looks like some problems at the coastline corners
ocean011
#1 Unread post by ocean011 »
Hi,i am running a project about north atalantic,and the model is blowing up,i checked the result and found that it's looks like some problems at the coastline corners :?: ,grid size is 1/12degree * 1/12degree,time steps is 180seconds,here is the surface u velocity component at each time step and the cpp options,could anyone help me?Thanks you all in advance.
cpp options:
AVERAGES Writing out time-averaged fields.
DIAGNOSTICS_TS Computing and writing tracer diagnostic terms.
DIAGNOSTICS_UV Computing and writing momentum diagnostic terms.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WET_DRY Wetting and drying activated.
surface u component
surface u component
Re: looks like some problems at the coastline corners
Which way is your u-velocity? If positive u is to the east, then you have strong downwelling flow in a very narrow band. It doesn't really make sense, oceanographically. What is driving that flow? Where does the water go? You have massive divergent flow so there must be some powerful forces causing it.
tony1230
#3 Unread post by tony1230 »
hi kate, why would you say"If positive u is to the east, then you have strong downwelling flow in a very narrow band." i wanna know how you identified the "downwelling flow"! thank you !
It just means you have surface flow towards the coast. It can't go into the coast so must go down. But yours doesn't make it to the coast - if it is indeed what that plot represents.
ocean011
#5 Unread post by ocean011 »
kate wrote:Which way is your u-velocity? If positive u is to the east, then you have strong downwelling flow in a very narrow band. It doesn't really make sense, oceanographically. What is driving that flow? Where does the water go? You have massive divergent flow so there must be some powerful forces causing it.
Hi,Kate.The postive u is the eastward velocity component.I checked the initial field,and calculated the du/dx+dv/dy to vertify the convergency and divergency.They are likely to result in the unstable state. Thank you very much for your help.
