What do I need to do to get the capability for large Netcdf files on a Linux system?
I had modified my earlier version of Roms to write binary files. Now I am switching to a newer version and want to use Netcdf files for output. Unfortunately the program bombs when the file reaches the 2 GB size.
How do I implement the LFS capability?
Thanks in advance.
Large Files on Linux Systems
netCDF files larger that 2GBytes
At first, I consider it a bad habit, because it can be avoided by arranging your output
into sequence of files, rather than single big file. Secondly, it restricts portability: you
must have an operating system which has Large File Support and you can no longer
open it from a 32-bit Matlab, and any other piece of software which uses earlier
versions of netCDF.
If you still desire to have netCDF files larger than 2Gbytes, here is what you have to do:
1. Make sure that you have the latest version of netcdf library, I am using
3.6.1 --- beta3
do not use earlier release of 3.6, as it is buggy specifically in large offset part.
Please let me know, it you are aware of a newer version.
2. When you create netcdf file, make sure that you enable 64BIT offset in netCDF:
it would not do it by default. To do so, find all occasions of NF_CREATE and
replace NF_CLOBBER with NF_64BIT_OFFSET, so it should look like
CALL NF_CREATE (filename, NF_64BIT_OFFSET, ncid)
More information about this matter can be found in
http://www.unidata.ucar.edu/software/ne ... 005fCREATE
versions of netCDF.
3.6.1 --- beta3
