Dear All
During compilation I faced to following massage
mv a.out roms
make Clock skew detected. Your build may be incomplete.
I know by "make clean" for the other compiler can fix above massage, in the roms case is not correct.
is anybody know how can I solve this warning massage.
High appritiate
F.Daryabor
Warning during Comapilation
Re: Warning during Comapilation
This is usually due to your computer time clock not being synced with remote computer that is storing your source code. If you are in a Linux environment, look in to running ntpd on both/all machines to keep your clocks synced.
This warning can be ignored if you do make clean before make or use the build script WITHOUT the -noclean flag.
