Screen Readable PDF Files
Milestones, stupid facts, and other fun information
#1 Unread post by arango »
Dear All,
When submitting a PDF document generated from TeX or LaTex be sure to use a command similar to create first the PostScript file
dvips -Ppdf MyFile.dvi
This filter will force the PostScript file with level-1 fonts. The resulting PDF file will render the text as text and not curves. It also makes the PDF file smalller.
Then, use any PS to PDF converter like ps2pdf.
Good luck,
Hernan G. Arango
arango@imcs.rutgers.edu
csn
#2 Unread post by csn »
Another possibility would be dvipdfm MyFile.dvi, which directly generates pdf.
Cheers, Christian
