Dear Rommers,
I´m trying to model a large and flat river in the Amazon basin. I have information of flow and velocity in the western boundary, wich I fit to an analytical expression and I´m trying to use ana_m2obc to force the model. When compiling the model I receive this error messages:
analytical.f90:304.39:
& IminS, ImaxS, JminS, JmaxS, &
1
Error: Symbol 'imaxs' at (1) has no IMPLICIT type
analytical.f90:304.32:
1
Error: Symbol 'imins' at (1) has no IMPLICIT type
analytical.f90:304.53:
1
Error: Symbol 'jmaxs' at (1) has no IMPLICIT type
analytical.f90:304.46:
1
Error: Symbol 'jmins' at (1) has no IMPLICIT type
My .h file is like below:
#undef UV_ADV
#undef UV_C4ADVECTION
#define UV_LDRAG
#undef TS_C4HADVECTION
#undef TS_C4VADVECTION
#undef SALINITY
#undef NONLIN_EOS
#undef MIX_S_UV
#undef VISC_GRID
#undef TS_DIF2
#undef MIX_S_TS
#undef DIFF_GRID
/* model configuration options */
#undef SOLVE3D
#undef DIAGNOSTICS_UV
#undef DIAGNOSTICS_TS
/* vertical turbulent mixing scheme */
#undef MY25_MIXING
#ifdef MY25_MIXING
# define N2S2_HORAVG /* use if Large et al. (1994) interior closure */
# define KANTHA_CLAYSON /* use if Kantha and Clayson stability function */
#define ANA_INITIAL
#define ANA_SMFLUX
#define ANA_SRFLUX
/* lateral boundary conditions */
#define SOUTHERN WALL
#define EAST_FSCHAPMAN
#define EAST_M2RADIATION
#define EAST_TRADIATION
#define WEST_FSCHAPMAN
#define WEST_TRADIATION
#define WEST_M2CLAMPED
#define NORTH_FSCHAPMAN
#define NORTH_M2FLATHER
#define NORTH_TRADIATION
#define ANA_FSOBC
#define ANA_M2OBC
#define ANA_TOBC
Any hints?
Thank you.
Mauricio
PROOCEANO - BRASIL
Problem using ana_m2obc
Re: Problem using ana_m2obc
Did you start from one of the ana_m2obc.h example files? Did you mix-and-match between ROMS versions? Is it complaining about lines in ana_m2obc or in ana_m2obc_tile? Did you include "tile.h" as in the example?
See https://www.myroms.org/wiki/index.php/P ... ode_syntax for what IminS and friends are.
Hi Kate. Thanks for the reply.
I´m running serial, so I guess it´s complaining about ana_m2obc.h.
I used ana_m2obc I downloaded along with ROMS code and just modified after the "else" part:
Thanks again,
Mauricio.
#else
# ifdef WEST_M2OBC
IF (WESTERN_EDGE) THEN
DO j=JstrR,JendR
BOUNDARY(ng)%ubar_west(j)=-0.65*(((j-1)*0.0133)-1)**2.+0.65
DO j=Jstr,JendR
BOUNDARY(ng)%vbar_west(j)=0.0_r8
Mauricio.
