error while using OA pacakge....
mashinde
Location: Indian Institute of Tropical Meteorology, Pune, INDIA
#1 Unread post by mashinde »
Dear All,
I use sun ultra 24 workstation......
I have following error after running 'make -f MakeFile.Sun'
f77 -c -fast -O3 -u -U -I/usr/local/include oamain.F
MAIN oamain:
Error on line 41 of <stdin>: Statement order error: declaration after DATA
Warning on line 316 of <stdin>: nf_put_varm_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_varnatts declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_redef declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf__open declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_abort declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_close declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var1_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vara_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vara_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_varm_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_varm_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var1_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vara_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_varm_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vara_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_enddef declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_varm_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_delete declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_create declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf__enddef declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_def_dim declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf__create declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_def_var declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_del_att declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_dim declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_att declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_var declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_varm_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vars_double declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf__open_mp declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_set_fill declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_copy_att declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_copy_var declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_strerror declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_issyserr declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_dimid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_attid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_varid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_ndims declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_nvars declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_natts declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncdid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nccre declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncvid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncopn declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf__create_mp declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_rename_dim declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_dimlen declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_rename_att declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_rename_var declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_attlen declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_format declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncddef declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_set_default_format declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncvdef declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_base_pe declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_set_base_pe declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nctlen declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_dimname declared EXTERNAL but never used.
Warning on line 316 of <stdin>: ncsfil declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_attname declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_varname declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_libvers declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_atttype declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_vartype declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_open declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var1_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vara_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var1_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_vardimid declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_varm_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_att_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var_real declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_unlimdim declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_vars_int declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_inq_varndims declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_att_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_get_var_text declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var1_int1 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_var1_int2 declared EXTERNAL but never used.
Warning on line 316 of <stdin>: nf_put_vara_int declared EXTERNAL but never used.
/usr/bin/f77: aborting compilation
make: *** [oamain.o] Error 255
so anybody knows where is the problem.
Thanks in advance.
Re: error while using OA pacakge....
The rest are warnings. The error is this one:
The code has statements out of order according to the Fortran standard.
