How to Build and Adjoint for ROMS/TOMS?
#1 Unread post by arango »
Below you will my find the links for the flash movies that I used in my presentation that shows how the adjoint model is built. It shows how the
tangent linear model (TLM) is built from the nonlinear model (NLM). Then, it shows how the adjoint model (ADM) is built from the tangent linear model. It also shows how the representer model (RPM) is built from the tangent linear model. The RPM is used for weak constraint variational data assimilation via IOM indirect representer method.
http://www.myroms.org/webcasts/tlm.html
http://www.myroms.org/webcasts/adm.html
http://www.myroms.org/webcasts/rpm.html
The PowerPoint presentation for this talk can be found in:
http://www.myroms.org/Workshops/ROMS200 ... djoint.ppt
Please notice that in order to see this PPT correctly you need to install Swiff Point Player which insert and play flash movies in PowerPoint. This is a freely distributed software, please check http://www.globfx.com
