The error is in checkvar.F, when set the sediment on. The mud_01 and snad_01 are considered as mud_ and sand_
error information:
NLM:checkvar unable to find model variable : mud_
sediment bug in the latest verison 429
Re: sediment bug in the latest verison 429
Yes, I missed this one. Good catch, thank you. Please update. Check the following
ticket for details.
I'm afraid there are still some problems with the variables, maybe with the bry file varibles. Pls check out~
I did check all the logic for the sediment variables in the debugger and all the boundary metadata is defined correctly. In this new version, all the sediment model metadata is now processed in new include file ROMS/Nonlinear/Sediment/sediment_var.h. See the following
ticket for details.
If there is still a problem, you need to be more specific and provide the error printed to the standard output file. Also you need to check the last line of that file that prints the NetCDF library error string explaining the problem. You always need to look the standard out file carefully
You need to redirect this to a log file, for example:
and not print directly to the screen because you can miss the error. We have recommeded this so many times in this forum and explained well in the Wiki.
![Exclamation :!:](./images/smilies/icon_exclaim.gif)
% mpirun -np 2 oceanM ocean.in > & log &
Sorry for that. Actually, the error is about the river sediment. The files are all the same, But it is right in the ROMS version 399 and wrong in the verison 429 or the lastest one. The north south east and west boundary sediment condition all exist in the bry file. Log files are below:
Thank you~
Time is date
cat ${PSB_NODEFILE}
This job has allocated 64 nodes
Process Information: Node # 38 (pid= 3784) is active. Node # 22 (pid= 13451) is active. Node # 37 (pid= 3782) is active. Node # 39 (pid= 3785) is active.
Node # 44 (pid= 3790) is active. Node # 36 (pid= 3781) is active.
Node # 45 (pid= 3791) is active.
Node # 33 (pid= 3778) is active. Node # 34 (pid= 3779) is active. Node # 43 (pid= 3789) is active.
Node # 42 (pid= 3788) is active.
Node # 35 (pid= 3780) is active. Node # 46 (pid= 3792) is active. Node # 47 (pid= 3793) is active. Node # 41 (pid= 3787) is active. Node # 40 (pid= 3786) is active.
Node # 20 (pid= 13449) is active.
Node # 23 (pid= 13452) is active.
Node # 19 (pid= 13448) is active. Node # 18 (pid= 13447) is active.
Node # 29 (pid= 13458) is active. Node # 28 (pid= 13457) is active.
Node # 31 (pid= 13460) is active. Node # 25 (pid= 13454) is active. Node # 21 (pid= 13450) is active.
Node # 30 (pid= 13459) is active.
Node # 17 (pid= 13446) is active.
Node # 16 (pid= 13445) is active.
Node # 53 (pid= 21320) is active. Node # 54 (pid= 21321) is active. Node # 48 (pid= 21315) is active.
Node # 50 (pid= 21317) is active. Node # 52 (pid= 21319) is active.
Node # 55 (pid= 21322) is active.
Node # 51 (pid= 21318) is active. Node # 49 (pid= 21316) is active. Node # 63 (pid= 21330) is active. Node # 62 (pid= 21329) is active. Node # 60 (pid= 21327) is active. Node # 61 (pid= 21328) is active.
Node # 59 (pid= 21326) is active.
Node # 56 (pid= 21323) is active.
Node # 58 (pid= 21325) is active. Node # 57 (pid= 21324) is active.
Node # 12 (pid= 25681) is active. Node # 13 (pid= 25682) is active. Node # 5 (pid= 25674) is active.
Node # 6 (pid= 25675) is active.
Node # 11 (pid= 25680) is active. Node # 8 (pid= 25677) is active. Node # 9 (pid= 25678) is active.
Node # 7 (pid= 25676) is active.
Node # 10 (pid= 25679) is active. Node # 2 (pid= 25671) is active.
Node # 1 (pid= 25670) is active.
Node # 4 (pid= 25673) is active. Node # 3 (pid= 25672) is active. Node # 15 (pid= 25684) is active.
Node # 14 (pid= 25683) is active.
Node # 0 (pid= 25669) is active.
Node # 32 (pid= 3777) is active.
Node # 24 (pid= 13453) is active.
Node # 26 (pid= 13455) is active.
Node # 27 (pid= 13456) is active.
Sunday - January 10, 2010 - 9:02:15 PM
East China Sea Sediment
Operating system : Linux
CPU/hardware : x86_64
Compiler system : pgi
Compiler command : /opt/mpi/mvapich/1.1/gcc.pgf90/bin/mpif90
Compiler flags : -O3 -tp k8-64 -Mfree
Input Script : /dcfs2/users/leon/Documents/trunk/User/External/ecs22.in
SVN Revision : 405:437M
Local Root : /dcfs2/users/leon/Documents/trunk
Header Dir : /dcfs2/users/leon/Documents/trunk/ROMS/Include
Header file : bedload.h
Analytical Dir: /dcfs2/users/leon/Documents/trunk/ROMS/Functionals
Resolution, Grid 01: 0368x0440x030, Parallel Nodes: 64, Tiling: 008x008
466560 ntimes Number of timesteps for 3-D equations.
200.000 dt Timestep size (s) for 3-D equations.
50 ndtfast Number of timesteps for 2-D equations between
12960 nRST Number of timesteps between the writing of data
into restart fields.
10 ninfo Number of timesteps between print of information
to standard output.
12960 nHIS Number of timesteps between the writing fields
into history file.
12960 ntsAVG Starting timestep for the accumulation of output
time-averaged data.
12960 nAVG Number of timesteps between the writing of
12960 ndefAVG Number of timesteps between creation of new
time-averaged file.
(m2/s) for tracer 01: temp
(m2/s) for tracer 02: salt
4.0000E+01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
for turbulent energy.
2 Vstretching S-coordinate stretching function.
5.0000E+00 theta_b S-coordinate bottom control parameter.
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
F LtracerSrc(01) Processing point sources/Sink on tracer 01: temp
F LtracerSrc(02) Processing point sources/Sink on tracer 02: salt
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idTdif) Write out vertical T-diffusion coefficient.
Output Restart File: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22_rst.nc
Output History File: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22_his.nc
Prefix for Averages Files: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22_avg
Input Grid File: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-grid.nc
Input Nonlinear Initial File: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-init.nc
Input Forcing File 01: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-forc.nc
Input Forcing File 02: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-tide72.nc
Input Boundary File: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-bry.nc
Tile partition information for Grid 01: 0368x0440x0030 tiling: 008x008
tile Istr Iend Jstr Jend Npts
0 1 46 1 55 75900
1 47 92 1 55 75900
2 93 138 1 55 75900
3 139 184 1 55 75900
4 185 230 1 55 75900
5 231 276 1 55 75900
6 277 322 1 55 75900
7 323 368 1 55 75900
8 1 46 56 110 75900
9 47 92 56 110 75900
10 93 138 56 110 75900
11 139 184 56 110 75900
12 185 230 56 110 75900
13 231 276 56 110 75900
14 277 322 56 110 75900
15 323 368 56 110 75900
16 1 46 111 165 75900
17 47 92 111 165 75900
18 93 138 111 165 75900
19 139 184 111 165 75900
20 185 230 111 165 75900
21 231 276 111 165 75900
22 277 322 111 165 75900
23 323 368 111 165 75900
24 1 46 166 220 75900
25 47 92 166 220 75900
26 93 138 166 220 75900
27 139 184 166 220 75900
28 185 230 166 220 75900
29 231 276 166 220 75900
30 277 322 166 220 75900
31 323 368 166 220 75900
32 1 46 221 275 75900
33 47 92 221 275 75900
34 93 138 221 275 75900
35 139 184 221 275 75900
36 185 230 221 275 75900
37 231 276 221 275 75900
38 277 322 221 275 75900
39 323 368 221 275 75900
40 1 46 276 330 75900
41 47 92 276 330 75900
42 93 138 276 330 75900
43 139 184 276 330 75900
44 185 230 276 330 75900
45 231 276 276 330 75900
46 277 322 276 330 75900
47 323 368 276 330 75900
48 1 46 331 385 75900
49 47 92 331 385 75900
50 93 138 331 385 75900
51 139 184 331 385 75900
52 185 230 331 385 75900
53 231 276 331 385 75900
54 277 322 331 385 75900
55 323 368 331 385 75900
56 1 46 386 440 75900
57 47 92 386 440 75900
58 93 138 386 440 75900
59 139 184 386 440 75900
60 185 230 386 440 75900
61 231 276 386 440 75900
62 277 322 386 440 75900
63 323 368 386 440 75900
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 46.50 0.50 55.50 RHO-points
1 46.50 92.50 0.50 55.50 RHO-points
2 92.50 138.50 0.50 55.50 RHO-points
3 138.50 184.50 0.50 55.50 RHO-points
4 184.50 230.50 0.50 55.50 RHO-points
5 230.50 276.50 0.50 55.50 RHO-points
6 276.50 322.50 0.50 55.50 RHO-points
7 322.50 368.50 0.50 55.50 RHO-points
8 0.50 46.50 55.50 110.50 RHO-points
9 46.50 92.50 55.50 110.50 RHO-points
10 92.50 138.50 55.50 110.50 RHO-points
11 138.50 184.50 55.50 110.50 RHO-points
12 184.50 230.50 55.50 110.50 RHO-points
13 230.50 276.50 55.50 110.50 RHO-points
14 276.50 322.50 55.50 110.50 RHO-points
15 322.50 368.50 55.50 110.50 RHO-points
16 0.50 46.50 110.50 165.50 RHO-points
17 46.50 92.50 110.50 165.50 RHO-points
18 92.50 138.50 110.50 165.50 RHO-points
19 138.50 184.50 110.50 165.50 RHO-points
20 184.50 230.50 110.50 165.50 RHO-points
21 230.50 276.50 110.50 165.50 RHO-points
22 276.50 322.50 110.50 165.50 RHO-points
23 322.50 368.50 110.50 165.50 RHO-points
24 0.50 46.50 165.50 220.50 RHO-points
25 46.50 92.50 165.50 220.50 RHO-points
26 92.50 138.50 165.50 220.50 RHO-points
27 138.50 184.50 165.50 220.50 RHO-points
28 184.50 230.50 165.50 220.50 RHO-points
29 230.50 276.50 165.50 220.50 RHO-points
30 276.50 322.50 165.50 220.50 RHO-points
31 322.50 368.50 165.50 220.50 RHO-points
32 0.50 46.50 220.50 275.50 RHO-points
33 46.50 92.50 220.50 275.50 RHO-points
34 92.50 138.50 220.50 275.50 RHO-points
35 138.50 184.50 220.50 275.50 RHO-points
36 184.50 230.50 220.50 275.50 RHO-points
37 230.50 276.50 220.50 275.50 RHO-points
38 276.50 322.50 220.50 275.50 RHO-points
39 322.50 368.50 220.50 275.50 RHO-points
40 0.50 46.50 275.50 330.50 RHO-points
41 46.50 92.50 275.50 330.50 RHO-points
42 92.50 138.50 275.50 330.50 RHO-points
43 138.50 184.50 275.50 330.50 RHO-points
44 184.50 230.50 275.50 330.50 RHO-points
45 230.50 276.50 275.50 330.50 RHO-points
46 276.50 322.50 275.50 330.50 RHO-points
47 322.50 368.50 275.50 330.50 RHO-points
48 0.50 46.50 330.50 385.50 RHO-points
49 46.50 92.50 330.50 385.50 RHO-points
50 92.50 138.50 330.50 385.50 RHO-points
51 138.50 184.50 330.50 385.50 RHO-points
52 184.50 230.50 330.50 385.50 RHO-points
53 230.50 276.50 330.50 385.50 RHO-points
54 276.50 322.50 330.50 385.50 RHO-points
55 322.50 368.50 330.50 385.50 RHO-points
56 0.50 46.50 385.50 440.50 RHO-points
57 46.50 92.50 385.50 440.50 RHO-points
58 92.50 138.50 385.50 440.50 RHO-points
59 138.50 184.50 385.50 440.50 RHO-points
60 184.50 230.50 385.50 440.50 RHO-points
61 230.50 276.50 385.50 440.50 RHO-points
62 276.50 322.50 385.50 440.50 RHO-points
63 322.50 368.50 385.50 440.50 RHO-points
0 1.00 46.50 0.50 55.50 U-points
1 46.50 92.50 0.50 55.50 U-points
2 92.50 138.50 0.50 55.50 U-points
3 138.50 184.50 0.50 55.50 U-points
4 184.50 230.50 0.50 55.50 U-points
5 230.50 276.50 0.50 55.50 U-points
6 276.50 322.50 0.50 55.50 U-points
7 322.50 368.00 0.50 55.50 U-points
8 1.00 46.50 55.50 110.50 U-points
9 46.50 92.50 55.50 110.50 U-points
10 92.50 138.50 55.50 110.50 U-points
11 138.50 184.50 55.50 110.50 U-points
12 184.50 230.50 55.50 110.50 U-points
13 230.50 276.50 55.50 110.50 U-points
14 276.50 322.50 55.50 110.50 U-points
15 322.50 368.00 55.50 110.50 U-points
16 1.00 46.50 110.50 165.50 U-points
17 46.50 92.50 110.50 165.50 U-points
18 92.50 138.50 110.50 165.50 U-points
19 138.50 184.50 110.50 165.50 U-points
20 184.50 230.50 110.50 165.50 U-points
21 230.50 276.50 110.50 165.50 U-points
22 276.50 322.50 110.50 165.50 U-points
23 322.50 368.00 110.50 165.50 U-points
24 1.00 46.50 165.50 220.50 U-points
25 46.50 92.50 165.50 220.50 U-points
26 92.50 138.50 165.50 220.50 U-points
27 138.50 184.50 165.50 220.50 U-points
28 184.50 230.50 165.50 220.50 U-points
29 230.50 276.50 165.50 220.50 U-points
30 276.50 322.50 165.50 220.50 U-points
31 322.50 368.00 165.50 220.50 U-points
32 1.00 46.50 220.50 275.50 U-points
33 46.50 92.50 220.50 275.50 U-points
34 92.50 138.50 220.50 275.50 U-points
35 138.50 184.50 220.50 275.50 U-points
36 184.50 230.50 220.50 275.50 U-points
37 230.50 276.50 220.50 275.50 U-points
38 276.50 322.50 220.50 275.50 U-points
39 322.50 368.00 220.50 275.50 U-points
40 1.00 46.50 275.50 330.50 U-points
41 46.50 92.50 275.50 330.50 U-points
42 92.50 138.50 275.50 330.50 U-points
43 138.50 184.50 275.50 330.50 U-points
44 184.50 230.50 275.50 330.50 U-points
45 230.50 276.50 275.50 330.50 U-points
46 276.50 322.50 275.50 330.50 U-points
47 322.50 368.00 275.50 330.50 U-points
48 1.00 46.50 330.50 385.50 U-points
49 46.50 92.50 330.50 385.50 U-points
50 92.50 138.50 330.50 385.50 U-points
51 138.50 184.50 330.50 385.50 U-points
52 184.50 230.50 330.50 385.50 U-points
53 230.50 276.50 330.50 385.50 U-points
54 276.50 322.50 330.50 385.50 U-points
55 322.50 368.00 330.50 385.50 U-points
56 1.00 46.50 385.50 440.50 U-points
57 46.50 92.50 385.50 440.50 U-points
58 92.50 138.50 385.50 440.50 U-points
59 138.50 184.50 385.50 440.50 U-points
60 184.50 230.50 385.50 440.50 U-points
61 230.50 276.50 385.50 440.50 U-points
62 276.50 322.50 385.50 440.50 U-points
63 322.50 368.00 385.50 440.50 U-points
0 0.50 46.50 1.00 55.50 V-points
1 46.50 92.50 1.00 55.50 V-points
2 92.50 138.50 1.00 55.50 V-points
3 138.50 184.50 1.00 55.50 V-points
4 184.50 230.50 1.00 55.50 V-points
5 230.50 276.50 1.00 55.50 V-points
6 276.50 322.50 1.00 55.50 V-points
7 322.50 368.50 1.00 55.50 V-points
8 0.50 46.50 55.50 110.50 V-points
9 46.50 92.50 55.50 110.50 V-points
10 92.50 138.50 55.50 110.50 V-points
11 138.50 184.50 55.50 110.50 V-points
12 184.50 230.50 55.50 110.50 V-points
13 230.50 276.50 55.50 110.50 V-points
14 276.50 322.50 55.50 110.50 V-points
15 322.50 368.50 55.50 110.50 V-points
16 0.50 46.50 110.50 165.50 V-points
17 46.50 92.50 110.50 165.50 V-points
18 92.50 138.50 110.50 165.50 V-points
19 138.50 184.50 110.50 165.50 V-points
20 184.50 230.50 110.50 165.50 V-points
21 230.50 276.50 110.50 165.50 V-points
22 276.50 322.50 110.50 165.50 V-points
23 322.50 368.50 110.50 165.50 V-points
24 0.50 46.50 165.50 220.50 V-points
25 46.50 92.50 165.50 220.50 V-points
26 92.50 138.50 165.50 220.50 V-points
27 138.50 184.50 165.50 220.50 V-points
28 184.50 230.50 165.50 220.50 V-points
29 230.50 276.50 165.50 220.50 V-points
30 276.50 322.50 165.50 220.50 V-points
31 322.50 368.50 165.50 220.50 V-points
32 0.50 46.50 220.50 275.50 V-points
33 46.50 92.50 220.50 275.50 V-points
34 92.50 138.50 220.50 275.50 V-points
35 138.50 184.50 220.50 275.50 V-points
36 184.50 230.50 220.50 275.50 V-points
37 230.50 276.50 220.50 275.50 V-points
38 276.50 322.50 220.50 275.50 V-points
39 322.50 368.50 220.50 275.50 V-points
40 0.50 46.50 275.50 330.50 V-points
41 46.50 92.50 275.50 330.50 V-points
42 92.50 138.50 275.50 330.50 V-points
43 138.50 184.50 275.50 330.50 V-points
44 184.50 230.50 275.50 330.50 V-points
45 230.50 276.50 275.50 330.50 V-points
46 276.50 322.50 275.50 330.50 V-points
47 322.50 368.50 275.50 330.50 V-points
48 0.50 46.50 330.50 385.50 V-points
49 46.50 92.50 330.50 385.50 V-points
50 92.50 138.50 330.50 385.50 V-points
51 138.50 184.50 330.50 385.50 V-points
52 184.50 230.50 330.50 385.50 V-points
53 230.50 276.50 330.50 385.50 V-points
54 276.50 322.50 330.50 385.50 V-points
55 322.50 368.50 330.50 385.50 V-points
56 0.50 46.50 385.50 440.00 V-points
57 46.50 92.50 385.50 440.00 V-points
58 92.50 138.50 385.50 440.00 V-points
59 138.50 184.50 385.50 440.00 V-points
60 184.50 230.50 385.50 440.00 V-points
61 230.50 276.50 385.50 440.00 V-points
62 276.50 322.50 385.50 440.00 V-points
63 322.50 368.50 385.50 440.00 V-points
HaloSizeI(1) = 180
HaloSizeJ(1) = 207
TileSide(1) = 63
TileSize(1) = 3402
Sediment Parameters, Grid: 01
1 8.0000E-03 0.0000E+00 2.6500E+03 3.5700E-02 5.0000E-04 6.8240E-01
2 8.0000E-02 0.0000E+00 2.6500E+03 4.1879E+00 1.0000E-04 4.8510E-01
tau_ce tau_cd nl_tnu2 nl_tnu4 Akt_bak Tnudg
1 2.2431E-02 9.9690E-03 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
2 1.0394E-01 4.6194E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
2 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.10000E-01 (m).
Rate coefficient for bed load transport = 0.50000E-01
F LtracerSrc(03) Processing point sources/Sink on tracer 03: mud_01
F LtracerSrc(04) Processing point sources/Sink on tracer 04: sand_01
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idTvar) Write out sediment02: sand_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out bed fraction, sediment 02: sandfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idfrac) Write out mass, sediment 02: sandmass_01
T Hout(idUbld) Write out bed load at U-points, sediment 01: bedload_Umud_01
T Hout(idVbld) Write out bed load at V-points, sediment 01: bedload_Vmud_01
T Hout(idUbld) Write out bed load at U-points, sediment 02: bedload_Usand_01
T Hout(idVbld) Write out bed load at V-points, sediment 02: bedload_Vsand_01
T Hout(idSbed) Write out BED property 03: bed_porosity
BEDLOAD East China Sea Sediment
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
ADD_M2OBC Adding tidal currents to proccesed OBC data.
BEDLOAD_MPM Activate bed load sediment transport Meyer-Peter-Mueller.
EAST_M3GRADIENT Eastern edge, 3D momentum, gradient condition.
EAST_TNUDGING Eastern edge, tracers, passive/active outflow/inflow.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
NORTH_M3GRADIENT Northern edge, 3D momentum, gradient condition.
NORTH_TNUDGING Northern edge, tracers, passive/active outflow/inflow.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
OUT_DOUBLE Double precision output fields in NetCDF files.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SOUTH_M3GRADIENT Southern edge, 3D momentum, gradient condition.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
THREE_GHOST Using three Ghost Points in halo regions.
TS_PSOURCE Tracers point sources and sinks.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_PSOURCE Mass point sources and sinks.
Vertical S-coordinate System:
30 0.0000000 0.0000000 0.000 0.000 0.000
29 -0.0333333 -0.0007218 -0.085 -2.475 -4.783
28 -0.0666667 -0.0034632 -0.175 -11.406 -22.480
27 -0.1000000 -0.0088852 -0.272 -28.910 -57.320
26 -0.1333333 -0.0174334 -0.377 -56.409 -112.153
25 -0.1666667 -0.0293918 -0.490 -94.813 -188.794
24 -0.2000000 -0.0449244 -0.612 -144.645 -288.291
23 -0.2333333 -0.0641059 -0.744 -206.144 -411.123
22 -0.2666667 -0.0869446 -0.884 -279.337 -557.343
21 -0.3000000 -0.1133988 -1.033 -364.091 -726.684
20 -0.3333333 -0.1433880 -1.192 -460.148 -918.632
19 -0.3666667 -0.1768003 -1.359 -567.151 -1132.470
18 -0.4000000 -0.2134957 -1.534 -684.651 -1367.304
17 -0.4333333 -0.2533078 -1.717 -812.117 -1622.069
16 -0.4666667 -0.2960427 -1.907 -948.929 -1895.526
15 -0.5000000 -0.3414759 -2.104 -1094.368 -2186.238
14 -0.5333333 -0.3893475 -2.307 -1247.604 -2492.544
13 -0.5666667 -0.4393561 -2.515 -1407.673 -2812.515
12 -0.6000000 -0.4911506 -2.728 -1573.453 -3143.908
11 -0.6333333 -0.5443212 -2.944 -1743.633 -3484.101
10 -0.6666667 -0.5983879 -3.163 -1916.678 -3830.023
9 -0.7000000 -0.6527875 -3.382 -2090.788 -4178.076
8 -0.7333333 -0.7068593 -3.600 -2263.849 -4524.032
7 -0.7666667 -0.7598274 -3.816 -2433.382 -4862.930
6 -0.8000000 -0.8107817 -4.027 -2596.475 -5188.949
5 -0.8333333 -0.8586552 -4.230 -2749.717 -5495.267
4 -0.8666667 -0.9021993 -4.422 -2889.116 -5773.898
3 -0.9000000 -0.9399541 -4.600 -3010.004 -6015.507
2 -0.9333333 -0.9702163 -4.759 -3106.933 -6209.200
1 -0.9666667 -0.9910011 -4.894 -3173.559 -6342.285
0 -1.0000000 -1.0000000 -5.000 -3202.500 -6400.000
Time Splitting Weights: ndtfast = 50 nfast = 69
1-0.0004563262418391 0.0200000000000000-0.0004563262418391 0.0200000000000000
2-0.0008555246732536 0.0200091265248368-0.0013118509150927 0.0400091265248368
3-0.0011975957891734 0.0200262370183019-0.0025094467042661 0.0600353635431387
4-0.0014825415143255 0.0200501889340853-0.0039919882185915 0.0800855524772240
5-0.0017103668530001 0.0200798397643718-0.0057023550715916 0.1001653922415958
6-0.0018810821987231 0.0201140471014318-0.0075834372703147 0.1202794393430276
7-0.0019947063038349 0.0201516687454063-0.0095781435741496 0.1404311080884340
8-0.0020512699089757 0.0201915628714830-0.0116294134831253 0.1606226709599169
9-0.0020508200324769 0.0202325882696625-0.0136802335156022 0.1808552592295795
10-0.0019934249196594 0.0202736046703121-0.0156736584352616 0.2011288638998915
11-0.0018791796520380 0.0203134731687052-0.0175528380872996 0.2214423370685968
12-0.0017082124164322 0.0203510567617460-0.0192610505037318 0.2417933938303428
13-0.0014806914339834 0.0203852210100746-0.0207417419377152 0.2621786148404174
14-0.0011968325490789 0.0204148348387543-0.0219385744867941 0.2825934496791717
15-0.0008569074781817 0.0204387714897359-0.0227954819649758 0.3030322211689075
16-0.0004612527185669 0.0204559096392995-0.0232567346835427 0.3234881308082070
17-0.0000102791169649 0.0204651346936709-0.0232670138005077 0.3439532655018779
18 0.0004955179018893 0.0204653402760102-0.0227714958986183 0.3644186057778880
19 0.0010555474468010 0.0204554299179724-0.0217159484518173 0.3848740356958604
20 0.0016691116117526 0.0204343189690364-0.0200468368400647 0.4053083546648968
21 0.0023353932676362 0.0204009367368013-0.0177114435724285 0.4257092914016981
22 0.0030534431940779 0.0203542288714486-0.0146580003783505 0.4460635202731467
23 0.0038221665513568 0.0202931600075670-0.0108358338269937 0.4663566802807137
24 0.0046403086924171 0.0202167166765399-0.0061955251345765 0.4865733969572536
25 0.0055064403149742 0.0201239105026915-0.0006890848196024 0.5066973074599451
26 0.0064189419537136 0.0200137816963921 0.0057298571341112 0.5267110891563371
27 0.0073759878125848 0.0198854028573178 0.0131058449466960 0.5465964920136549
28 0.0083755289371871 0.0197378831010661 0.0214813738838831 0.5663343751147210
29 0.0094152757272501 0.0195703725223223 0.0308966496111332 0.5859047476370433
30 0.0104926797892080 0.0193820670077773 0.0413893294003412 0.6052868146448206
31 0.0116049151288660 0.0191722134119932 0.0529942445292072 0.6244590280568137
32 0.0127488586841624 0.0189401151094159 0.0657431032133696 0.6433991431662296
33 0.0139210701980223 0.0186851379357326 0.0796641734113919 0.6620842811019622
34 0.0151177714313064 0.0184067165317722 0.0947819448426983 0.6804909976337343
35 0.0163348247158524 0.0181043611031460 0.1111167695585507 0.6985953587368804
36 0.0175677108476106 0.0177776646088290 0.1286844804061612 0.7163730233457094
37 0.0188115063198728 0.0174263103918768 0.1474959867260340 0.7337993337375862
38 0.0200608598965948 0.0170500802654793 0.1675568466226288 0.7508494140030655
39 0.0213099685258127 0.0166488630675474 0.1888668151484416 0.7674982770706129
40 0.0225525525931525 0.0162226636970312 0.2114193677415941 0.7837209407676441
41 0.0237818305154335 0.0157716126451681 0.2352011982570276 0.7994925534128122
42 0.0249904926743652 0.0152959760348595 0.2601916909313928 0.8147885294476717
43 0.0261706746903379 0.0147961661813722 0.2863623656217307 0.8295846956290438
44 0.0273139300363068 0.0142727526875654 0.3136762956580375 0.8438574483166091
45 0.0284112019917697 0.0137264740868393 0.3420874976498072 0.8575839224034484
46 0.0294527949368383 0.0131582500470039 0.3715402925866456 0.8707421724504523
47 0.0304283449864031 0.0125691941482671 0.4019686375730487 0.8833113665987193
48 0.0313267899643920 0.0119606272485390 0.4332954275374407 0.8952719938472583
49 0.0321363387181221 0.0113340914492512 0.4654317662555627 0.9066060852965095
50 0.0328444397727456 0.0106913646748887 0.4982762060283084 0.9172974499713983
51 0.0334377493257894 0.0100344758794338 0.5317139553540977 0.9273319258508321
52 0.0339020985817871 0.0093657208929180 0.5656160539358848 0.9366976467437502
53 0.0342224604270064 0.0086876789212823 0.5998385143628912 0.9453853256650325
54 0.0343829154442684 0.0080032297127422 0.6342214298071596 0.9533885553777747
55 0.0343666172678620 0.0073155714038568 0.6685880470750215 0.9607041267816315
56 0.0341557572785502 0.0066282390584996 0.7027438043535718 0.9673323658401310
57 0.0337315286386720 0.0059451239129286 0.7364753329922438 0.9732774897530596
58 0.0330740896673358 0.0052704933401551 0.7695494226595796 0.9785479830932148
59 0.0321625265557082 0.0046090115468084 0.8017119492152878 0.9831569946400232
60 0.0309748154223953 0.0039657610156942 0.8326867646376830 0.9871227556557174
61 0.0294877837089178 0.0033462647072463 0.8621745483466008 0.9904690203629637
62 0.0276770709152801 0.0027565090330680 0.8898516192618808 0.9932255293960317
63 0.0255170886756324 0.0022029676147624 0.9153687079375131 0.9954284970107941
64 0.0229809801740268 0.0016926258412497 0.9383496881115398 0.9971211228520438
65 0.0200405789002670 0.0012330062377692 0.9583902670118067 0.9983541290898130
66 0.0166663667458513 0.0008321946597639 0.9750566337576579 0.9991863237495768
67 0.0128274314400094 0.0004988673248468 0.9878840651976674 0.9996851910744237
68 0.0084914233258330 0.0002423186960466 0.9963754885235003 0.9999275097704703
69 0.0036245114764992 0.0000724902295300 0.9999999999999996 1.0000000000000000
ndtfast, nfast = 50 69 nfast/ndtfast = 1.38000
1.000000000000 1.033396903681 0.516698451840 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.22720
Minimum X-grid spacing, DXmin = 3.45982981E+00 km
Maximum X-grid spacing, DXmax = 4.22577922E+00 km
Minimum Y-grid spacing, DYmin = 4.11249518E+00 km
Maximum Y-grid spacing, DYmax = 5.02293410E+00 km
Minimum Z-grid spacing, DZmin = 8.51378686E-02 m
Maximum Z-grid spacing, DZmax = 3.48052605E+02 m
Minimum barotropic Courant Number = 8.68999059E-03
Maximum barotropic Courant Number = 3.21482984E-01
Maximum Coriolis Courant Number = 1.91235784E-02
NLM: GET_STATE - Read state initial conditions, t = 15 00:00:00
(File: ecs22-init.nc, Rec=0001, Index=1)
- free-surface
- u-momentum component
- v-momentum component
- potential temperature
(Min = 1.11511000E-01 Max = 2.46325836E+01)
- salinity
(Min = 2.84233093E+01 Max = 3.49072609E+01)
- suspended cohesive sediment, size class 01
- suspended noncohesive sediment, size class 01
- cohesive sediment fraction, size class 01
(Min = 5.00000000E-01 Max = 5.00000000E-01)
- cohesive sediment mass, size class 01
- noncohesive sediment fraction, size class 01
- noncohesive sediment mass, size class 01
- sediment bed layer thickness
- sediment layer age
- sediment layer porosity
- biodiffusivity at bottom of each layer
- sediment median grain diameter size
(Min = 2.52982213E-05 Max = 2.52982213E-05)
- sediment median grain density
(Min = 2.65000000E+03 Max = 2.65000000E+03)
- sediment median grain settling velocity
(Min = 3.86662682E-04 Max = 3.86662682E-04)
- sediment median critical erosion stress
(Min = 4.82846854E-02 Max = 4.82846854E-02)
- bottom ripple length
(Min = 1.00000000E-01 Max = 1.00000000E-01)
- bottom ripple height
(Min = 1.00000000E-02 Max = 1.00000000E-02)
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 9.29494800E+04)
(Min = 0.00000000E+00 Max = 6.13701777E+00)
(Min = 1.37093384E-04 Max = 6.28299337E+00)
(Min = 0.00000000E+00 Max = 3.14159265E+00)
(Min = 0.00000000E+00 Max = 6.28317670E+00)
(Min = 0.00000000E+00 Max = 6.04248924E+00)
(Min = -7.02054542E-02 Max = 1.10750142E-01)
(Min = 1.11000000E+02 Max = 1.11000000E+02)
(Min = 2.12000000E+02 Max = 2.12000000E+02)
(Min = 3.33333333E-02 Max = 3.33333333E-02)
GET_NGFLD - river runoff mass transport, t = 15 00:00:00
(Rec=0001, Index=1, File: ecs22-forc.nc)
(Min = 1.07000000E+04 Max = 1.07000000E+04)
(Min = -9.63994182E-05 Max = 8.67807185E-05)
(Min = -1.70242822E-04 Max = -5.18803996E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 2.56314001E+00 Max = 2.46325831E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -1.88635921E-05 Max = -8.02302277E-06)
GET_2DFLD - surface net freswater flux, (E-P), t = 15 00:00:00
(Min = 2.84413709E+01 Max = 3.48685579E+01)
(Rec=0001, Index=2, File: ecs22-bry.nc)
(Min = -1.23256712E-01 Max = 9.66403893E-01)
(Min = -2.49090120E-02 Max = 9.14263226E-01)
GET_NGFLD - free-surface northern boundary condition, t = 15 00:00:00
(Min = -2.12015561E-01 Max = 3.04446945E-02)
(Min = -9.57948996E-02 Max = 3.86646355E-01)
(Min = -1.87730295E-01 Max = 1.44428503E-01)
(Min = -1.98771698E-01 Max = 2.37601863E-01)
(Min = -7.00757756E-01 Max = 4.10468666E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 15 00:00:00
(Min = -7.15604833E-01 Max = 2.44446378E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 15 00:00:00
(Min = -2.91737026E-01 Max = 6.85510640E-02)
(Min = 1.21501069E-01 Max = 2.37951673E+01)
(Min = 3.39003970E+01 Max = 3.49070123E+01)
GET_NGFLD - suspended cohesive sediment eastern boundart = 15 00:00:00class 01,
GET_NGFLD - suspended noncohesive sediment eastern bount = 15 00:00:00ze class 01,
(Min = 1.48498585E+00 Max = 2.46325831E+01)
(Min = 3.41652605E+01 Max = 3.49048230E+01)
GET_NGFLD - suspended cohesive sediment southern boundat = 15 00:00:00 class 01,
GET_NGFLD - suspended noncohesive sediment southern bout = 15 00:00:00ize class 01,
GET_NGFLD - temperature northern boundary condition, t = 15 00:00:00
(Min = 1.11510998E-01 Max = 5.85751113E+00)
GET_NGFLD - salinity northern boundary condition, t = 15 00:00:00
(Min = 2.84233091E+01 Max = 3.41462627E+01)
GET_NGFLD - suspended noncohesive sediment northern bout = 15 00:00:00ize class 01,
GET_NGFLD - unable to find requested variable: ^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@^@
in file: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-bry.nc
Elapsed CPU time (seconds):
Node # 0 CPU: 10.936
Node # 12 CPU: 10.961
Node # 13 CPU: 10.961
Node # 14 CPU: 10.961
Node # 15 CPU: 10.961
Node # 6 CPU: 10.961
Node # 4 CPU: 10.961
Node # 7 CPU: 10.961
Node # 9 CPU: 10.961
Node # 8 CPU: 10.961
Node # 11 CPU: 10.961
Node # 3 CPU: 10.961
Node # 10 CPU: 10.961 Node # 1 CPU: 10.961
Node # 2 CPU: 10.961
Node # 5 CPU: 10.961
Node # 38 CPU: 10.961
Node # 21 CPU: 10.961
Node # 39 CPU: 10.961
Node # 37 CPU: 10.961 Node # 36 CPU: 10.961
Node # 34 CPU: 10.961
Node # 47 CPU: 10.961
Node # 43 CPU: 10.961
Node # 33 CPU: 10.961
Node # 42 CPU: 10.961 Node # 40 CPU: 10.961
Node # 44 CPU: 10.961 Node # 41 CPU: 10.961 Node # 35 CPU: 10.961
Node # 54 CPU: 10.961
Node # 55 CPU: 10.961 Node # 52 CPU: 10.961
Node # 53 CPU: 10.961
Node # 49 CPU: 10.961
Node # 61 CPU: 10.961
Node # 62 CPU: 10.961 Node # 56 CPU: 10.961
Node # 57 CPU: 10.961
Node # 50 CPU: 10.961
Node # 63 CPU: 10.961
Node # 60 CPU: 10.961 Node # 58 CPU: 10.961
Node # 51 CPU: 10.961 Node # 59 CPU: 10.961
Node # 48 CPU: 10.961
Node # 22 CPU: 10.961
Node # 23 CPU: 10.961
Node # 17 CPU: 10.961
Node # 29 CPU: 10.961
Node # 26 CPU: 10.961 Node # 18 CPU: 10.961 Node # 28 CPU: 10.961
Node # 25 CPU: 10.961
Node # 20 CPU: 10.961
Node # 27 CPU: 10.961
Node # 30 CPU: 10.961 Node # 19 CPU: 10.961 Node # 24 CPU: 10.961
Node # 31 CPU: 10.961
Node # 16 CPU: 10.961
Node # 46 CPU: 10.961
Node # 45 CPU: 10.961
Node # 32 CPU: 10.961
Total: 701.464
Reading of input data ............................ 282.823 (40.3190 %)
2D/3D coupling, vertical metrics ................. 0.391 ( 0.0558 %)
Omega vertical velocity .......................... 0.266 ( 0.0379 %)
Equation of state for seawater ................... 1.048 ( 0.1494 %)
Total: 284.529 40.5621
Message Passage: 2D halo exchanges ............... 4.276 ( 0.6095 %)
Message Passage: 3D halo exchanges ............... 1.492 ( 0.2127 %)
Message Passage: data broadcast .................. 382.823 (54.5748 %)
Message Passage: data reduction .................. 0.064 ( 0.0091 %)
Message Passage: data scattering.................. 219.459 (31.2858 %)
Total: 608.113 86.6920
All percentages are with respect to total time = 701.464
Analytical header files used:
REASON: No error
Yes, the problem was in varinfo.dat. This has been there since revision 383. There was a typo when defining the variable sand_north_. Please update and check the following
trac ticket for details. Thank you for reporting this problem.
I also noticed that the logical flag LtracerSrc is false for your sediment tracers. I don't know if this is what you intended. If you want to have point sources for a particular sediment tracer at the river locations, you need to activate its associated switch.
First, thank you very much~ I update the code and there are still some errors.
In the previous verison, there is no Ltracer option for mud or sand in the sediment.in file. The model is running ok. After updating to the latest version, the model runs well when the Ltracer option is F in sediment.in file. However, if I set the Ltracer on for the mud and sand in sediment.in file, errors come. The log file is as follow:
I have checked the focr file, and river_mud_01 and river_sand_01 are all existing.
Actually, I checked the adria example of ROMS, the Lstracer options of mud and sand in sediment_adria.in are all off. However, river sediments also exists in this example. So I am cofused about what you said above. What I want to do is to set sediment concerntration of the domain to be zeros and only to see how the river sediments are transported on the shelves.
Time is date
cat ${PSB_NODEFILE}
This job has allocated 1 nodes
Node # 0 (pid= 27008) is active.
Monday - January 11, 2010 - 2:10:23 PM
SVN Revision : 405:438M
Resolution, Grid 01: 0368x0440x030, Parallel Nodes: 1, Tiling: 001x001
to standard output.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
T LtracerSrc(01) Processing point sources/Sink on tracer 01: temp
T LtracerSrc(02) Processing point sources/Sink on tracer 02: salt
Tile partition information for Grid 01: 0368x0440x0030 tiling: 001x001
0 1 368 1 440 4857600
0 0.50 368.50 0.50 440.50 RHO-points
0 1.00 368.00 0.50 440.50 U-points
0 0.50 368.50 1.00 440.00 V-points
HaloSizeI(1) = 1137
HaloSizeJ(1) = 1353
TileSide(1) = 445
TileSize(1) = 165985
morph_fac
(nondim)
1 1.0000E+01
2 1.0000E+01
T LtracerSrc(03) Processing point sources/Sink on tracer 03: mud_01
T LtracerSrc(04) Processing point sources/Sink on tracer 04: sand_01
- free-surface
- salinity
GET_NGFLD - river runoff potential temperature, t = 15 00:00:00
(Min = 5.00000000E+00 Max = 5.00000000E+00)
GET_NGFLD - river runoff salinity, t = 15 00:00:00
in file: /dcfs2/users/leon/Documents/roms_examples/ecs22/ecs22-forc.nc
Node # 0 CPU: 9.132
Total: 9.132
Reading of input data ............................ 0.676 ( 7.4065 %)
2D/3D coupling, vertical metrics ................. 0.121 ( 1.3228 %)
Omega vertical velocity .......................... 0.087 ( 0.9535 %)
Equation of state for seawater ................... 0.766 ( 8.3927 %)
Total: 1.651 18.0756
Message Passage: 2D halo exchanges ............... 0.000 ( 0.0025 %)
Message Passage: 3D halo exchanges ............... 0.017 ( 0.1829 %)
Message Passage: data broadcast .................. 0.014 ( 0.1503 %)
Message Passage: data reduction .................. 0.000 ( 0.0003 %)
Message Passage: data scattering.................. 0.818 ( 8.9619 %)
Total: 0.849 9.2979
All percentages are with respect to total time = 9.132
REASON: No error
Yes, the same problem as before but now in the river metadata. I fixed the problem in sediment_var.h. I hope that this is the last one
Please check the following
![Embarassed :oops:](./images/smilies/icon_redface.gif)
