Hi all:
I run mpi roms in my SGI altix 450 computer. But the program stopped when finishing initialization and starting time-stepping. The following is the details of the screen output.It seems that the program stopped when creating output file. Would you please give me some instructions? By the way, the serial mode can run successfully, and i didn't change anything except something relating mpi.
Thank you very much!
Minimum X-grid spacing, DXmin = 7.01021364E-01 km
Maximum X-grid spacing, DXmax = 7.24317392E-01 km
Minimum Y-grid spacing, DYmin = 9.11444473E-01 km
Maximum Y-grid spacing, DYmax = 9.41733188E-01 km
Minimum Z-grid spacing, DZmin = 8.33333333E-01 m
Maximum Z-grid spacing, DZmax = 1.78640994E+01 m
Minimum barotropic Courant Number = 4.91146612E-02
Maximum barotropic Courant Number = 1.77549157E-01
Maximum Coriolis Courant Number = 1.14661208E-02
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 9.29494800E+04)
(Min = 0.00000000E+00 Max = 7.64930339E-01)
(Min = 1.44557053E-03 Max = 6.28226262E+00)
(Min = 0.00000000E+00 Max = 6.28316436E+00)
(Min = 0.00000000E+00 Max = 6.28314443E+00)
(Min = 0.00000000E+00 Max = 7.59266559E-01)
(Min = -1.39419820E-01 Max = 7.76747173E-02)
Maximum grid stiffness ratios: rx0 = 5.491274E-01 (Beckmann and Haidvogel)
rx1 = 4.147671E+00 (Haney)
Initial basin volumes: TotVolume = 8.1849428288E+11 m3
MinVolume = 5.3324640306E+05 m3
MaxVolume = 1.2146028193E+07 m3
Max/Min = 2.2777515467E+01
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00001440)
0 1 00:00:00 0.000000E+00 1.184360E+02 1.184360E+02 9.404629E+11
DEF_HIS - creating history file: ocean_his_0001.nc
rank 3 in job 14 altix450_42271 caused collective abort of all ranks
exit status of rank 3: killed by signal 9
rank 2 in job 14 altix450_42271 caused collective abort of all ranks
exit status of rank 2: killed by signal 9
rank 1 in job 14 altix450_42271 caused collective abort of all ranks
exit status of rank 1: killed by signal 11
run mpi version on SGI altix 450 computer
- Location: National Marine Environmental Mornitoring Center
Re: run mpi version on SGI altix 450 computer
I have solved this problem by defining INLINE_2DIO in the *.h file.
