I can not extract a bathymetry.
I decided to follow this path: https: / / www.myroms.org / wiki / index.php / easygrid
following this path I extract the coastline: https: / / www.myroms.org / wiki / index.php / seagrid
the coastline is ok!
I have to extract the bathymetry
or used 3 methods
1) read_srtm30plus.m
2) Smith, Sandwell [http://topex.ucsd.edu/WWW_html/mar_topo.html] [ftp://topex.ucsd.edu/pub/global_topo_1min/] with extract.me topo_12.1.img
3) etopo5 and matlab script
in all three methods have problems
1)>> [lon, lat, z] = read_srtm30plus([10 20], [40 46], 30.1);
url =
http://onearth.jpl.nasa.gov/wms.cgi?req ... us&bbox=10, 40,20,46 & SRS = EPSG: 4326 & TRANSPARENT = FALSE & width = 1200 & height = 720 & format = image / GeoTIFF & version = 1.1.1
?? Error using ==> imread at 293
Can not read URL
"http://onearth.jpl.nasa.gov/wms.cgi?req ... us&bbox=10, 40,20,46 & SRS = EPSG: 4326 & TRANSPARENT = FALSE & width = 1200 & height = 720 & format = image / GeoTIFF & version = 1.1.1 .
Error in ==> read_srtm30plus at 60
pix = imread (url, 'tif');
2)>> [image_data, vlat, vlon] = mygrid_sand ([38 42 12 17], 1)
iblat =
1934
itlat =
1778
iwlon =
360
ielon =
510
Reading in bathymetry data
?? Error using ==> fseek
Invalid file identifier. Use fopen to generate a valid file identifier.
Error in ==> mygrid_sand at 91
status = fseek (fid, offset, 'bof');
3) [lon, lat, h] = x_etopo5 ([12,17,38,42], etopo5);
Warning: Function ETOPO5 is obsolete and will be removed in the next release.
Use eTopo instead.
> In etopo5 at 62
?? Error using ==> eTopo> getFileFromDir at 252
Directory "/ home / joe / Bati / matlab / bathymetry" does not contain eTopo date.
Error in ==> eTopo> parseInputs at 95
file = getFileFromDir (datadir);
Error in ==> eTopo at 67
[file, samplefactor, latlim, lonlim, readFcn] = parseInputs (varargin {:});
Error in ==> etopo5 at 66
[Z, refvec] = eTopo (varargin {:});
Use MATLAB 7.6.0 R2008a
I hope in your help
extract bathymetry
- Location: second institution of oceanography,state oceanic administration China
Re: extract bathymetry
[quote][1)>> [lon, lat, z] = read_srtm30plus([10 20], [40 46], 30.1);
/quote]
hello mistral,I use the first method to extract the bathymetry ,and I have the proble the same with you.
Have you resolved it?
help!
/quote]
help!
