About the psi-variable
eivinds
#1 Unread post by eivinds »
I am setting up the model with grid from file. My collegue assisted me in this, and he said that I could simply delete all variables related to psi in the input netcdf files, i.e x_psi, mask_psi etc. This way the model would not compute the psi values, resulting in faster run time and less model output. In the forum topic "Sediment for beginner))" Kate says that psi is a variable "..from a previous generation of the model." which support the view that psi is not a variable I should need to take into consideration.
When I try to run the model, I get the error:
"GET_GRID - unable to find grid variable: mask_psi in grid NetCDF file: vanm_grid.nc"
When looking in the file get_grid.F I see that the routine indeed looks for all the psi-related variables that I thought were unimportant. I suppose what I wonder is wether there is a way to avoid performing the psi-computations, and if so, how? If not its not a problem for me to simply put the psi-variables back in.
Regards,
Eivind
Re: About the psi-variable
For the most part, ROMS reads in what it needs and ignores the rest. It does use the mask at psi points, but insists on recomputing it from the rho mask, so it probably doesn't have to read it from the grid file first.
Psi is indeed not a ROMS variable, but there are a few computations that take place on what we call the "psi points".
