blowing up when plus tide
leon
#1 Unread post by leon »
I got a problem.
When I didn't plus tide, my model can run for a long time. But when I plus tide, it just blows up after a few time steps. Why? I add my *.h file with 'UV_TIDES, SSH_TIDES, ADD_FSOBC, ADD_M2OBC'. Am I right? What's the most possible problem? Any suggestion is ok. Thank you in advance.
Re: blowing up when plus tide
First, try a shorter timestep. Second, find out if it is blowing up due to total depth going negative. Third, are you using quadratic bottom drag? That could cause it to blow up too. I wrote to the roms blog about the trouble with tides: https://www.myroms.org/blog/?p=165
