Open Boundary Problem
bibi951
#1 Unread post by bibi951 »
Hi,all
I do a simulation using Hycom's Global simulation product for my open boundary.
I have checked the Open Boundary section field after interpolating them to Roms's s- coordinate.It seems fine although not exactly the same.
But I have some doubt about the field consistent.I just use the same points for all the variables(ssh,t,s,u,v),and after interpolation to s-coordinate, I just integrate u,v to get ubar vbar.Is there something will cause trouble?
Besides, I didn't modify the field on land,so ssh may to very large.It doesn't matter,right?
I prepare the data in the order of ROMS index ,which means in horrizotal from 1 to xi(eta).and in vertical from 1 to L-layers.
I use only the open boundary forcing.
However,the result goes quite wrong.West Boundary Current is reversed.Here is the picture after 80 days or so.
http://photo.xiaonei.com/getphoto.do?id ... 1894331121
http://photo.xiaonei.com/getphoto.do?id ... 1894333244
I use OBC :fschapman m2flather m3radiation Tradiation.
Any idea?
Thanks in advance.
Re: Open Boundary Problem
Hi Bibi,
I can't see your images, not having a login wherever that is.
Is your grid aligned with north-south-east-west? How about Hycom's grid? You may have to rotate the boundary u,v so that they are lined up with the ROMS grid.
bibi951
#3 Unread post by bibi951 »
Thank you,Kate.
You are always so kind.
Sorry,I didn't realize the login problem.
Here is the new address
http://photo.blog.sina.com.cn/photo/46f ... 32f1f7e4be
http://photo.blog.sina.com.cn/photo/46f ... f81612#pic
and I will send you an email for pictures.
My grid is North-South-West-East(the angle is zero),hycom's product is along the longitutde and latitude.That should not be the problem.
Besides,I want to make sure this is right.Forgive me.The caculation is too expensive, so I don't want to do some tests blindly.
How about the velocity and ssh consistency? and the same line of data from hycom to provide Open Boundary data is OK?
Will the large value of ssh on land will cause trouble?
Thanks for any suggestion.
Your currents are more likely being generated by the initial conditions than the boundary conditions - you mean the ones up against the land, right? I don't think hycom is the wrong way to go for initial conditions, but it and roms need to agree on what density is at what depth. If you need to extrapolate into the land (where hycom has land), do that on level z surfaces before doing the vertical interpolations.
Large zeta in the land won't affect anything.
bibi951
#5 Unread post by bibi951 »
Sorry, I didn't mention my initial condition is taken from SODA-1.4.2 and is climatology yearly mean.Both my soda and hycom data are on z-level surfaces.
Maybe the initial condition is the problem?
I will show pictures of the process from intial condition to the day 87;and the time varing East open boundary here
(title divided by 4 is the day number):Click the photo for the next one..
ssh:
http://photo.blog.sina.com.cn/photo/46f ... 49351ec970
velocity:
http://photo.blog.sina.com.cn/photo/46f ... 4931abbab5
boudary:
http://photo.blog.sina.com.cn/photo/46f ... eef918#pic
Here is the simulation gif pictures
http://rapidshare.com/files/258634548/zeta.gif
http://rapidshare.com/files/258630796/velocity.gif
I'm sorry it need 45 second waiting.Need your patience..
The vertical averege velocity(80days simulation) on the path of Kurishio is reversed.and I can't find the ubar pointing out the east boundary at any time.
I checked the Open boundary field after interpolation at some time,they seem OK comparing with the hycom's section(at least the feature is still there).
#6 Unread post by kate »
So your initial currents look good, but then they go chaotic and then settle going the wrong way? Internal problems like that are still not due to boundary conditions, but something else. There's something up with your model physics. What terms in the equations do you have on? What is your equation of state?
bibi951
#7 Unread post by bibi951 »
Thank you for teaching me how to diagnose where the problem may be,Kate.
I really appreciate it.
I should have shown the CPP flags before.
This is what I use
NANHAI NANHAI SHUZHISHIYAN
MASKING Land/Sea masking.
MIX_ISO_TS Mixing of tracers along isopycnal surfaces.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
SALINITY Using salinity.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
UV_C2ADVECTION Second-order centered differences advection of momentum.
I set btflux,smflux,stflux to zero.
Anything wrong here?
#8 Unread post by kate »
I don't see anything off hand. Have you looked at the coriolis parameter f in the grid file? Is it of the correct sign?
bibi951
#9 Unread post by bibi951 »
Yes,parameter f is correct and it varies along latitude.
Maybe I should try another initial condition since it may conflict someway with the open boundary information,consindering they come from different model and differ in time.
I will report the result after this is done.
#10 Unread post by kate »
How about turning on DIAGNOSTICS? You could then see if there's something terribly wrong with coriolis balancing pressure gradients.
susonic
#11 Unread post by susonic »
How often is your BC value given in your domain?
Have you ever changed the BC code from RADIATION to CLAMPED for M3 and T ?
From my experience, CLAMPED BC code might be more promising.
-Peter
bibi951
#12 Unread post by bibi951 »
Thanks for your suggustion.
My OB data is given daily to the interior domain.
I have not tried Clamped OBC yet,maybe that would help.
I am also thinking about nudging ,would 20 days of nudging time scale be OK for outflow , 0.5 day for inflow ?
bibi951
#13 Unread post by bibi951 »
Hello,everyone.
I tried another initial condition derived from hycom, and used nudging mentioned above (20 days of nudging time scale for outflow , 0.5 day for inflow).It partly works(I don't know which contributes more to this, intialization or nudging),however not good enough.
ssh and barotropic velocity
http://photo.blog.sina.com.cn/u/1190472905
The title plus 90 is the day number of my simulation.(ie. 45+90=135 which means this is the 135 day's simulation.)Click the photo to see more clearly.
The kuroshio doesn't show up clearly, the surface elevation doesn't look good with too much strong holes(low ssh).So the velocity field is quite a mess.I also think Kuroshio water intrusion through luzon strait is too strong,and the Kuroshio(if is can be called Kuroshio) is too northward.
I wonder is there any model configuration I can do to change this simulation better?
Here is the standard output:
0.0000E+00 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
0.0000E+00 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
for tracer 02: salt
for turbulent energy.
2.5000E-03 rdrg2 Quadratic bottom drag coefficient.
7.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E-01 theta_b S-coordinate bottom control parameter.
20050101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
1.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
1.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
1.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
2.0000E+01 obcfac Factor between passive and active
Thanks for any suggustion.
prakash22
#14 Unread post by prakash22 »
hi bibi
Could you tell me which tool are you using to create boundary and initial file using hycom global data. if it is possible then could you help me.
That will very helpful.
thanks in Advance
-Prakash
#15 Unread post by kate »
There are Python tools to do this in pyroms. I'm sure others have Matlab tools. Did you have a preference?
prakash22
#16 Unread post by prakash22 »
No, I don't have any preference. So Could you tell me about Matlab tool or can you send me the link of tool.
#17 Unread post by kate »
For the matlab, start here.
prakash22
#18 Unread post by prakash22 »
Hi kate
I install pyroms,pyroms_tool successfully but I am not able to create boundary file.
I have few doubt like
when I ran make_bdry_file.py then I am getting error like _iso , _average file is not found. I copied these file to current directory now I am getting error like
File "make_bdry_file.py", line 41, in <module>
src_grd = pyroms_toolbox.Grid_HYCOM.get_nc_Grid_HYCOM(src_grd_file)
File "/usr/local/python_tool//lib/python2.7/site-packages/pyroms_toolbox/Grid_HYCOM/get_nc_Grid_HYCOM.py", line 16, in get_nc_Grid_HYCOM
File "netCDF4/_netCDF4.pyx", line 1795, in netCDF4._netCDF4.Dataset.__init__ (netCDF4/_netCDF4.c:11938)
RuntimeError: No such file or directory
another doubt is that, Is these tools need Hycom global grid and ROMS grid information
if is it so then from where I can get hycom global grid data ( if it is possible send me the link of these data)
please help me
thanks in Advance
-ravi
#19 Unread post by kate »
Oops, I added the python script for downloading the HYCOM grid to the Arctic_HYCOM example. You need to have both grids, you need to have the PYROMS_GRIDID_FILE environment variable set to point to the gridid.txt file and you need to edit it for your grid. Then you should be able to run make_remap_weights_file if scrip.so was installed properly. Once that is done, you can move on to making the boundary files.
prakash22
#20 Unread post by prakash22 »
But in place of hycom global grid which data I will provide
#21 Unread post by kate »
Ah, are you downloading a subset of the HYCOM global grid? For the Arctic example I downloaded a subset covering the north pole. I also have an example covering a non-polar subset which I can add as another example. OK, done.
