problem with mpirun...
mashinde
Location: Indian Institute of Tropical Meteorology, Pune, INDIA
#1 Unread post by mashinde »
i run oceanM file with mpirun -np 4 ./oceanM ocean_upwelling.in, which gives me following error
$ mpirun -np 4 ./oceanM ROMS/External/ocean_upwelling.in
[ubuntu:15999] *** Process received signal ***
[ubuntu:15999] Signal: Segmentation fault (11)
[ubuntu:15999] Signal code: Address not mapped (1)
[ubuntu:15999] Failing at address: 0x60
[ubuntu:16000] *** Process received signal ***
[ubuntu:16000] Signal: Segmentation fault (11)
[ubuntu:16000] Signal code: Address not mapped (1)
[ubuntu:16000] Failing at address: 0x60
[ubuntu:16000] [ 0] /lib/libpthread.so.0 [0x7ff6b01810f0]
[ubuntu:16000] [ 1] /usr/lib/libhdf5-1.6.6.so.0(MPIR_ToPointer+0xb7) [0x7ff6b2001ff7]
[ubuntu:16000] [ 2] /usr/lib/libhdf5-1.6.6.so.0(PMPI_Comm_rank+0xe) [0x7ff6b200356e]
[ubuntu:16000] [ 3] /usr/local/lib/libmpi_f77.so.0(mpi_comm_rank_+0x26) [0x7ff6b18bac26]
[ubuntu:16000] [ 4] ./oceanM(MAIN__+0x49) [0x41e429]
[ubuntu:16000] [ 5] ./oceanM(main+0x2c) [0x5cf2ac]
[ubuntu:16000] [ 6] /lib/libc.so.6(__libc_start_main+0xe6) [0x7ff6afe1e466]
[ubuntu:16000] [ 7] ./oceanM [0x41e319]
[ubuntu:16000] *** End of error message ***
[ubuntu:16001] *** Process received signal ***
[ubuntu:16001] Signal: Segmentation fault (11)
[ubuntu:16001] Signal code: Address not mapped (1)
[ubuntu:16001] Failing at address: 0x60
[ubuntu:16001] [ 0] /lib/libpthread.so.0 [0x7ff201e420f0]
[ubuntu:16001] [ 1] /usr/lib/libhdf5-1.6.6.so.0(MPIR_ToPointer+0xb7) [0x7ff203cc2ff7]
[ubuntu:16001] [ 2] /usr/lib/libhdf5-1.6.6.so.0(PMPI_Comm_rank+0xe) [0x7ff203cc456e]
[ubuntu:16001] [ 3] /usr/local/lib/libmpi_f77.so.0(mpi_comm_rank_+0x26) [0x7ff20357bc26]
[ubuntu:16001] [ 4] ./oceanM(MAIN__+0x49) [0x41e429]
[ubuntu:16001] [ 5] ./oceanM(main+0x2c) [0x5cf2ac]
[ubuntu:16001] [ 6] /lib/libc.so.6(__libc_start_main+0xe6) [0x7ff201adf466]
[ubuntu:16001] [ 7] ./oceanM [0x41e319]
[ubuntu:16001] *** End of error message ***
mpirun noticed that process rank 3 with PID 16001 on node ubuntu exited on signal 11 (Segmentation fault).
please help to solve this problem...
Mahesh
Re: problem with mpirun...
It looks like libhdf5 is unhappy. Did you ask ROMS for parallel I/O? Did you compile hdf5 and netcdf4 for parallel I/O? Have you run any parallel tests of the hdf and netcdf libraries? I assume they come with some tests. Does anything work in serial mode?
robertson
#3 Unread post by robertson »
That HDF5 version (1.6.6) is much to old to be used with NetCDF-4. Perhaps you have a new version in a different location?
feroda
#4 Unread post by feroda »
I probably met the same problem:
On my laptop with Ubuntu system and 2 CPUs, I installed the MPICH2.
When the successfully compiled oceanM was executed following:
mpiexec -np 2 ./oceanM ocean_*.in
Things are going well, but the process was killed at the end:
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00036000)
(Rec=0001, Index=2, File: SCS-forc-aug-nowind.nc)
(Min = 3.40529103E-05 Max = 6.08471248E-05)
(Rec=0001, Index=1, File: SCS-bry-SODA-aug.nc)
(Min = 3.07866417E-01 Max = 1.10178467E+00)
(Min = 4.27124822E-01 Max = 6.95942208E-01)
(Min = -3.83395787E-01 Max = 3.03214096E-01)
(Min = -7.59140116E-02 Max = 1.21399133E-01)
(Min = -2.05323426E-01 Max = 1.01100750E-01)
(Min = -2.62352232E-01 Max = 1.39583157E-01)
(Min = -3.82833226E-01 Max = 6.29373687E-01)
(Min = -1.23403633E-01 Max = 1.23196424E-01)
(Min = -4.76592953E-01 Max = 1.10937390E-01)
(Min = -9.31719153E-01 Max = 2.86592785E-01)
(Min = 1.19765575E+00 Max = 3.00410382E+01)
(Min = 3.25857851E+01 Max = 3.50023552E+01)
(Min = 1.22471450E+00 Max = 3.15486310E+01)
(Min = 3.18748405E+01 Max = 3.48537465E+01)
0 0 00:00:00 4.443919E-16 2.133980E+04 2.133980E+04 1.141677E+16
rank 1 in job 9 tiger-laptop_47103 caused collective abort of all ranks
exit status of rank 1: killed by signal
9
Then, I tried the serial mode:
./oceanS < ocean_*.in
here came the errors at the beginning of the executing process:
(File: SCS-init-WOA-aug.nc, Rec=0001, Index=1)
- free-surface
Segmentation fault
tiger@tiger-laptop:~/work/SCS$
In my mind, those may due to the memory limitation.
Anyone has invaluable comment on that or know how to furthest release and make use of the memory of my laptop(with 2GB memory)?
Thanks a lot!
mashinde
#5 Unread post by mashinde »
i installed new HDF5 and Netcdf4 I also compile it in parallel I/O mode. In serial it work fine. Also some test example with mpich2 runs okay.
now i am getting the following error.
$mpirun -l -n 4 ./oceanM ROMS/External/ocean_upwelling.in
rank 3 in job 18 ubuntu_50363 caused collective abort of all ranks
exit status of rank 3: killed by signal 11
rank 2 in job 18 ubuntu_50363 caused collective abort of all ranks
exit status of rank 2: killed by signal 11
rank 0 in job 18 ubuntu_50363 caused collective abort of all ranks
exit status of rank 0: killed by signal 9
please help.
