I just use ROMS for my own application, But it blows up when just runs several steps. When I check the history file and restart file, I find the value of zeta as fllows(only a part of zeta values):
zeta =
_, _, _, _, _, _, _, _, 0, 0.256860918381414, 0.254291715215559,
0.248481492553035, 0.241916377206696, 0.238508802068345,
0.240013291092903, 0.242697349779395, 0.245499704716296,
0.246197729040227, 0.244363392702145, 0.242089363878746,
0.243065977320007, 0.245866070522518, 0.253267301360104,
0.264162375925189, 0.273990961133747, 0.281946084452367,
0.288118486580631, 0.29082553475344, 0.293726281300007, 0.29471074459092,
0.308970820580904, _, _, _, _, _, _, _, _, _, _, _, _, 0.510823608001006,
It's obveous that some value of zeta are unwrriten into the file. I mean they are maybe uncaculate, But the "_," will be treated as 9.969210E+36 for the value of zeta in the caculation. So I think that's the problem of "blow up". But I don't known how to fix the problem. Wish someone can help me or give me some suggetion. Any information useful is OK. Thank you in advance!
More information:
Resolution, Grid 01: 0128x0188x020, Parallel Nodes: 16, Tiling: 004x004
86400 ntimes Number of timesteps for 3-D equations.
3600.000 dt Timestep size (s) for 3-D equations.
50 ndtfast Number of timesteps for 2-D equations between
600 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
360 nHIS Number of timesteps between the writing fields
into history file.
time-averaged data.
720 nAVG Number of timesteps between the writing of
8640 ndefAVG Number of timesteps between creation of new
time-averaged file.
2.0000E+01 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
2.0000E+01 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
4.0000E+01 visc2 Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
1 lmd_Jwt Jerlov water type.
5.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E-01 theta_b S-coordinate bottom control parameter.
3.000 Tcline S-coordinate surface/bottom layer width (m) used
-1.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
1.0000E+01 obcfac Factor between passive and active
T Hout(idTsur) Write out surface net heat flux.
T Hout(idTsur) Write out surface net salt flux.
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idTdif) Write out vertical T-diffusion coefficient.
T Hout(idHsbl) Write out depth of surface boundary layer.
Output Restart File: /dcfs2/users/leon/Documents/roms_examples/ecs/output/ecs_rst.nc
Output History File: /dcfs2/users/leon/Documents/roms_examples/ecs/output/ecs_his.nc
Prefix for Averages Files: /dcfs2/users/leon/Documents/roms_examples/ecs/output/ecs_avg
Input Grid File: /dcfs2/users/leon/Documents/roms_examples/ecs/input/ecs-grid.nc
Input Nonlinear Initial File: /dcfs2/users/leon/Documents/roms_examples/ecs/input/ecs-init.nc
Input Forcing File 01: /dcfs2/users/leon/Documents/roms_examples/ecs/input/ecs-forc.nc
Input Climatology File: /dcfs2/users/leon/Documents/roms_examples/ecs/input/ecs-clim.nc
Input Boundary File: /dcfs2/users/leon/Documents/roms_examples/ecs/input/ecs-bry.nc
Tile partition information for Grid 01: 0128x0188x0020 tiling: 004x004
tile Istr Iend Jstr Jend Npts
0 1 32 1 47 30080
1 33 64 1 47 30080
2 65 96 1 47 30080
3 97 128 1 47 30080
4 1 32 48 94 30080
5 33 64 48 94 30080
6 65 96 48 94 30080
7 97 128 48 94 30080
8 1 32 95 141 30080
9 33 64 95 141 30080
10 65 96 95 141 30080
11 97 128 95 141 30080
12 1 32 142 188 30080
13 33 64 142 188 30080
14 65 96 142 188 30080
15 97 128 142 188 30080
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 32.50 0.50 47.50 RHO-points
1 32.50 64.50 0.50 47.50 RHO-points
2 64.50 96.50 0.50 47.50 RHO-points
3 96.50 128.50 0.50 47.50 RHO-points
4 0.50 32.50 47.50 94.50 RHO-points
5 32.50 64.50 47.50 94.50 RHO-points
6 64.50 96.50 47.50 94.50 RHO-points
7 96.50 128.50 47.50 94.50 RHO-points
8 0.50 32.50 94.50 141.50 RHO-points
9 32.50 64.50 94.50 141.50 RHO-points
10 64.50 96.50 94.50 141.50 RHO-points
11 96.50 128.50 94.50 141.50 RHO-points
12 0.50 32.50 141.50 188.50 RHO-points
13 32.50 64.50 141.50 188.50 RHO-points
14 64.50 96.50 141.50 188.50 RHO-points
15 96.50 128.50 141.50 188.50 RHO-points
0 1.00 32.50 0.50 47.50 U-points
1 32.50 64.50 0.50 47.50 U-points
2 64.50 96.50 0.50 47.50 U-points
3 96.50 128.00 0.50 47.50 U-points
4 1.00 32.50 47.50 94.50 U-points
5 32.50 64.50 47.50 94.50 U-points
6 64.50 96.50 47.50 94.50 U-points
7 96.50 128.00 47.50 94.50 U-points
8 1.00 32.50 94.50 141.50 U-points
9 32.50 64.50 94.50 141.50 U-points
10 64.50 96.50 94.50 141.50 U-points
11 96.50 128.00 94.50 141.50 U-points
12 1.00 32.50 141.50 188.50 U-points
13 32.50 64.50 141.50 188.50 U-points
14 64.50 96.50 141.50 188.50 U-points
15 96.50 128.00 141.50 188.50 U-points
0 0.50 32.50 1.00 47.50 V-points
1 32.50 64.50 1.00 47.50 V-points
2 64.50 96.50 1.00 47.50 V-points
3 96.50 128.50 1.00 47.50 V-points
4 0.50 32.50 47.50 94.50 V-points
5 32.50 64.50 47.50 94.50 V-points
6 64.50 96.50 47.50 94.50 V-points
7 96.50 128.50 47.50 94.50 V-points
8 0.50 32.50 94.50 141.50 V-points
9 32.50 64.50 94.50 141.50 V-points
10 64.50 96.50 94.50 141.50 V-points
11 96.50 128.50 94.50 141.50 V-points
12 0.50 32.50 141.50 188.00 V-points
13 32.50 64.50 141.50 188.00 V-points
14 64.50 96.50 141.50 188.00 V-points
15 96.50 128.50 141.50 188.00 V-points
HaloSizeI(1) = 88
HaloSizeJ(1) = 118
TileSide(1) = 53
TileSize(1) = 2014
ECS East China Sea
AVERAGES Writing out time-averaged fields.
AVERAGES_FLUXES Writing out time-averaged surface fluxes.
DIURNAL_SRFLUX Modulate shortwave radiation by the local diurnal cycle.
EAST_FSGRADIENT Eastern edge, free-surface, gradient condition.
EAST_M2NUDGING Eastern edge, 2D momentum, passive/active outflow/inflow.
EAST_M2RADIATION Eastern edge, 2D momentum, radiation condition.
EAST_M3NUDGING Eastern edge, 3D momentum, passive/active outflow/inflow.
EAST_M3RADIATION Eastern edge, 3D momentum, radiation condition.
EAST_TNUDGING Eastern edge, tracers, passive/active outflow/inflow.
EAST_TRADIATION Eastern edge, tracers, radiation condition.
EAST_VOLCONS Eastern edge, enforce mass conservation.
LMD_CONVEC LMD convective mixing due to shear instability.
LMD_MIXING Large/McWilliams/Doney interior mixing.
LMD_NONLOCAL LMD convective nonlocal transport.
LMD_RIMIX LMD diffusivity due to shear instability.
LMD_SKPP KPP surface boundary layer mixing.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_VOLCONS Northern edge, enforce mass conservation.
NORTH_FSGRADIENT Northern edge, free-surface, gradient condition.
NORTH_M2NUDGING Northern edge, 2D momentum, passive/active outflow/inflow.
NORTH_M2RADIATION Northern edge, 2D momentum, radiation condition.
NORTH_M3NUDGING Northern edge, 3D momentum, passive/active outflow/inflow.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TNUDGING Northern edge, tracers, passive/active outflow/inflow.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
QCORRECTION Surface net heat flux correction.
SALINITY Using salinity.
SCORRECTION Surface salinity flux correction.
SRELAXATION Surface salinity relaxation as surface flux.
SOUTH_FSGRADIENT Southern edge, free-surface, gradient condition.
SOUTH_M2NUDGING Southern edge, 2D momentum, passive/active outflow/inflow.
SOUTH_M2RADIATION Southern edge, 2D momentum, radiation condition.
SOUTH_M3NUDGING Southern edge, 3D momentum, passive/active outflow/inflow.
SOUTH_M3RADIATION Southern edge, 3D momentum, radiation condition.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
SOUTH_TRADIATION Southern edge, tracers, radiation condition.
SOUTH_VOLCONS Southern edge, enforce mass conservation.
SPONGE Enhanced horizontal mixing in the sponge areas.
TCLIMATOLOGY Processing tracer climatology data.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
Vertical S-coordinate System:
20 0.0000000 0.0000000 0.000 0.000 0.000
19 -0.0500000 -0.0037835 -0.150 -13.143 -26.136
18 -0.1000000 -0.0087922 -0.300 -30.493 -60.686
17 -0.1500000 -0.0158197 -0.450 -54.776 -109.103
16 -0.2000000 -0.0260168 -0.600 -89.945 -179.289
15 -0.2500000 -0.0409944 -0.750 -141.529 -282.309
14 -0.3000000 -0.0628318 -0.900 -216.671 -432.442
13 -0.3500000 -0.0938098 -1.050 -323.203 -645.355
12 -0.4000000 -0.1356491 -1.200 -467.033 -932.866
11 -0.4500000 -0.1882840 -1.350 -647.937 -1294.524
10 -0.5000000 -0.2489214 -1.500 -856.322 -1711.145
9 -0.5500000 -0.3126323 -1.650 -1075.262 -2148.874
8 -0.6000000 -0.3746809 -1.800 -1288.494 -2575.188
7 -0.6500000 -0.4328656 -1.950 -1488.456 -2974.962
6 -0.7000000 -0.4881475 -2.100 -1678.450 -3354.800
5 -0.7500000 -0.5437741 -2.250 -1869.628 -3737.005
4 -0.8000000 -0.6041494 -2.400 -2077.113 -4151.825
3 -0.8500000 -0.6742046 -2.550 -2317.840 -4633.130
2 -0.9000000 -0.7593114 -2.700 -2610.255 -5217.811
1 -0.9500000 -0.8655258 -2.850 -2975.157 -5947.464
0 -1.0000000 -1.0000000 -3.000 -3437.106 -6871.211
Time Splitting Weights: ndtfast = 50 nfast = 69
1-0.0004563262418391 0.0200000000000000-0.0004563262418391 0.0200000000000000
2-0.0008555246732536 0.0200091265248368-0.0013118509150927 0.0400091265248368
3-0.0011975957891734 0.0200262370183019-0.0025094467042661 0.0600353635431387
4-0.0014825415143255 0.0200501889340853-0.0039919882185915 0.0800855524772240
5-0.0017103668530001 0.0200798397643718-0.0057023550715916 0.1001653922415958
6-0.0018810821987231 0.0201140471014318-0.0075834372703147 0.1202794393430276
7-0.0019947063038349 0.0201516687454063-0.0095781435741496 0.1404311080884340
8-0.0020512699089757 0.0201915628714830-0.0116294134831253 0.1606226709599169
9-0.0020508200324769 0.0202325882696625-0.0136802335156022 0.1808552592295795
10-0.0019934249196594 0.0202736046703121-0.0156736584352616 0.2011288638998915
11-0.0018791796520380 0.0203134731687052-0.0175528380872996 0.2214423370685968
12-0.0017082124164322 0.0203510567617460-0.0192610505037318 0.2417933938303428
13-0.0014806914339834 0.0203852210100746-0.0207417419377152 0.2621786148404174
14-0.0011968325490789 0.0204148348387543-0.0219385744867941 0.2825934496791717
15-0.0008569074781817 0.0204387714897359-0.0227954819649758 0.3030322211689075
16-0.0004612527185669 0.0204559096392995-0.0232567346835427 0.3234881308082070
17-0.0000102791169649 0.0204651346936709-0.0232670138005077 0.3439532655018779
18 0.0004955179018893 0.0204653402760102-0.0227714958986183 0.3644186057778880
19 0.0010555474468010 0.0204554299179724-0.0217159484518173 0.3848740356958604
20 0.0016691116117526 0.0204343189690364-0.0200468368400647 0.4053083546648968
21 0.0023353932676362 0.0204009367368013-0.0177114435724285 0.4257092914016981
22 0.0030534431940779 0.0203542288714486-0.0146580003783505 0.4460635202731467
23 0.0038221665513568 0.0202931600075670-0.0108358338269937 0.4663566802807137
24 0.0046403086924171 0.0202167166765399-0.0061955251345765 0.4865733969572536
25 0.0055064403149742 0.0201239105026915-0.0006890848196024 0.5066973074599451
26 0.0064189419537136 0.0200137816963921 0.0057298571341112 0.5267110891563371
27 0.0073759878125848 0.0198854028573178 0.0131058449466960 0.5465964920136549
28 0.0083755289371871 0.0197378831010661 0.0214813738838831 0.5663343751147210
29 0.0094152757272501 0.0195703725223223 0.0308966496111332 0.5859047476370433
30 0.0104926797892080 0.0193820670077773 0.0413893294003412 0.6052868146448206
31 0.0116049151288660 0.0191722134119932 0.0529942445292072 0.6244590280568137
32 0.0127488586841624 0.0189401151094159 0.0657431032133696 0.6433991431662296
33 0.0139210701980223 0.0186851379357326 0.0796641734113919 0.6620842811019622
34 0.0151177714313064 0.0184067165317722 0.0947819448426983 0.6804909976337343
35 0.0163348247158524 0.0181043611031460 0.1111167695585507 0.6985953587368804
36 0.0175677108476106 0.0177776646088290 0.1286844804061612 0.7163730233457094
37 0.0188115063198728 0.0174263103918768 0.1474959867260340 0.7337993337375862
38 0.0200608598965948 0.0170500802654793 0.1675568466226288 0.7508494140030655
39 0.0213099685258127 0.0166488630675474 0.1888668151484416 0.7674982770706129
40 0.0225525525931525 0.0162226636970312 0.2114193677415941 0.7837209407676441
41 0.0237818305154335 0.0157716126451681 0.2352011982570276 0.7994925534128122
42 0.0249904926743652 0.0152959760348595 0.2601916909313928 0.8147885294476717
43 0.0261706746903379 0.0147961661813722 0.2863623656217307 0.8295846956290438
44 0.0273139300363068 0.0142727526875654 0.3136762956580375 0.8438574483166091
45 0.0284112019917697 0.0137264740868393 0.3420874976498072 0.8575839224034484
46 0.0294527949368383 0.0131582500470039 0.3715402925866456 0.8707421724504523
47 0.0304283449864031 0.0125691941482671 0.4019686375730487 0.8833113665987193
48 0.0313267899643920 0.0119606272485390 0.4332954275374407 0.8952719938472583
49 0.0321363387181221 0.0113340914492512 0.4654317662555627 0.9066060852965095
50 0.0328444397727456 0.0106913646748887 0.4982762060283084 0.9172974499713983
51 0.0334377493257894 0.0100344758794338 0.5317139553540977 0.9273319258508321
52 0.0339020985817871 0.0093657208929180 0.5656160539358848 0.9366976467437502
53 0.0342224604270064 0.0086876789212823 0.5998385143628912 0.9453853256650325
54 0.0343829154442684 0.0080032297127422 0.6342214298071596 0.9533885553777747
55 0.0343666172678620 0.0073155714038568 0.6685880470750215 0.9607041267816315
56 0.0341557572785502 0.0066282390584996 0.7027438043535718 0.9673323658401310
57 0.0337315286386720 0.0059451239129286 0.7364753329922438 0.9732774897530596
58 0.0330740896673358 0.0052704933401551 0.7695494226595796 0.9785479830932148
59 0.0321625265557082 0.0046090115468084 0.8017119492152878 0.9831569946400232
60 0.0309748154223953 0.0039657610156942 0.8326867646376830 0.9871227556557174
61 0.0294877837089178 0.0033462647072463 0.8621745483466008 0.9904690203629637
62 0.0276770709152801 0.0027565090330680 0.8898516192618808 0.9932255293960317
63 0.0255170886756324 0.0022029676147624 0.9153687079375131 0.9954284970107941
64 0.0229809801740268 0.0016926258412497 0.9383496881115398 0.9971211228520438
65 0.0200405789002670 0.0012330062377692 0.9583902670118067 0.9983541290898130
66 0.0166663667458513 0.0008321946597639 0.9750566337576579 0.9991863237495768
67 0.0128274314400094 0.0004988673248468 0.9878840651976674 0.9996851910744237
68 0.0084914233258330 0.0002423186960466 0.9963754885235003 0.9999275097704703
69 0.0036245114764992 0.0000724902295300 0.9999999999999996 1.0000000000000000
ndtfast, nfast = 50 69 nfast/ndtfast = 1.38000
1.000000000000 1.033396903681 0.516698451840 1.000000000000 1.000000000000
Power filter parameters, Fgamma, gamma = 0.28400 0.22720
Minimum X-grid spacing, DXmin = 9.04304958E+00 km
Maximum X-grid spacing, DXmax = 1.09354054E+01 km
Minimum Y-grid spacing, DYmin = 8.96827502E+00 km
Maximum Y-grid spacing, DYmax = 1.08449847E+01 km
Minimum Z-grid spacing, DZmin = 1.50000000E-01 m
Maximum Z-grid spacing, DZmax = 9.23747438E+02 m
Minimum barotropic Courant Number = 5.39466551E-02
Maximum barotropic Courant Number = 2.43502746E+00
Maximum Coriolis Courant Number = 3.44073451E-01
NLM: GET_STATE - Read state initial conditions, t = 15 00:00:00
(File: ecs-init.nc, Rec=0001, Index=1)
- free-surface
(Min = -1.03900039E+00 Max = 4.24623102E-01)
(Min = -2.48144001E-01 Max = 2.25646660E-01)
(Min = -3.05982500E-01 Max = 1.76929355E-01)
- u-momentum component
(Min = -5.14225662E-01 Max = 4.19940740E-01)
- v-momentum component
(Min = -5.95250189E-01 Max = 4.60865140E-01)
- potential temperature
(Min = 1.21935844E-01 Max = 2.43009834E+01)
- salinity
(Min = 2.88827286E+01 Max = 3.49072151E+01)
GET_2DFLD - surface u-momentum stress, t = 15 00:00:00
(Rec=0001, Index=1, File: ecs-forc.nc)
(Min = -9.55872877E-05 Max = 8.67718256E-05)
GET_2DFLD - surface v-momentum stress, t = 15 00:00:00
(Min = -1.70217654E-04 Max = -5.20200284E-05)
GET_2DFLD - solar shortwave radiation flux, t = 15 00:00:00
(Min = 2.67830187E-05 Max = 4.39091744E-05)
GET_2DFLD - surface net heat flux, t = 15 00:00:00
(Min = -1.10588018E-04 Max = -2.01264782E-05)
GET_2DFLD - sea surface temperature climatology, t = 15 00:00:00
(Min = 2.61116224E+00 Max = 2.43009842E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 15 00:00:00
(Min = -1.83709200E-05 Max = -8.45130399E-06)
GET_2DFLD - sea surface salinity climatology, t = 15 00:00:00
(Min = 2.89088797E+01 Max = 3.48982156E+01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 15 00:00:00
(Rec=0001, Index=2, File: ecs-bry.nc)
(Min = -6.78813930E-02 Max = 1.39036095E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 15 00:00:00
(Min = -1.16295470E-01 Max = 3.75634752E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 15 00:00:00
(Min = -2.48136400E-01 Max = 1.00757690E-01)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -2.13953312E-01 Max = 1.04379732E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 15 00:00:00
(Min = -2.86243012E-02 Max = 1.30605154E-02)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 15 00:00:00
(Min = -3.58262522E-02 Max = 3.89263887E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 15 00:00:00
(Min = -1.57907076E-01 Max = 2.27884399E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 15 00:00:00
(Min = -2.03974092E-01 Max = 8.60740532E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 15 00:00:00
(Min = -5.14225647E-01 Max = 2.14896525E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 15 00:00:00
(Min = -4.41885832E-01 Max = 3.04669367E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 15 00:00:00
(Min = -4.07267814E-02 Max = 6.54127802E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 15 00:00:00
(Min = -7.03160290E-02 Max = 7.79320904E-02)
GET_NGFLD - temperature eastern boundary condition, t = 15 00:00:00
(Min = 1.25825964E-01 Max = 2.31046022E+01)
GET_NGFLD - salinity eastern boundary condition, t = 15 00:00:00
(Min = 3.39027342E+01 Max = 3.49070811E+01)
GET_NGFLD - temperature southern boundary condition, t = 15 00:00:00
(Min = 1.56173820E+00 Max = 2.43009842E+01)
GET_NGFLD - salinity southern boundary condition, t = 15 00:00:00
(Min = 3.41662610E+01 Max = 3.49068738E+01)
GET_NGFLD - temperature northern boundary condition, t = 15 00:00:00
(Min = 1.21935847E-01 Max = 5.86545917E+00)
GET_NGFLD - salinity northern boundary condition, t = 15 00:00:00
(Min = 2.88827286E+01 Max = 3.41449572E+01)
GET_3DFLD - potential temperature climatology, t = 15 00:00:00
(Rec=0001, Index=1, File: ecs-clim.nc)
(Min = 1.21935847E-01 Max = 2.43009842E+01)
GET_3DFLD - salinity climatology, t = 15 00:00:00
(Min = 2.88827286E+01 Max = 3.49072150E+01)
Maximum grid stiffness ratios: rx0 = 3.073662E-01 (Beckmann and Haidvogel)
rx1 = 5.872313E+00 (Haney)
Initial basin volumes: TotVolume = 1.01955771531188E+15 m3
MinVolume = 1.22765758381738E+07 m3
MaxVolume = 1.08882424887833E+11 m3
Max/Min = 8.86912004805646E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000361 - 00086400)
GET_2DFLD - surface u-momentum stress, t = 45 00:00:00
(Rec=0002, Index=2, File: ecs-forc.nc)
(Min = -8.64987824E-05 Max = 5.54186921E-05)
GET_2DFLD - surface v-momentum stress, t = 45 00:00:00
(Min = -1.45845268E-04 Max = -3.81793509E-05)
GET_2DFLD - solar shortwave radiation flux, t = 45 00:00:00
(Min = 3.56265866E-05 Max = 4.83486652E-05)
GET_2DFLD - surface net heat flux, t = 45 00:00:00
(Min = -8.51424856E-05 Max = -2.51220934E-06)
GET_2DFLD - sea surface temperature climatology, t = 45 00:00:00
(Min = 1.45024127E+00 Max = 2.41342802E+01)
GET_2DFLD - surface net heat flux sensitivity to SST, t = 45 00:00:00
(Min = -1.73132747E-05 Max = -6.22469509E-06)
GET_2DFLD - sea surface salinity climatology, t = 45 00:00:00
(Min = 2.82958405E+01 Max = 3.48577115E+01)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 45 00:00:00
(Rec=0002, Index=1, File: ecs-bry.nc)
(Min = -7.14497877E-02 Max = 1.78052583E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 45 00:00:00
(Min = -1.31554173E-01 Max = 3.55817396E-02)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 45 00:00:00
(Min = -2.39730665E-01 Max = 8.98597266E-02)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 45 00:00:00
(Min = -2.15809507E-01 Max = 1.78383946E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 45 00:00:00
(Min = -2.26529823E-02 Max = 8.77640229E-03)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 45 00:00:00
(Min = -3.11442407E-02 Max = 3.68661431E-02)
GET_NGFLD - 3D u-momentum eastern boundary condition, t = 45 00:00:00
(Min = -1.73840437E-01 Max = 2.74281391E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, t = 45 00:00:00
(Min = -2.18833608E-01 Max = 8.41800091E-02)
GET_NGFLD - 3D u-momentum southern boundary condition, t = 45 00:00:00
(Min = -4.75964421E-01 Max = 1.85201868E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, t = 45 00:00:00
(Min = -4.42814101E-01 Max = 3.76349827E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, t = 45 00:00:00
(Min = -3.33055608E-02 Max = 4.07769424E-02)
GET_NGFLD - 3D v-momentum northern boundary condition, t = 45 00:00:00
(Min = -6.59982058E-02 Max = 6.71205084E-02)
GET_NGFLD - temperature eastern boundary condition, t = 45 00:00:00
(Min = 1.27428484E-01 Max = 2.25594570E+01)
GET_NGFLD - salinity eastern boundary condition, t = 45 00:00:00
(Min = 3.39312326E+01 Max = 3.48577115E+01)
GET_NGFLD - temperature southern boundary condition, t = 45 00:00:00
(Min = 1.56141550E+00 Max = 2.41342802E+01)
GET_NGFLD - salinity southern boundary condition, t = 45 00:00:00
(Min = 3.41727622E+01 Max = 3.48815883E+01)
GET_NGFLD - temperature northern boundary condition, t = 45 00:00:00
(Min = 1.09079484E-01 Max = 4.94595786E+00)
GET_NGFLD - salinity northern boundary condition, t = 45 00:00:00
(Min = 2.82569830E+01 Max = 3.41322895E+01)
GET_3DFLD - potential temperature climatology, t = 45 00:00:00
(Rec=0002, Index=2, File: ecs-clim.nc)
(Min = 1.09079484E-01 Max = 2.41342802E+01)
GET_3DFLD - salinity climatology, t = 45 00:00:00
(Min = 2.82569830E+01 Max = 3.48815883E+01)
360 15 00:00:00 2.712312E-03 1.604108E+04 1.604108E+04 1.024024E+15
DEF_HIS - creating history file: /dcfs2/users/leon/Documents/roms_examples/ecs/output/ecs_his.nc
361 15 01:00:00 NaN NaN NaN NaN
WRT_RST - wrote re-start fields (Index=2,2) into time record = 0000001
Elapsed CPU time (seconds):
Node # 0 CPU: 3.366 Node # 1 CPU: 3.391 Node # 2 CPU: 3.391 Node # 7 CPU: 3.391 Node # 6 CPU: 3.391 Node # 4 CPU: 3.391 Node # 9 CPU: 3.391
Node # 3 CPU: 3.391 Node # 8 CPU: 3.391
Node # 10 CPU: 3.391 Node # 14 CPU: 3.391 Node # 5 CPU: 3.391 Node # 15 CPU: 3.391
Node # 11 CPU: 3.391
Node # 13 CPU: 3.391 Node # 12 CPU: 3.391
Total: 54.232
Initialization ................................... 21.751 (40.1080 %)
Reading of input data ............................ 17.701 (32.6398 %)
Processing of input data ......................... 0.171 ( 0.3150 %)
Processing of output time averaged data .......... 0.070 ( 0.1284 %)
Computation of vertical boundary conditions ...... 0.011 ( 0.0208 %)
Computation of global information integrals ...... 0.083 ( 0.1534 %)
Writing of output data ........................... 9.588 (17.6791 %)
Model 2D kernel .................................. 2.041 ( 3.7636 %)
2D/3D coupling, vertical metrics ................. 0.095 ( 0.1758 %)
Omega vertical velocity .......................... 0.073 ( 0.1348 %)
Equation of state for seawater ................... 0.382 ( 0.7049 %)
KPP vertical mixing parameterization ............. 0.329 ( 0.6066 %)
3D equations right-side terms .................... 0.108 ( 0.1999 %)
3D equations predictor step ...................... 0.276 ( 0.5088 %)
Pressure gradient ................................ 0.102 ( 0.1878 %)
Harmonic mixing of tracers, S-surfaces ........... 0.040 ( 0.0743 %)
Harmonic stress tensor, S-surfaces ............... 0.074 ( 0.1357 %)
Corrector time-step for 3D momentum .............. 0.177 ( 0.3267 %)
Corrector time-step for tracers .................. 0.169 ( 0.3124 %)
Total: 53.242 98.1756
Nonlinear model message Passage profile:
Message Passage: 2D halo exchanges ............... 0.676 ( 1.2459 %)
Message Passage: 3D halo exchanges ............... 0.224 ( 0.4127 %)
Message Passage: 4D halo exchanges ............... 0.057 ( 0.1043 %)
Message Passage: data broadcast .................. 28.565 (52.6719 %)
Message Passage: data reduction .................. 0.102 ( 0.1884 %)
Message Passage: data gathering .................. 3.128 ( 5.7680 %)
Message Passage: data scattering.................. 5.075 ( 9.3582 %)
Total: 37.826 69.7494
All percentages are with respect to total time = 54.232
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_hmixcoef.h
ROMS/Functionals/ana_srflux.h
ROMS/TOMS: DONE... Sunday - April 19, 2009 - 9:39:00 PM
how does roms caculate the value of zeta?
Re: how does roms caculate the value of zeta?
Hi Leon;
Your problem is probable related with your time step since your
Maximum barotropic Courant Number = 2.43502746E+00.
Try to reduce it to get Maximum barotropic Courant Number < 0 and satisfy the CFL criteria.
Have a look in arangos comments at viewtopic.php?f=1&t=850&hilit=cfl and m.hadfield's comments at viewtopic.php?f=14&t=1097&hilit=Maximum ... ant+Number
Cheers;
Carlos
Cheers;
Carlos
- m.hadfield
Achieving a maximum barotropic Courant number < 0 is maybe a little ambitious. You'll have better luck if you aim for a value < 1.ocecept wrote:Try to reduce it to get Maximum barotropic Courant Number < 0 and satisfy the CFL criteria.
![Wink :wink:](./images/smilies/icon_wink.gif)
Thanks all of you. I really appreciate it.And I want to known that whether the CFL condition for ROMS is dt<sqrt(((min(min(dx))^2)+(min(min(dy))^2)) / (9.8 * (min(min(h))^2))) or not.
leon
leon
I change the dt value, but it still bolws up. This is my first application, I hope someone can help me. Thank you in advance.
Information:
36.000 dt Timestep size (s) for 3-D equations.
to standard output.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 32 1 47 30080
1 33 64 1 47 30080
2 65 96 1 47 30080
3 97 128 1 47 30080
4 1 32 48 94 30080
5 33 64 48 94 30080
6 65 96 48 94 30080
8 1 32 95 141 30080
HaloSizeI(1) = 88
HaloSizeJ(1) = 118
TileSide(1) = 53
TileSize(1) = 2014
ECS East China Sea
Minimum barotropic Courant Number = 5.39466551E-04
Maximum barotropic Courant Number = 2.43502746E-02
Maximum Coriolis Courant Number = 3.44073451E-03
- free-surface
- salinity
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00036001 - 00086400)
36000 15 00:00:00 2.712312E-03 1.604108E+04 1.604108E+04 1.024024E+15
36001 15 00:00:36 2.690301E-03 1.604107E+04 1.604108E+04 1.024024E+15
36002 15 00:01:12 2.654853E-03 1.604107E+04 1.604108E+04 1.024024E+15
36003 15 00:01:48 2.631875E-03 1.604107E+04 1.604108E+04 1.024024E+15
36004 15 00:02:24 2.620680E-03 1.604108E+04 1.604108E+04 1.024024E+15
36005 15 00:03:00 2.614121E-03 1.604108E+04 1.604108E+04 1.024024E+15
36006 15 00:03:36 2.608847E-03 1.604109E+04 1.604109E+04 1.024024E+15
36007 15 00:04:12 2.605913E-03 1.604109E+04 1.604109E+04 1.024024E+15
36008 15 00:04:48 2.604339E-03 1.604113E+04 1.604113E+04 1.024024E+15
36009 15 00:05:24 2.597043E-03 1.604338E+04 1.604338E+04 1.024024E+15
Node # 0 CPU: 5.308 Node # 2 CPU: 5.356 Node # 8 CPU: 5.356
Node # 5 CPU: 5.356 Node # 1 CPU: 5.356 Node # 6 CPU: 5.356 Node # 3 CPU: 5.356 Node # 7 CPU: 5.356 Node # 9 CPU: 5.356 Node # 4 CPU: 5.356 Node # 14 CPU: 5.356 Node # 10 CPU: 5.356 Node # 13 CPU: 5.356
Node # 11 CPU: 5.356 Node # 15 CPU: 5.356
Node # 12 CPU: 5.356
Total: 85.651
Initialization ................................... 19.800 (23.1176 %)
Reading of input data ............................ 16.385 (19.1296 %)
Processing of input data ......................... 0.635 ( 0.7411 %)
Processing of output time averaged data .......... 0.617 ( 0.7199 %)
Computation of vertical boundary conditions ...... 0.052 ( 0.0610 %)
Computation of global information integrals ...... 0.361 ( 0.4214 %)
Writing of output data ........................... 9.925 (11.5883 %)
Model 2D kernel .................................. 18.240 (21.2961 %)
2D/3D coupling, vertical metrics ................. 0.353 ( 0.4117 %)
Omega vertical velocity .......................... 0.466 ( 0.5442 %)
Equation of state for seawater ................... 1.371 ( 1.6012 %)
KPP vertical mixing parameterization ............. 3.182 ( 3.7156 %)
3D equations right-side terms .................... 0.946 ( 1.1046 %)
3D equations predictor step ...................... 2.512 ( 2.9323 %)
Pressure gradient ................................ 0.919 ( 1.0732 %)
Harmonic mixing of tracers, S-surfaces ........... 0.347 ( 0.4047 %)
Harmonic stress tensor, S-surfaces ............... 0.647 ( 0.7556 %)
Corrector time-step for 3D momentum .............. 1.484 ( 1.7327 %)
Corrector time-step for tracers .................. 1.474 ( 1.7213 %)
Total: 79.717 93.0721
Message Passage: 2D halo exchanges ............... 3.730 ( 4.3546 %)
Message Passage: 3D halo exchanges ............... 0.981 ( 1.1456 %)
Message Passage: 4D halo exchanges ............... 0.325 ( 0.3789 %)
Message Passage: data broadcast .................. 27.790 (32.4453 %)
Message Passage: data reduction .................. 0.895 ( 1.0447 %)
Message Passage: data gathering .................. 3.093 ( 3.6115 %)
Message Passage: data scattering.................. 5.069 ( 5.9187 %)
Total: 41.883 48.8992
All percentages are with respect to total time = 85.651
ROMS/TOMS: DONE... Monday - April 20, 2009 - 12:14:17 PM
Information:
to standard output.
into history file.
time-averaged data.
time-averaged file.
for tracer 02: salt
for tracer 02: salt
for tracer 02: salt
for 3D momentum.
0 1 32 1 47 30080
1 33 64 1 47 30080
2 65 96 1 47 30080
3 97 128 1 47 30080
4 1 32 48 94 30080
5 33 64 48 94 30080
6 65 96 48 94 30080
8 1 32 95 141 30080
HaloSizeI(1) = 88
HaloSizeJ(1) = 118
TileSide(1) = 53
TileSize(1) = 2014
ECS East China Sea
- free-surface
- salinity
Total: 85.651
- m.hadfield
I can't see any obvious problems with your input.
You should examine the data saved in the restart file when the model blew up to see where the blow-up is initiated. This will often gives you a clue about the cause of the blow-up.
