Help My first application
bibi951
#1 Unread post by bibi951 »
Hello,everyone.I am new to Roms.
I just have build up my first application program.As I ween,there is something wrong. It is just an imatation of windbasin.I use my grid-The area range is 3-41N,100-137E.I didn't do much preprocess on bathymethy.And I use four wall boundry conditions,surface and bottom both with momentum and heat flux.It just blowup in the first step. Would somebody help me find what's the problem?
As follows:
NANHAI SHUZHISHIYAN
Operating system : CYGWIN
CPU/hardware : i686
Compiler system : g95
Compiler command : /usr/local/bin/g95
Compiler flags : -fno-second-underscore -O3 -ffast-math -ffree-form -ffree-line-length-huge
SVN Revision : 333M
Local Root : /home/Sun/roms/trunk
Header Dir : /home/Sun/roms/Projects/nanhai
Header file : nanhai.h
Analytical Dir: /home/Sun/roms/Projects/nanhai/Functionals
Resolution, Grid 01: 0521x0440x020, Parallel Threads: 1, Tiling: 001x001
NANHAI NANHAI SHUZHISHIYAN
EASTERN_WALL Wall boundary at Eastern edge.
MASKING Land/Sea masking.
MY25_MIXING Mellor/Yamada Level-2.5 mixing closure.
NONLINEAR Nonlinear Model.
NORTHERN_WALL Wall boundary at Northern edge.
SOUTHERN_WALL Wall boundary at Southern edge.
TS_SVADVECTION Parabolic splines vertical advection of tracers.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WESTERN_WALL Wall boundary at Western edge.
Vertical S-coordinate System:
Minimum X-grid spacing, DXmin = 6.58820368E+00 km
Maximum X-grid spacing, DXmax = 8.58514811E+00 km
Minimum Y-grid spacing, DYmin = 6.80046120E+00 km
Maximum Y-grid spacing, DYmax = 8.86173180E+00 km
Minimum Z-grid spacing, DZmin = NaN m
Maximum Z-grid spacing, DZmax = NaN m
Minimum barotropic Courant Number = 0.00000000E+00
Maximum barotropic Courant Number = 3.06178799E-01
Maximum Coriolis Courant Number = 1.12416582E-02
Maximum grid stiffness ratios: rx0 = 1.000000E+00 (Beckmann and Haidvogel)
rx1 = 2.141787E+01 (Haney)
Initial basin volumes: TotVolume = NaN m3
MinVolume = NaN m3
MaxVolume = 6.62990960088657E+10 m3
Max/Min = 0.00000000000000E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00068400)
0 515 24:00:00 NaN NaN NaN NaN
Elapsed CPU time (seconds):
Thread # 0 CPU: 128.453
Total: 128.453
Initialization ................................... 70.406 (54.8109 %)
Computation of global information integrals ...... 7.047 ( 5.4860 %)
2D/3D coupling, vertical metrics ................. 11.359 ( 8.8432 %)
Omega vertical velocity .......................... 5.156 ( 4.0141 %)
Equation of state for seawater ................... 52.422 (40.8101 %)
Total: 146.391 113.9642
All percentages are with respect to total time = 128.453
Analytical header files used:
/home/Sun/roms/Projects/nanhai/Functionals/ana_btflux.h
/home/Sun/roms/Projects/nanhai/Functionals/ana_initial.h
/home/Sun/roms/Projects/nanhai/Functionals/ana_smflux.h
/home/Sun/roms/Projects/nanhai/Functionals/ana_stflux.h
gouillon
Re: Help My first application
#2 Unread post by gouillon »
I never tried that test case but if there is no land in your basin, try to undefine the MASKING option.
It seems that you have a NAN value for your min basin volume and a 0 value for your barotropic courant number. Start from there to debug.
Flav
#3 Unread post by jcwarner »
"Minimum Z-grid spacing, DZmin = NaN m
Minimum barotropic Courant Number = 0.00000000E+00"
do you have any 'zeros' in your bathymetry?
Note that you can't have zero depth, even if it is inside the land mask.
bibi951
#5 Unread post by bibi951 »
Hi.Thanks for your replies.
I have modified the bathymetre,and it works.
Very nice.
Thank you all
bibi951
#6 Unread post by bibi951 »
Hello,everyone.
Back again.
I now use OTPS to make tide forcing.I use Cygwin for windows,and G95,Gfortran are my fortran compiler.Now it seem that G95 don't recognize this.Any advice?
$ make extract_HC
g95 -o extract_HC extract_HC.f subs.f -L/usr/local/lib -lnetcdf -I/usr/local/include
In file extract_HC.f:227
write(11,fmt)lat(k),lon0(k),((abs(z1(ic)),atan2(-imag(z1(ic)),real(z1(ic)))*180/3.141593),ic=1,ncon)
....................................................(1)
Error: Expected a right parenthesis in expression at (1)
#7 Unread post by kate »
bibi951 wrote:Hello,everyone.
Back again.
$ make extract_HC
Have you tried gfortran? If that doesn't work, I would rewrite that implied do loop on ic into an explicit do loop. I have a vague memory of the above style not being accepted by some gnu compiler even though it may be valid Fortran.
bibi951
#8 Unread post by bibi951 »
Hi,Kate.
I tried Gfortran,it also failed to do it.
I have rewrite this section to a explicit do loop.
As follows:
line 25 : character*2000 fmt1,fmt2,ftmp
aroud 176: c output format
fmt1='(f9.3,f9.3)'
if(APRI)then
fmt2='(f8.3,f8.1)'
else
fmt2='(f8.3,f8.3)'
endif
aroud 227: if(APRI)then
write(11,trim(fmt1),advance='no') lat(k),lon0(k)
do ic=1,ncon
write(11,trim(fmt2),advance='no') abs(z1(ic)),
* atan2(-imag(z1(ic)),real(z1(ic)))*180/3.141593
enddo
write(11,*)
else
do ic=1,ncon
write(11,trim(fmt2),advance='no') real(z1(ic)),imag(z1(ic))
enddo
write(11,*)
endif
bibi951
Help My first application about orientation
#9 Unread post by bibi951 »
Hi,everyone
I created my domain grid with seagrid.The first corner(*) is southwest(in real world),so the first edge is south(in real world).But what is the west boundary in Roms Model? Is it the first edge(south in real world)? Or ...?
If one boundary is half open,(there is a gap ),I should use OBC without further consideration, right?
Thanks in advance.
#10 Unread post by kate »
I believe the answers are yes and yes.
mathieu
#11 Unread post by mathieu »
Inside of roms the attributes south, east, north, west refer to the Grid.
More precisely if the grid has size (eta_rho,xi_rho),
then:
  • The points of the southern boundaries are all the points (1,iXi) for iXi between 1 and xi_rho.
    The points of the eastern boundary are all the points (iEta,xi_rho) for iEta between 1 and eta_rho.
    The points of the western boundary are all the points (iEta,1) for iEta between 1 and eta_rho.
    The points of the northern boundaries are all the points (eta_rho,iXi) for iXi between 1 and xi_rho.
All the options SOUTH_* and others refer to those points. The grid thus has its own notions of south, north, west, east. They coincide with the the corresponding geographical south, north, west and east only if the angle of the grid (variable angle in the netcdf grid file) is zero.
So, I would advise you to plot the grid and see if it matches with the above description.
hugobastos
#12 Unread post by hugobastos »
mathieu wrote:Inside of roms the attributes south, east, north, west refer to the Grid.
then:
Hello community,
A nice way to verify this in with ncview, and check the mask_rho or others mask's variables and see if they match with your geographic location (coastline position).
Because ncview read like mathieu says, and if the mask's (rho,psi) r not likely your real coast on the ncview display, your put some point on the wrong sequence!
Yhis happen to me on the GUIFG tool, when u forgot the order of Roll points hehe, my ocean boundary became clamped and the point's next to the land masks stay with nudging to NaN values :shock: hehe .
Another issue is to check de U,V masks, since when i use some routines from the collection of .m scripts, one or two routine messed up the masks on U and V!
:idea: So, to avoid this type of errors( and others stuff), ncview is very nice!
Thnkz
hugo
bibi951
#13 Unread post by bibi951 »
Thanks for the above replies,they are very clear.
I get this error message:
Minimum barotropic Courant Number = 9.63854617E-03
Maximum barotropic Courant Number = 2.99427149E-01
GET_NGFLD - tidal period
(Min = 4.32000000E+04 Max = 9.29494800E+04)
(Min = 0.00000000E+00 Max = 3.23688018E+00)
(Min = 1.25512765E-04 Max = 6.28311161E+00)
(Min = 0.00000000E+00 Max = 6.28318531E+00)
(Min = 0.00000000E+00 Max = 6.28318217E+00)
(Min = 0.00000000E+00 Max = 5.91933030E+00)
(Min = -1.30634990E+00 Max = 1.62644441E+00)
assertion "extent != 0" failed: file "posixio.c", line 412
Aborted (core dumped)
And I find a oceanS.exe.stackdump file which says:
Stack trace:
Frame Function Args
0022BBC8 7C802532 (00000678, 0000EA60, 000000A4, 0022BC10)
0022BCE8 61097F54 (00000000, 7C8025F0, 7C802532, 000000A4)
0022BDD8 61095AEB (00000000, 003B0023, 00230000, 0022CE68)
0022BE38 61095FCB (0022BE50, 00000000, 00000094, 61020C1B)
0022BEF8 61096182 (00000E34, 00000006, 0022BF28, 61096383)
0022BF08 610961AC (00000006, 0022CE88, 0000D44C, 6109A7DF)
0022BF28 61096383 (6110D008, 005405ED, 005404D4, 0000019C)
0022BF58 61001087 (005404D4, 0000019C, 005405ED, 00000000)
0022BFC8 610935A8 (00000000, 00000000, 00000000, 00000000)
0022BFF8 0052C66B (00ACFF30, 0022C058, FFFFFFFF, 00000000)
0022C0A8 0052D450 (00ACFEC8, 00000000, 00000000, 00000000)
0022C0E8 005145A8 (0096A270, 00000000, 00000000, 00000000)
0022C108 0051466C (0096A270, 00000000, 00000000, 0022C148)
0022C128 00514695 (0096A270, 00000000, 0022C148, 698043F1)
0022C158 0050E6A1 (0096A260, 0053CE70, 0022C434, 00000009)
0022C2B8 004C573D (0022CC84, 00532280, 00962310, 0053CE70)
End of stack trace (more stack frames may be present)
Is it because of my PC memory isn't enough?
Besides,I have run the example cases such as cblast,it's OK.And they run fast.My case runs very slowly. I always find it's almost the maximum memory.
I attach my .h file. Somewhere improper?
** svn $Id: .h 169 2007-04-09 21:01:01Z $
** Copyright (c) 2002-2007 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Coupled Boundary Layers and Air-Sea Transfer Application.
** Application flag: ** Input script: .in
/* Basic physics options */
#undef SALINITY
/* Basic numerics options */
/*#define UV_SADVECTION*/
#define TS_U3HADVECTION
#define TS_SVADVECTION
#define SPLINES
/* Outputs */
/*#define AVERAGES
/*#define AVERAGES_QUADRATIC /* for full diagnostics of mean and eddy heat fluxes */
/*#define AVERAGES_FLUXES /* for full diagnostics of mean and eddy heat fluxes */
/*#define DIAGNOSTICS_UV
/*#define DIAGNOSTICS_TS /* for full diagnostics of mean and eddy heat fluxes */
/*#define STATIONS*/
#undef OUT_DOUBLE
/* Surface and bottom boundary conditions */
/*#define SOLAR_SOURCE /* solar radiation penetrates through water column */
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_BMFLUX
#define ANA_INITIAL
/* Vertical subgridscale turbulence closure */
#undef LMD_MIXING
#define MY25_MIXING
#ifdef MY25_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# define LMD_BKPP
# define ANA_CLOUD
#define EASTERN_WALL
#define NORTHERN_WALL
/* Open boundary conditions */
#define ANA_FSOBC
#define ANA_M2OBC
#define RADIATION_2D
#define RAMP_TIDES
#define SSH_TIDES
#define ADD_FSOBC
#define WEST_FSCHAPMAN
#define SOUTH_FSCHAPMAN
#define UV_TIDES
#define ADD_M2OBC
#define WEST_M2FLATHER
#define WEST_M3RADIATION
#define WEST_M3NUDGING
#define WEST_TRADIATION
#define WEST_TNUDGING
#define SOUTH_M2FLATHER
#define SOUTH_M3RADIATION
#define SOUTH_M3NUDGING
#define SOUTH_TRADIATION
#define SOUTH_TNUDGING
#14 Unread post by kate »
Have you tried compiling with USE_DEBUG? You might get a more useful stack trace then. What is your grid size? You can get a feel for how big is too big by running the BENCHMARK case with the three different input files.
bibi951
#15 Unread post by bibi951 »
Hi,everyone.
I want to use only real tides on the open boundry.So I write this in my .h file
#undef SALINITY
#define SPLINES
/#undef OUT_DOUBLE
#define ANA_SMFLUX
#define ANA_STFLUX
#define ANA_BMFLUX
#define ANA_INITIAL
#undef LMD_MIXING
#define MY25_MIXING
#ifdef MY25_MIXING
#ifdef LMD_MIXING
# define LMD_RIMIX
# define LMD_CONVEC
# define LMD_SKPP
# define LMD_BKPP
# define ANA_CLOUD
#define ANA_FSOBC
#define ANA_M2OBC
#define RAMP_TIDES
#define SSH_TIDES
#define ADD_FSOBC
#define UV_TIDES
#define ADD_M2OBC
on the open boundry,I use ana_fsobc.h and ana_m2obc.h to give zero for all the vars. And I modified the parts of ana_initial.h ana_bmflux.h ana_btflux.h ana_smflux.h ana_stflux.h for my application.
It is a very simple case, but I encounted this error,and spent days in finding what's wrong.
It seems that a boundry file is requested.But I think I use ana_*.h to assign them zeros.I just want an analytic boundry values and the tide.Besides I have give a tidal forcing file but seems model didn't need it.
NFFILES == 1 ! number of forcing files
FRCNAME == test_HC.nc
This is the error message:
Output Restart File: ./rst_nanhai_ex.nc
Prefix for History Files: ./his_nanhai_ex
Input Grid File: zhongguon.nc
Input Boundary File: /dev/null
This is Activated C-preprocessing Options:
ADD_FSOBC Adding tidal elevation to proccesed OBC data.
0 0 00:00:00 0.000000E+00 3.233154E+05 3.233154E+05 2.468722E+16
Would some one help me ?
hugobastos
#16 Unread post by hugobastos »
You cant use this together:
#define ANA_FSOBC
#define ANA_M2OBC
with
#define SSH_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
U probably are overwriting the values in the boundary, using this 2 options !
The first's options set the elevation on the boundary to the values in ana_fsobc.F & ana_m2obc.F , call by analytical.F!
The last options r for realistic cases! u need to provide the tidal parameters on a netcdf file, and add this values in the model boundary.
Usually, we make a file from TPXO tide model, set this file to forcing file, add the options of SSH_TIDES,ADD_FSOBC,ADD_M2OBC and the respectivly boundary conditions .
See https://www.myroms.org/wiki/index.php/Tidal_Forcing For realistic tide forcing
and this https://www.myroms.org/wiki/index.php/FJORD_TIDAL_CASE , for a simple test on your grid!
Search in the wiki & forum about the CPP FLAGS and cases u want to use/test!
Clearly u will skip some of these types of problems.
bibi951
#17 Unread post by bibi951 »
Hello,I have a simple question to ask.
I don't quite understand this :
In set_tides.F line 434 and below,
! To avoid having two boundary
! points for these arrays, the values of "zeta_west" and "zeta_east"
! are averaged at u-points.
# ifdef ADD_FSOBC
zeta_west(j)=zeta_west(j)+ &
& 0.5_r8*(Etide(Istr-1,j)+Etide(Istr,j))
It seems that the programer want " zeta averaged at u-points",to be consistant with Ubar,maybe? zeta should be associated with divergence through continuity equation,So zeta should be on Rho grid point and u v on u,v grid point,isn't it? But then, Add tidal currents (m/s) to 2D momentum climatologies.
Uwrk(i,j)=UV_Tmajor(i,j,itide)*Cangle*Cphase- &
& UV_Tminor(i,j,itide)*Sangle*Sphase
Vwrk(i,j)=UV_Tmajor(i,j,itide)*Sangle*Cphase+ &
& UV_Tminor(i,j,itide)*Cangle*Sphase
And Utide(i,j)=Utide(i,j)+ &
& ramp*0.5_r8*(Uwrk(i-1,j)+Uwrk(i,j))
It seems back to zeta.I am confused about this.
What is that indeed? And what boundry condition (variables on which grid point?) do I need to provide for climatory?
I am a beginer to ROMS? Please give me some guide.
Thanks in advance.
