NETCDF_CHECK_VAR too strict?
m.hadfield
I've run into a problem--not to difficult to work around I hope, with the NETCDF_CHECK_VAR subroutine introduce in the recent coordinate transformation overhaul
viewtopic.php?t=1233
My run stops with the message
 NETCDF_CHECK_VAR - inconsistent value of variable: theta_b    2.000000E-01  2.000000E-01
                    in file: roms_ini.nc
It's complaining that theta_b set in the model run (2.000000E-01) does not equal theta_b read from the initial-fields file (2.000000E-01). They look pretty similar to me!
I think it's just a precision mismatch: I generated the initial-conditions file with a script that stored theta_b as a netCDF FLOAT value, while theta_b in the model run is double-precision. So I'm regenerating the initial-conditions file with all its vertical coordinate data in DOUBLE precision. We'll see if that works.
However, perhaps NETCDF_CHECK_VAR should check for equality within some small tolerance?
PS: the checks performed in NETCDF_CHECK_VAR are a good idea. Some years ago I used an initial-conditions file with vertical-grid parameters that didn't match the model run. This lead to very weird results.
Re: NETCDF_CHECK_VAR too strict?
#2 Unread post by arango »
Yes, I was able to reproduce the problem. Thank you. As you suspected it is due to round-off. I corrected this problem by checking the absolute of the difference whitin ad round-off value. See the following :arrow: track ticket.
