I am a new user of ROMS.
I run the upwelling test, it's ok. But when I run the ESTUARY_TEST, after 'make',I get such problem:
cd Build; /usr/bin/gfortran -c -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none analytical.f90
analytical.f90:256.32:
BOUNDARY(ng)%zeta_west(j)=9.0E-06_r8*fac
1
wrong: ‘zeta_west’at (1)is not the member of ‘t_boundary’
make: *** [Build/analytical.o] wrong 1
and I use the gfortran complier.I want to know why.
Thank you for your help!
problem when run the ESTUARY_TEST case
- m.hadfield
Re: problem when run the estuary_test case,help~
It sounds at bit like the problem reported here:
viewtopic.php?t=1208
There have been some changes in globaldefs.h to the code that sets the *_FSOBC, *_M2OBC, etc preprocessor symbols. It looks like the wrinkles haven't been completely ironed out. It may be that ana_fsobc.h has some redundant code for the ESTUARY_TEST case,
Yes, sometimes there is code that it not used in the analytical expressions. The definition and allocation of boundary arrays is very strict now. This problem is now
fixed.
Please update
Please update
Re: problem when run the ESTUARY_TEST case
That's the piont! It's ok now. You are really cool! Great! Thank you very much!
Lm == 200 ! Number of I-direction INTERIOR RHO-points
Mm == 3 ! Number of J-direction INTERIOR RHO-points
N == 20 ! Number of vertical levels
I think the value of Mm is wrong in the ocean_estuary.in
- m.hadfield
Wrong in what sense?
- m.hadfield
The ESTUARY_TEST case runs OK for me with revision 319. There's initially a vertical boundary between fresh and salty water. The fresh water moves seaward, as you'd expect, and the pattern moves back & forth with the tide. I see no sign of Mm being too small.
