Problems after updating to latest version of ROMS
nirnimesh
#1 Unread post by nirnimesh »
Hello Everybody
I am using ROMS with SWAN for a surf zone application and I had been using ROMS Revision (240). Today I updated my ROMS code to Revision 305 and tried to use it for same application
The application which used to work fine using Revision (240), doesn't work for Revision (305) because of 2 reasons:
(a) The maximum X-grid spacing, DXmax which initially used to be 10 meters, now displays a value of Inf km, similarly maximum Y-grid spacing, DYmax also shows a value of Inf km.
(b) The tidal netcdf forcing file I use has a minimum tide_period of 2.61 hours. The error I get states,
GET_CYCLE - starting time for variable: tide_period
                    is greater than current model time.
                    TMIN=        2.6101   TDAYS=            0.0000
 Minimum X-grid spacing, DXmin =  1.00000000E-02 km
 Maximum X-grid spacing, DXmax =             Inf km
 Minimum Y-grid spacing, DYmin =  2.50000000E-02 km
 Maximum Y-grid spacing, DYmax =             Inf km
 Minimum Z-grid spacing, DZmin = -3.62332311E-01 m
 Maximum Z-grid spacing, DZmax =  9.07500000E-01 m
 Minimum barotropic Courant Number =  3.58942782E-02
 Maximum barotropic Courant Number =  4.54466434E-01
 Maximum Coriolis   Courant Number =  1.45800000E-03
 NLM: GET_STATE - Read state initial conditions,             t =     0 00:00:00
                   (File: mbcoupled_init3_1126.nc, Rec=0001, Index=1)
                - free-surface
                - u-momentum component
                - v-momentum component
                - potential temperature
                   (Min =  1.00000000E+01 Max =  1.00000000E+01)
             TMIN =          2.6101  TDAYS =          0.0000
 Elapsed CPU time (seconds):
 Node   #  0 CPU:       0.053
 Total:                 0.053
  Reading of input data ............................         0.000  ( 0.0131 %)
  2D/3D coupling, vertical metrics .................         0.000  ( 0.7723 %)
  Omega vertical velocity ..........................         0.000  ( 0.3968 %)
  Equation of state for seawater ...................         0.000  ( 0.7895 %)
                                              Total:         0.001    1.9717
 Nonlinear model message Passage profile:
  Message Passage: 2D halo exchanges ...............         0.000  ( 0.1570 %)
  Message Passage: 3D halo exchanges ...............         0.000  ( 0.0656 %)
  Message Passage: data broadcast ..................         0.000  ( 0.8791 %)
  Message Passage: data reduction ..................         0.000  ( 0.0737 %)
  Message Passage: data scattering..................         0.001  ( 1.4116 %)
                                              Total:         0.001    2.5871
 All percentages are with respect to total time =            0.053
 ROMS/TOMS - Input error ............. exit_flag:   2
 REASON: No error
p0_5997: (3.539062) net_send: could not write to fd=4, errno = 32
I am not very sure about what is wrong. It would be very nice if someone could help me resolving these issues.
Nirnimesh
Re: Problems after updating to latest version of ROMS
#2 Unread post by arango »
OK. I will have to check that. The newer version is more strict in CF compliance of the input NetCDF files. Can you post an ncdump -h tide.nc so I can check what do you have in the tide forcing NetCDF file? The cycling is only activated when we have the cycle_length attribute. It seems that tide_period has such attribute. Why?
I don't know why are you getting Inf in the grid spacing. That may indicates that we are dividing by zero. Your pm and pn are zero in you input grid NetCDF. Check those variables. Did you applied land/sea masking to the inverse grid spacing?. The grid spacing always is a finite number (never zero) regardless if you have land/sea masking or not.
Why are you getting the GET_CYCLE message twice? Are you really using revision 305?
#3 Unread post by arango »
I modified get_cycle.F to avoid checking time-frequency variables, see following :arrow: ticket. Please update your code again.
nirnimesh
#4 Unread post by nirnimesh »
Hernan
Sorry for the delay in replying. I was having issues in connecting to the cluster. To answer your questions:
(a) I was using revision 305 as I checked my version after posting the message
The GET_CYCLE message comes twice as I did a mistake while copying and pasting it, when posting the last message. Sorry for that.
(b) I updated my code to revision 306 and now I don't get an error due to tidal period. The screen output from my latest run is shown below:
                - free-surface
    GET_NGFLD   - tidal period
                   (Min =  9.39642864E+03 Max =  2.63100002E+05)
    GET_2DFLD   - tidal elevation amplitude
                   (Min =  3.38429047E-03 Max =  7.86509474E-01)
    GET_2DFLD   - tidal elevation phase angle
                   (Min =  6.75731530E-01 Max =  6.25860515E+00)
    GET_2DFLD   - tidal current inclination angle
    GET_2DFLD   - tidal current phase angle
    GET_2DFLD   - maximum tidal current, ellipse major axis
    GET_2DFLD   - minimum tidal current, ellipse minor axis
    GET_2DFLD   - surface u-momentum stress,                 t =     0 00:00:00
                   (Rec=0001, Index=1, File: mbcoupled_wind3_1126.nc)
                   (Tmin=          0.0000 Tmax=     262800.0000)
                   (Min =  0.00000000E+00 Max =  7.42828407E-06)
    GET_2DFLD   - surface v-momentum stress,                 t =     0 00:00:00
                   (Min = -5.80016702E-06 Max =  0.00000000E+00)
 Maximum grid stiffness ratios:  rx0 =   2.029424E+00 (Beckmann and Haidvogel)
                                 rx1 =   3.044136E+01 (Haney)
 Initial basin volumes: TotVolume =  7.18938804333472E+05 m3
                        MinVolume = -8.25361851958021E+01 m3
                        MaxVolume =  2.17812500000000E+02 m3
                          Max/Min = -2.63899403011273E+00
      OCN2WAV   - (07) imported and (05) exported fields,    t =     0 00:00:00
                - ROMS coupling exchanges wait clock (s):
                   (Recv= 3.18984032E-01 Send= 1.27077103E-04)
                - ROMS Import: wave direction
                   (Min=  0.00000000E+00 Max=  0.00000000E+00)
                - ROMS Import: significant wave height
                   (Min=  0.00000000E+00 Max=  2.00687870E-02)
                - ROMS Import: average wave length
                   (Min=  0.00000000E+00 Max=  3.11992955E+00)
                - ROMS Import: surface wave relative peak period
                   (Min=  0.00000000E+00 Max=  1.90365362E+00)
                - ROMS Import: bottom wave period
                - ROMS Import: wave energy dissipation
                - ROMS Import: percent wave breaking
                - ROMS Import: wave bottom orbital velocity
                - ROMS Export: bathymetry
                   (Min= -2.89865849E+00 Max=  7.26000000E+00)
                - ROMS Export: free-surface
                - ROMS Export: vertically integrated u-momentum component
                - ROMS Export: vertically integrated v-momentum component
 SWAN is preparing computation ...
      WAV2OCN   - (05) imported and (07) exported fields,    t = 20000101.000000
                - SWAN coupling exchanges wait clock (s):
                   (Recv= 1.07121468E-03 Send= 3.58104706E-04)
     - ROMS Export: bottom roughness
                   (Min=  3.00000000E-03 Max=  3.00000000E-03)
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00026400)
    GET_2DFLD   - surface u-momentum stress,                 t =  3600 00:00:00
                   (Rec=0002, Index=2, File: mbcoupled_wind3_1126.nc)
                   (Min =  0.00000000E+00 Max =  1.18598557E-05)
    GET_2DFLD   - surface v-momentum stress,                 t =  3600 00:00:00
                   (Min =  0.00000000E+00 Max =  2.30452172E-06)
      0     0 00:00:00           NaN           NaN           NaN           Inf
I am not posting the ncdump -h tide.nc as "-h" option for ncdump doesn't seem to be working for my MATLAB and NETCDF configuration. I checked the tidal parameters being considered and they match with my inputs in the tide.nc file
(c) I checked my pm and pn values for my grid*.nc file and they are not zero at any grid point. I didn't apply land sea masking to inverse grid spacing. My masking is 1(WET) at all the grid points and I use WET_DRY cppdefs.h option to determine if a grid point is dry or wet.
I am also sure that the grid spacing which I used while creating this netcdf file is not zero.
I will dig a bit deep into the ROMS code and maybe post a more detailed message as to what is causing the error.
Thanks a lot for helping me out
Nirnimesh
bronwyn
#5 Unread post by bronwyn »
I had a similar problem when I updated to revision 294. I tried to rerun a biotoys application which worked fine in previous revision but failed trying to read in time variable with r294 as follows:
    GET_2DFLD   - surface u-wind component,                  t =     0 00:00:00
                   (File: frc_biotoys_era4010yrsall.nc, Rec=0000, Index=1)
                   (Tmin= *************** Tmax= ***************)
etc ... same for all forcing variables
 Maximum grid stiffness ratios:  rx0 =   0.000000E+00 (Beckmann and Haidvogel)
                                rx1 =   0.000000E+00 (Haney)
 Initial basin volumes: TotVolume =  2.76460644294440E+11 m3
                        MinVolume =  1.68603785954766E+08 m3
                        MaxVolume =  1.36456038303323E+09 m3
                          Max/Min =  8.09329621696230E+00
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00000001 - 00584000)
 SET_2DFLD  - current model time exceeds ending value for variable: Tair
              TDAYS     =          0.0000
              Data Tmin = ***************  Data Tmax = ***************
              Data Tstr = ***************  Data Tend =          0.0000
              TINTRP1   =          0.0000  TINTRP2   =             NaN
              FAC1      =             NaN  FAC2      =          0.0000
etc ... same again for all variables
 REASON: No error
I've just updated my code to revision 306 and this seems to have fixed the problem, application is running fine.
#6 Unread post by arango »
I think that now I understand the problem that you are having. You application is periodic and there is a problem when reading fields (like grid variables) from NetCDF files. I corrected this bug. See the following :arrow: trac ticket for more details.
Please update :!:
