Process Information:
Thread # 0 (pid= 61278) is active.
Model Input Parameters: ROMS/TOMS version 3.2
Tuesday - January 27, 2009 - 2:39:36 PM
Dave Test
Operating system : Darwin
CPU/hardware : i386
Compiler system : gfortran
Compiler command : /usr/local/bin/gfortran
Compiler flags : -frepack-arrays -O3 -ffast-math -ffree-form -ffree-line-length-none
SVN Revision : 294M
Local Root : /Users/daves/ROMS
Header Dir : /Users/daves/ROMS/ROMS/Include
Header file : davetest.h
Analytical Dir: /Users/daves/ROMS/ROMS/Functionals
Resolution, Grid 01: 0009x0014x010, Parallel Threads: 1, Tiling: 001x001
8640 ntimes Number of timesteps for 3-D equations.
300.000 dt Timestep size (s) for 3-D equations.
4320 nRST Number of timesteps between the writing of data
into restart fields.
10 ninfo Number of timesteps between print of information
to standard output.
864 nHIS Number of timesteps between the writing fields
into history file.
864 ndefHIS Number of timesteps between creation of new
history files.
5.0000E-01 tnu2(01) Horizontal, harmonic mixing coefficient (m2/s)
0.0000E+00 tnu2(02) Horizontal, harmonic mixing coefficient (m2/s)
for tracer 02: salt
for tracer 02: salt
5.0000E-06 Akv_bak Background vertical mixing coefficient (m2/s)
for turbulent energy.
1.0000E+01 blk_ZT Height (m) of surface air temperature measurement.
5 lmd_Jwt Jerlov water type.
8.0000E-01 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
1023.700 rho0 Mean density (kg/m3) for Boussinesq approximation.
120.000 dstart Time-stamp assigned to model initialization (days).
-5114.000 tide_start Reference time origin for tidal forcing (days).
20060101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.0000E+00 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+00 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+00 Znudg Nudging/relaxation time scale (days)
3.0000E+00 M2nudg Nudging/relaxation time scale (days)
3.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
4.0000E+00 obcfac Factor between passive and active
4.000 T0 Background potential temperature (C) constant.
32.000 S0 Background salinity (PSU) constant.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idVvis) Write out vertical viscosity coefficient.
T Hout(idSdif) Write out vertical S-diffusion coefficient.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
Output Restart File: OUT/ocean_rst.nc
Prefix for History Files: OUT/ocean_his
Input Grid File: grid.nc
Input Nonlinear Initial File: Ocn/ocean_ini.nc
Input Forcing File 01: Ocn/tides.nc
Input Forcing File 02: Atm/Uwind.nc
Input Forcing File 03: Atm/lwrad_down.nc
Input Forcing File 04: Atm/Pair.nc
Input Forcing File 05: Atm/rain.nc
Input Forcing File 06: Atm/swrad.nc
Input Forcing File 07: Atm/Tair.nc
Input Forcing File 08: Atm/Qair.nc
Input Forcing File 09: Atm/Vwind.nc
Input Climatology File: Ocn/ocean_clm.nc
Input Boundary File: Ocn/ocean_bry.nc
Tile partition information for Grid 01: 0009x0014x0010 tiling: 001x001
tile Istr Iend Jstr Jend Npts
0 1 9 1 14 1260
tile Xmin Xmax Ymin Ymax grid
0 1.00 9.00 1.00 14.00 RHO-points
0 1.50 8.50 1.00 14.00 U-points
0 1.00 9.00 1.50 13.50 V-points
DAVETEST Dave Test
ANA_RAIN Analytical rain fall rate.
BULK_FLUXES Surface bulk fluxes parametererization.
CANUTO_A Canuto A-stability function formulation.
EAST_M3NUDGING Eastern edge, 3D momentum, passive/active outflow/inflow.
EAST_TNUDGING Eastern edge, tracers, passive/active outflow/inflow.
LONGWAVE_OUT Compute outgoing longwave radiation internally.
M2CLIMATOLOGY Processing 2D momentum climatology data.
M2CLM_NUDGING Nudging toward 2D momentum climatology.
M3CLIMATOLOGY Processing 3D momentum climatology data.
M3CLM_NUDGING Nudging toward 3D momentum climatology.
MASKING Land/Sea masking.
NONLINEAR Nonlinear Model.
NORTH_FSCHAPMAN Northern edge, free-surface, Chapman condition.
NORTH_M2FLATHER Northern edge, 2D momentum, Flather condition.
NORTH_M3NUDGING Northern edge, 3D momentum, passive/active outflow/inflow.
NORTH_M3RADIATION Northern edge, 3D momentum, radiation condition.
NORTH_TNUDGING Northern edge, tracers, passive/active outflow/inflow.
NORTH_TRADIATION Northern edge, tracers, radiation condition.
SALINITY Using salinity.
SOUTH_M3NUDGING Southern edge, 3D momentum, passive/active outflow/inflow.
SOUTH_TNUDGING Southern edge, tracers, passive/active outflow/inflow.
SPHERICAL Spherical grid configuration.
TCLIMATOLOGY Processing tracer climatology data.
TCLM_NUDGING Nudging toward tracer climatology.
UV_ADV Advection of momentum.
UV_COR Coriolis term.
WEST_FSCHAPMAN Western edge, free-surface, Chapman condition.
WEST_M2FLATHER Western edge, 2D momentum, Flather condition.
WEST_M3NUDGING Western edge, 3D momentum, passive/active outflow/inflow.
WEST_M3RADIATION Western edge, 3D momentum, radiation condition.
WEST_TNUDGING Western edge, tracers, passive/active outflow/inflow.
WEST_TRADIATION Western edge, tracers, radiation condition.
ZCLIMATOLOGY Processing sea surface height climatology data.
ZCLM_NUDGING Nudging toward sea surface height climatology.
Vertical S-coordinate System:
10 0.0000000 -0.0000000 -0.000 -0.000 -0.000
9 -0.1000000 -0.0105618 -0.032 -15.408 -30.785
8 -0.2000000 -0.0361960 -0.109 -52.806 -105.504
7 -0.3000000 -0.0969683 -0.291 -141.466 -282.641
6 -0.4000000 -0.2224207 -0.667 -324.488 -648.308
5 -0.5000000 -0.4163071 -1.249 -607.347 -1213.445
4 -0.6000000 -0.6143559 -1.843 -896.278 -1790.714
3 -0.7000000 -0.7533581 -2.260 -1099.067 -2195.875
2 -0.8000000 -0.8405260 -2.522 -1226.236 -2449.950
1 -0.9000000 -0.9121394 -2.736 -1330.712 -2658.688
0 -1.0000000 -1.0000000 -3.000 -1458.891 -2914.782
Time Splitting Weights: ndtfast = 20 nfast = 29
3-0.0011514592651645 0.0501156998674241-0.0034654566136460 0.1501639558342179
4-0.0003735756740661 0.0501732728306823-0.0038390322877122 0.2003372286649002
5 0.0009829200513762 0.0501919516143856-0.0028561122363360 0.2505291802792858
6 0.0029141799764308 0.0501428056118168 0.0000580677400948 0.3006719858911026
7 0.0054132615310267 0.0499970966129952 0.0054713292711215 0.3506690825040978
8 0.0084687837865132 0.0497264335364439 0.0139401130576347 0.4003955160405417
9 0.0120633394191050 0.0493029943471183 0.0260034524767397 0.4496985103876600
10 0.0161716623600090 0.0486998273761630 0.0421751148367486 0.4983983377638230
11 0.0207585511322367 0.0478912442581626 0.0629336659689853 0.5462895820219856
12 0.0257765478740990 0.0468533167015507 0.0887102138430843 0.5931428987235363
13 0.0311633730493853 0.0455644893078458 0.1198735868924696 0.6387073880313821
14 0.0368391158442262 0.0440063206553765 0.1567127027366958 0.6827137086867585
15 0.0427031802506397 0.0421643648631652 0.1994158829873354 0.7248780735499237
16 0.0486309868367616 0.0400292058506332 0.2480468698240970 0.7649072794005569
17 0.0544704302037591 0.0375976565087951 0.3025173000278562 0.8025049359093520
18 0.0600380921294285 0.0348741349986072 0.3625553921572847 0.8373790709079592
19 0.0651152103984763 0.0318722303921358 0.4276706025557610 0.8692513013000949
20 0.0694434033194839 0.0286164698722119 0.4971140058752449 0.8978677711723068
21 0.0727201499285569 0.0251442997062377 0.5698341558038018 0.9230120708785445
22 0.0745940258796570 0.0215082922098099 0.6444281816834588 0.9445203630883544
23 0.0746596950216180 0.0177785909158270 0.7190878767050768 0.9622989540041814
24 0.0724526566618460 0.0140456061647461 0.7915405333669228 0.9763445601689276
25 0.0674437485167025 0.0104229733316538 0.8589842818836253 0.9867675335005814
26 0.0590334053485720 0.0070507859058187 0.9180176872321973 0.9938183194064002
27 0.0465456732896125 0.0040991156383901 0.9645633605218099 0.9979174350447904
28 0.0292219798521905 0.0017718319739095 0.9937853403740005 0.9996892670186999
29 0.0062146596259994 0.0003107329813000 0.9999999999999999 0.9999999999999999
ndtfast, nfast = 20 29 nfast/ndtfast = 1.45000
Minimum X-grid spacing, DXmin = 2.97356675E+01 km
Maximum X-grid spacing, DXmax = 2.97356675E+01 km
Minimum Y-grid spacing, DYmin = 3.07439608E+01 km
Maximum Y-grid spacing, DYmax = 3.07439608E+01 km
Minimum Z-grid spacing, DZmin = 3.16853172E-02 m
Maximum Z-grid spacing, DZmax = 5.77269100E+02 m
Minimum barotropic Courant Number = 3.80717940E-03
Maximum barotropic Courant Number = 1.18671316E-01
Maximum Coriolis Courant Number = 3.28944953E-02
NLM: GET_STATE - Read state initial conditions, t = 120 00:00:00
(File: ocean_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = 4.29925293E-03 Max = 1.39852402E-01)
(Min = -1.58153090E-01 Max = 1.67690075E-01)
(Min = -8.34430335E-02 Max = 1.30607023E-01)
- u-momentum component
(Min = -1.98971007E-01 Max = 2.69165120E-01)
- v-momentum component
(Min = -1.22494426E-01 Max = 2.07887629E-01)
- potential temperature
(Min = 1.74229923E+00 Max = 1.50000000E+01)
- salinity
(Min = 0.00000000E+00 Max = 3.46305472E+01)
GET_NGFLD - tidal period
(Min = -7.20002575E+03 Max = -7.20002575E+03)
(Min = 1.00000000E+37 Max = -1.00000000E+37)
GET_2DFLD - surface u-wind component, t = 120 00:00:00
(File: Uwind.nc, Rec=0714, Index=1)
(Tmin= 90.2917 Tmax= 273.2500)
(Min = 6.85470033E-01 Max = 8.74236333E+00)
GET_2DFLD - surface v-wind component, t = 120 00:00:00
(File: Vwind.nc, Rec=0714, Index=1)
(Min = -1.06013147E+01 Max = 6.27439000E-01)
GET_2DFLD - solar shortwave radiation flux, t = 120 00:00:00
(File: swrad.nc, Rec=0714, Index=1)
(Min = 5.66614492E-05 Max = 1.40407721E-04)
GET_2DFLD - downwelling longwave radiation flux, t = 120 00:00:00
(File: lwrad_down.nc, Rec=0714, Index=1)
(Min = 5.23297392E-05 Max = 7.78363329E-05)
GET_2DFLD - surface air pressure, t = 120 00:00:00
(File: Pair.nc, Rec=0714, Index=1)
(Min = 9.41421267E+02 Max = 1.02793233E+03)
GET_2DFLD - surface air temperature, t = 120 00:00:00
(File: Tair.nc, Rec=0714, Index=1)
(Min = 8.46280000E+00 Max = 1.24724000E+01)
GET_2DFLD - surface air relative humidity, t = 120 00:00:00
(File: Qair.nc, Rec=0714, Index=1)
(Min = 4.82636058E-01 Max = 8.69312700E-01)
GET_NGFLD - free-surface western boundary condition, t = 120 00:00:00
(File: ocean_bry.nc, Rec=0001, Index=2)
(Tmin= 120.0000 Tmax= 150.0000)
(Min = 4.29925293E-03 Max = 1.14858652E-01)
GET_NGFLD - free-surface eastern boundary condition, t = 120 00:00:00
(Min = 6.69948349E-02 Max = 1.39385963E-01)
GET_NGFLD - free-surface southern boundary condition, t = 120 00:00:00
(Min = 4.29925293E-03 Max = 7.11807813E-02)
GET_NGFLD - free-surface northern boundary condition, t = 120 00:00:00
(Min = 1.11451183E-01 Max = 1.24161614E-01)
GET_NGFLD - 2D u-momentum western boundary condition, t = 120 00:00:00
(Min = -2.23290309E-02 Max = -8.31978531E-03)
GET_NGFLD - 2D v-momentum western boundary condition, t = 120 00:00:00
(Min = 5.34520762E-03 Max = 1.98139420E-02)
GET_NGFLD - 2D u-momentum eastern boundary condition, t = 120 00:00:00
(Min = -1.50792976E-01 Max = 1.67690075E-01)
GET_NGFLD - 2D v-momentum eastern boundary condition, t = 120 00:00:00
(Min = -8.34430335E-02 Max = 1.16547539E-01)
GET_NGFLD - 2D u-momentum southern boundary condition, t = 120 00:00:00
(Min = -1.01661586E-02 Max = 4.89103950E-03)
GET_NGFLD - 2D v-momentum southern boundary condition, t = 120 00:00:00
(Min = 1.35854326E-02 Max = 1.17949375E-01)
GET_NGFLD - 2D u-momentum northern boundary condition, t = 120 00:00:00
(Min = -1.63991366E-02 Max = 1.67690075E-01)
GET_NGFLD - 2D v-momentum northern boundary condition, t = 120 00:00:00
(Min = -8.34430335E-02 Max = 3.28114659E-02)
GET_NGFLD - 3D u-momentum western boundary condition, t = 120 00:00:00
(Min = -1.62868211E-01 Max = 1.27311642E-02)
GET_NGFLD - 3D v-momentum western boundary condition, t = 120 00:00:00
(Min = -1.06481557E-02 Max =
Dave Sutherland
