I am trying to run a simulation with the cpp option FLOATS, and I get a compilation error. Has anyone else encountered this? This is my first time with FLOATS. Are there other cpp options that I should be using? I am using revision 291.
The error messages are:
PGF90-S-0038-Symbol, flt_lagran, has not been explicitly declared (step_floats.f90)
PGF90-S-0038-Symbol, flt_isobar, has not been explicitly declared (step_floats.f90)
PGF90-S-0038-Symbol, flt_geopot, has not been explicitly declared (step_floats.f90)
greg
problem compiling with FLOATS
- m.hadfield
Re: problem compiling with FLOATS
Try compiling the FLT_TEST case, first without, then with SOLVE3D defined. It is working OK for me with revision 297. If the FLT_TEST case works for you, have a look at the differences between it and your run.
Thanks.
FLT_TEST compiles without SOLVE3D, but not with SOLVE3D.
Does it work both ways for you? It doesn't seem to depend on the version I am using.
- m.hadfield
Yes it does work both ways for me. Can you update to 297 and try again? (Or have you already done so?)ggerbi wrote:FLT_TEST compiles without SOLVE3D, but not with SOLVE3D. Does it work both ways for you? It doesn't seem to depend on the version I am using.
If that doesn't work, you need to look at the .f90 files (preprocessed source) to see where the relevant variables are declared (or not). Here are the results of a (case-insensitive) search for "flt_lagran" on my machine, with file names and line numbers followed by the line where the match was found
mod_scalars.f90(67): ! flt_Lagran: 3D Lagrangian floats
mod_scalars.f90(71): integer, parameter :: flt_Lagran = 1
step_floats.f90(135): IF (Ftype(l).eq.flt_Lagran) THEN
step_floats.f90(256): IF (Ftype(l).eq.flt_Lagran) THEN
Thanks for checking that.
I get the same error with version 297.
I'll dig deeper into my files.
greg
greg
