problems in INLET_TEST case
ljzhong
#1 Unread post by ljzhong »
When I ran ROMS/SWAN coupling test case INLET_TEST, the program terminated in initial.F where subroutine ocn2wav_coupling is called. It seems that SWAN was running normally because there were a number of SWAN output files, such as PRINT-00x, ***.mat-00x, point1-spc2d-00x, etc, but ROMS part was stuck because of the communication between ROMS and SWAN.
There was once an error when I built MCT library. It complained CLK_TCK not defined in get_zeits.c. I tried to replace #include <time.h> with #include <bits/time.h> and I am sure CLK_TCK is defined in this new time.h, but it still complained, so I had to define it manually in get_zeits.c by #define CLK_TCK CLOCKS_PER_SEC. Not sure if it caused the above problem. Meanwhile, I built MCT using the same flags as in ROMS, as suggested in the forum.
I set 2 CPUS for both ROMS and SWAN and ifort is my fortran compiler.
Any suggestions that someone can advise? Thanks.
Liejun
Re: problems in INLET_TEST case
can you look into the standard out file and see what is happening when it dies? Look for swan Errfiles, and see if there is any relevant info. Look in the SWAN Print-00* files and see if all that looks ok.
I remember that get_zeits problme with an older version of fortran. Which ifort -ver ?
ljzhong
#3 Unread post by ljzhong »
John, thanks for your quick response.
I'm using ifort v9.1. I downloaded the newest MCT v2.5 and compiled it successfully without any complaint or warning messages, but the same problem still exists in ROMS/SWAN.
My ROMS/SWAN code is the latest version, 258M. There is no Errfiles from SWAN. The model died without any error message. I ran the model with 1 CPU for SWAN and found no output from SWAN except PRINT. Here is is the last few lines from PRINT.
BLOCK 'COMPGRID' NOHEADER 'xp.mat' LAY 4 XP 1.
BLOCK 'COMPGRID' NOHEADER 'yp.mat' LAY 4 YP 1.
POINTS 'point1' 5000.0 10000.0
SPECOUT 'point1' SPEC2D 'point1.spc2d' OUTPUT 20000101.000000 1 HR
PROP BSBT
COMPUTE NONSTATIONARY 20000101.000000 60 SEC 20000103.000000
** Warning : Limiter is de-activated in case of no quadruplets
Looks like something was wrong with SWAN.
#4 Unread post by jcwarner »
that swan message is just a warning, not a show stopper.
Can you post the roms std out here:
ljzhong
#5 Unread post by ljzhong »
here is ROMS output
Coupled Input File name = input/coupling_inlet_test.in
Model Coupling Parallel Threads:
Ocean Model MPI nodes: 000 - 001
Waves Model MPI nodes: 002 - 002
Ocean Export: bath:SSH:Ubar:Vbar
Waves Export: Wdir:Wamp:Wlen:Wptop:Wpbot
Process Information:
Node # 0 (pid= 19590) is active.
Node # 1 (pid= 19591) is active.
Model Input Parameters: ROMS/TOMS version 3.0
Thursday - November 6, 2008 - 4:18:14 PM
SWAN is preparing computation ...
Inlet Test Case
Operating system : Linux
CPU/hardware : ia64
Compiler system : ifort
Compiler command : ifort
Compiler flags : -ip -O2 -fpe0 -I/xxx/MCT/include -free
Input Script : input/ocean_inlet_test.in
SVN Revision :
Local Root : xxx
Header Dir : xxx
Header file : inlet_test.h
Analytical Dir: xxx
Resolution, Grid 01: 0075x0070x008, Parallel Nodes: 2, Tiling: 001x002
34560 ntimes Number of timesteps for 3-D equations.
5.000 dt Timestep size (s) for 3-D equations.
720 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
2 nHIS Number of timesteps between the writing fields
into history file.
1.0000E-03 visc2 Horizontal, harmonic mixing coefficient (m2/s)
5.0000E-06 Akt_bak(02) Background vertical mixing coefficient (m2/s)
for tracer 02: salt
for turbulent energy.
1.5000E-02 Zob Bottom roughness (m).
5.0000E-01 Zos Surface roughness (m).
1.0000E+00 theta_s S-coordinate surface control parameter.
1.0000E+00 theta_b S-coordinate bottom control parameter.
0.000 Tcline S-coordinate surface/bottom layer width (m) used
for tracer 02: salt
for 3D momentum.
of State.
T Hout(idBath) Write out time-dependent bathymetry.
T Hout(idUbrs) Write out bottom U-current stress.
T Hout(idVbrs) Write out bottom V-current stress.
T Hout(idUbws) Write out wind-induced, bottom U-wave stress.
T Hout(idVbws) Write out wind-induced, bottom V-wave stress.
T Hout(idUbcs) Write out max wind + current, bottom U-wave stress.
T Hout(idVbcs) Write out max wind + current, bottom V-wave stress.
T Hout(idW2xx) Write out 2D radiation stress, Sxx.
T Hout(idW2xy) Write out 2D radiation stress, Sxy.
T Hout(idW2yy) Write out 2D radiation stress, Syy.
T Hout(idWamp) Write out wave height.
T Hout(idWlen) Write out wave length.
T Hout(idWdir) Write out wave direction.
T Hout(idBott) Write out bottom property 01: grain_diameter
T Hout(idBott) Write out bottom property 02: grain_density
T Hout(idBott) Write out bottom property 03: settling_vel
T Hout(idBott) Write out bottom property 04: erosion_stress
T Hout(idBott) Write out bottom property 05: ripple_length
T Hout(idBott) Write out bottom property 06: ripple_height
T Hout(idBott) Write out bottom property 07: bed_wave_amp
T Hout(idBott) Write out bottom property 08: Zo_def
T Hout(idBott) Write out bottom property 09: Zo_app
Physical parameters File: input/ocean_inlet_test.in
Input Grid File: input/inlet_test_grid.nc
Tile partition information for Grid 01: 0075x0070x0008 tiling: 001x002
tile Istr Iend Jstr Jend Npts
0 1 75 1 35 21000
1 1 75 36 70 21000
HaloSizeI(1) = 255
HaloSizeJ(1) = 144
TileSide(1) = 79
TileSize(1) = 3318
Sediment Parameters, Grid: 01
Size Sd50 Csed Srho Wsed Erate poros
Class (mm) (kg/m3) (kg/m3) (mm/s) (kg/m2/s) (nondim)
1 1.0000E-01 0.0000E+00 2.6500E+03 1.0000E+01 5.0000E-03 0.0000E+00
tau_ce tau_cd tnu2 tnu4 Akt_bak Tnudg
(N/m2) (N/m2) (m2/s) (m4/s) (m2/s) (day)
1 1.0000E-01 1.0000E-02 0.0000E+00 0.0000E+00 5.0000E-06 0.0000E+00
morph_fac
(nondim)
1 1.0000E+01
New bed layer formed when deposition exceeds 0.10000E-01 (m).
Two first layers are combined when 2nd layer smaller than 0.00000E+00 (m).
Rate coefficient for bed load transport = 0.15000E+00
T Hout(idTvar) Write out sediment01: mud_01
T Hout(idfrac) Write out bed fraction, sediment 01: mudfrac_01
T Hout(idfrac) Write out mass, sediment 01: mudmass_01
T Hout(idSbed) Write out BED property 01: bed_thickness
T Hout(idSbed) Write out BED property 02: bed_age
T Hout(idSbed) Write out BED property 03: bed_porosity
INLET_TEST Inlet Test Case
ANA_BPFLUX Analytical bottom passive tracers fluxes.
ANA_SEDIMENT Analytical sediment initial conditions.
ANA_SPFLUX Analytical surface passive tracer fluxes.
EAST_FSGRADIENT Eastern edge, free-surface, gradient condition.
EAST_M2GRADIENT Eastern edge, 2D momentum, gradient condition.
EAST_M3GRADIENT Eastern edge, 3D momentum, gradient condition.
FSOBC_REDUCED Using free-surface data in reduced physics condtions
MASKING Land/Sea masking.
MCT_LIB Using Model Coupling Toolkit library.
NEARSHORE_MELLOR Nearshore RAdiation Stress Terms.
NONLINEAR Nonlinear Model.
NORTH_FSGRADIENT Northern edge, free-surface, gradient condition.
NORTH_M2REDUCED Northern edge, 2D momentum, reduced-physics condition.
NORTH_M3GRADIENT Northern edge, 3D momentum, gradient condition.
SEDIMENT Cohesive and noncohesive sediments.
SED_MORPH Allow bottom model elevation to evolve.
SUSPLOAD Activate suspended sediment transport.
SOUTHERN_WALL Wall boundary at Southern edge.
SSW_BBL Styles and Glenn Bottom Boundary Layer - modified.
SSW_CALC_ZNOT Internal computation of bottom roughness.
SWAN_COUPLING Two-way SWAN/ROMS coupling.
THREE_GHOST Using three Ghost Points in halo regions.
UV_ADV Advection of momentum.
WAVES_OCEAN Two-way wave-ocean models coupling.
WEST_FSGRADIENT Western edge, free-surface, gradient condition.
WEST_M2GRADIENT Western edge, 2D momentum, gradient condition.
WEST_M3GRADIENT Western edge, 3D momentum, gradient condition.
if I set 2 cpus for SWAN, there is a little more output till ROMS reads the grid info
Minimum X-grid spacing, DXmin = 2.00000000E-01 km
Maximum X-grid spacing, DXmax = 2.00000000E-01 km
Minimum Y-grid spacing, DYmin = 2.00000000E-01 km
Maximum Y-grid spacing, DYmax = 2.00000000E-01 km
Minimum Z-grid spacing, DZmin = 4.49062569E-01 m
Maximum Z-grid spacing, DZmax = 2.08817024E+00 m
Minimum barotropic Courant Number = 1.10736173E-02
Maximum barotropic Courant Number = 2.18124964E-02
Maximum Coriolis Courant Number = 7.29000000E-04
Maximum grid stiffness ratios: rx0 = 3.846154E-02 (Beckmann and Haidvogel)
rx1 = 6.467265E-01 (Haney)
Initial basin volumes: TotVolume = 1.43456000000009E+09 m3
MinVolume = 1.79625027600252E+04 m3
MaxVolume = 8.18046072184575E+04 m3
Max/Min = 4.55418759353014E+00
Anyway, ROMS seems have no chance to move one single time step forward.
I may have to dig into SWAN code and I will report here if I find something.
#6 Unread post by jcwarner »
I just updated to the latest rutgers trunk version. Compiled the inlet test. It ran. It works for me on my systems, and so it is hard for me to help you.
I am not sure what to tell you to try. By default it has 1 proc for roms and 1 proc for swan. Can you try to run it with just 1 proc roms and 1 proc swan, as it is distributed?
