Initialization for Fasham and EcoSim BioToys applications
I have some initialization files for Fasham and EcoSim BioToys applications which I want to make available for general use. Is there somewhere I can post these on the ROMS site or do I need to post elsewhere on an ftp server?
- Bronwyn
- Bronwyn
The initialization files for the BIO_TOY application are now on the datasets page.
Re: Initialization for Fasham and EcoSim BioToys applications
Hi, bronwyn,
I have just tested the EcoSim case, but met trouble whiling running 1 step. The messages are:
STEP time[DAYS] KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME trd
0 0.00000 0.000000E+00 1.034867E+03 1.034867E+03 2.764606E+11 0
DEF_HIS - creating history file: ocean_his.nc
WRT_HIS - error while writing variable: Bac_F1
into history NetCDF file for time record: 1
REASON: NetCDF: Numeric conversion not representable
I have googled the NetCDF error. The var Bac_F1 is Inf which might break the HIS file.
What can I do to solve this problem?
Thank you!
zhou
Thank you!
zhou
Is Bac_F1 part of the initial condition? If it is, you must have bad data in your initial condition since model encounter that problem while writing the initial record.
Hi Zhou,
That's curious. I've used this initial condition file without problems ... can you tell me what version of NetCdf and ROMS you are using?
Bronwyn
Bronwyn
Hi:
This may not help, but I have the same problem. I compiled the 3 versions of last revision of ROMS, serial, OpenMP and MPI. With my problem, serial version works ok! but with parallel versions OpenMP and MPI the model stops and raises an error:
0 0 00:00:00 0.000000E+00 2.466303E+04 2.466303E+04 1.107566E+15
WRT_HIS - error while writing variable: w
and after that:
I tested versions 3.6.2 and 3.6.3 of NetCDF libraries and two different machines (Linux - Intel Itanium2 at HP Finisterrae - Centro de Supercomputación de Galicia, and Linux 2 QuadCores Intel Xeon). I use intel compilers (10 series for Finisterrae and 9.1 for QuadCores).
Any idea?
Best regards.
and after that:
Any idea?
Best regards.
Hi!
I'm having a slightly different problem with the biotoy initialization files. I can build the model fine, but when I run it, it runs, but produces no output files. In the log, I find the following after the "Initial Basin Volumes" section:
Any suggestions as to how this might happen? I'm new to ROMS, and have only run the standard upwelling test before.
System info:
ROMS svn Revision: 232 (yesterday)
Linux (Fedora 9)
gfortran 4.3.0
--Tom
It seems that the initial timestep has been set to a high number, so the time loop exits instantly. I get the same problem building with mpi on or off.NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 00058561 - 00001600)
Elapsed CPU time (seconds):
Thread # 0 CPU: 0.036
Total: 0.036
System info:
Linux (Fedora 9)
gfortran 4.3.0
--Tom
Tom, you need to check your DSTART and the time in your initialization file. You can change DSTART to match whatever time is in the file, so that NTIMES gives the number of steps to run. Or change NTIMES to run beyond your starting time, in this case 58561+1600. A third option is to change the time in the netcdf file.
Thanks Kate!
Your answer came just after I had spent a morning learning the ways of ROMS through gdb, where I had tracked down the problem to the call to "get_state" in initial.F. Your response clarifies the problem.
It turns out there's a slight inconsistency between Bronwyn's files for the Fasham model and the ROMS distribution. In the current distribution, ocean_bio_toy.in is set to use biotoy_ini_fasham.nc, and sets dstart=0. However, Bronwyn's biotoy_ini_fasham.nc has ocean_time=366. When I edited ocean_bio_toy.in to use ecosim initializations (where ocean_time=0), the model runs.
Next question:
I've gotten the ecosim model to run in biotoy. How do I change to the Fasham model?? Here's what I tried:
1) Edited ocean_bio_toy.in to read bioFasham.in and biotoy_ini_fasham.nc (with ocean_time changed to 0).
2) Edited build.bash to export MY_CPP_FLAGS="-DBIO_FASHAM".
3) Rebuilt the model and started run.
It now gets past the previous start-time error, but now I get the "WRT_HIS - error while writing variable: Bac_F1" error reported by FengZhou. (I don't see a resolution for that problem posted--did I miss something?)
Looking through the log file, I see in the list of CPP flags that ECOSIM is defined, not BIO_FASHAM. (I checked the build log, and -DBIO_FASHAM was definitely in the compile commands.) So, the undefined Bac_F1 is probably because I'm running ECOSIM code with BIO_FASHAM input files. But why is it running with ECOSIM defined? Looking at ROMS/Include/biotoy.h, I fined hardcoded:
I don't understand why these would be hardcoded, especially as they are followed immediately by #ifdef's for these flags. It looks like I need to modify biotoy.h to get this to work. I'm running my tests in a project directory outside the ROMS file hierarchy. Can someone tell me where to put my modified biotoy.h so it will override the one in ROMS/Include? Or, is there another way around this?
Thanks in advance for your help!
--Tom
#undef BIO_FASHAM
#define ECOSIM
--Tom
Hi Tom,
Yes, you are right about the inconsistency in the fasham initial conditions ocean_time and dstart in the ocean_biotoy.in file. I'll post a new fasham initial condition file with ocean_time set to 0.
As for the second question, you need to define BIO_FASHAM and undef ECOSIM in biotoys.h to run fasham but not in the ROMS/Include directory. The idea is to work with a project directory (typically it's User/...) with header (User/Include), analytical (User/Functionals) and application (User/External) sub-directories. It means that if you are working on multiple projects / applications at the same time, it makes it easier to manage changes. So, don't change what's hardcoded under ROMS/Include but copy biotoy.h from there to User/Include, modify the definitions there for your purpose, and then tell your build script where to find your project directory, header directory, etc ... In the end, where you put all these project files and how you manage them is a matter of personal preference, you just need to make sure you have put the correct path in the build script.
Hope that's helpful!
Bronwyn
Bronwyn
Bronwyn,
Thanks for the help. Now I know where to put modified files.
Actually, that shouldn't be necessary here. I did a little test, and if those two lines ("#undef BIO_FASHAM" and "#define ECOSIM") are dropped from bio_toy.h, then the biological model can be selected in the build script and ocean*.in file, without any need to edit bio_toy.h each time. The project I'm working on is comparing different biological model versions, so the fewer the edits needed to switch, the better. Here's the diff between my modified bio_toy.h and the original:
$ diff Include/bio_toy.h ../../ROMS/ROMS/Include/bio_toy.h
2c2
< ** svn $Id: bio_toy.h 139 2008-01-10 00:17:29Z arango $ Local Modification -TW
41a42
> #undef BIO_FASHAM
47a49
> #define ECOSIM
Thanks again!
--Tom
2c2
41a42
> #undef BIO_FASHAM
47a49
> #define ECOSIM
Thanks again!
--Tom
I try to run bio_toy test case using this setup:
ocean_bio_toy.in:
bio_toy.h:
but then, it resulting an error when I run it:::
Please help me how to solve this error. I really appreciate comments, directions, and/or clues regarding this error. Thank you in advance to you all.
(system: redhat, Revision: 297, compiler: gfortran)
Al
ocean_bio_toy.in:
GRDNAME == /home/am/ROMS/trunk/Data/ROMS/Grid/biotoy_grd.nc
! ININAME == /home/am/ROMS/trunk/Data/ROMS/Initial/biotoy_ini_fasham.nc
ININAME == /home/am/ROMS/trunk/Data/ROMS/Initial/biotoy_ini_ecosim.nc
FRCNAME == /home/am/ROMS/trunk/Data/ROMS/Forcing/biotoy_frc.nc
BPARNAM = ROMS/External/ecosim.in
#undef BIO_FASHAM
#define ECOSIM
(File: biotoy_ini_ecosim.nc, Rec=0001, Index=1)
- free-surface
- Fortran runtime error: Array reference out of bounds for array 'tval', lower bound of dimension 1 exceeded (in file 'get_cycle.f90', at line 151)
vertically integrated v-momentum component
- u-momentum component
- v-momentum component
- potential temperature
(Min = 7.19653463E+00 Max = 2.20842991E+01)
- salinity
(Min = 3.42398605E+01 Max = 3.52679787E+01)
Al
Look at this topic, your problem looks like it is related.
viewtopic.php?t=1192
I think you may need to update your code ...
Thank you very much, bronwyn !
I manage to run it after updated the code
Al
Al
