pyroms -- a suite of tools for working with ROMS in Python
hetland
#1 Unread post by hetland »
NOTE: THIS SECTION USED TO BE ABOUT PYROMS, WHICH HAS CEASED DEVELOPMENT. PLEASE USE OCTANT INSTEAD.
I have started to create a tool suite for working with ROMS in python, called octant. You can get the source and see other project resources at
http://octant.google.com/
This package is based on pyroms. The name has been changes, and the code base rearranged to make it possible for other C-Grid based models (notably GETM) to use the common code base.
Right now, I have some basic tools for reading roms netcdf files, working with s-coordinates, and grid generation. What is there is pretty solid, but not super well documented. I hope to develop more tools soon. Some of the things I would like to do are offline calculation of tracer advection (using pieces of step_t) and floats. I would like to add more support for simple visualization, and initial, boundary, and forcing file creation.
You are all invited to help. Let me know if you would like to be a member of the project. Sign up for a gmail account, if you don't already have one, and send me a note.
RubenDiez-Lazaro
#2 Unread post by RubenDiez-Lazaro »
Great...
I think that portable, versatile, open and fast python scripts will replace in the future a lot of slow and ad-hoc matlab code...
turuncu
Re: pyroms -- a suite of tools for working with ROMS in Python
#3 Unread post by turuncu »
I try to install pyroms but i get following error messages when importing pyroms,
/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/pyroms/Dataset.py:65: UserWarning: netCDF4 not found -- using pupynere.
warnings.warn('netCDF4 not found -- using pupynere.')
File "<stdin>", line 1, in <module>
File "/Library/Frameworks/Python.framework/Versions/2.5/lib/python2.5/site-packages/pyroms/__init__.py", line 15, in <module>
from Dataset import Dataset, MFDataset
ImportError: cannot import name MFDataset
I am using Mac OS X Leopard and i install other required tools such as python netCDF4, HDF5, NETCDF4, scipy, numpy etc. and each of them working successfully under python.
Any suggestions will be helpful.
best,
--ufuk
linzhenhua
#4 Unread post by linzhenhua »
Hello,with limited python knowledge,I think there is something wrong with your netcdf4-python install.
Can you use the netcdf4-python packages? Try "import netCDF4" to see whether it works or not.
turuncu
#5 Unread post by turuncu »
yes, i could import netCDF4 module without error. The version of it is 0.7.4.
best,
--ufuk
hetland
#6 Unread post by hetland »
This problem is due to the changes in the netCDF4 API. Basically, the multifile support has been folded into the regular netCDF4 object. In other words, there is no more MFNetCDF4.
I would recommend that you use the newer package (that has already fixed this bug) called octant. It is very similar to the old code, but it separates the model dependent code so that other models (in particular GETM) can also use the common code base. The name change was done to be more inclusive of other models..
Get it at
http://octant.googlecode.com
OCTANT (Ocean C-grid model seTup and Analysis Toolkit) is a suite of tools based on the python/numpy/matplotlib scientific python suite. NetCDF I/O is based on the NetCDF4-python package.
The toolkit contains general modeling tools for dealing with arrays, diagnosing standard properties, curvilinear grid generation, and interpolation. Specific tools are also included for ROMS and GETM.
Note, I have stopped work on pyroms, and all of the active work will be on octant.
