Cygwin with 2 processors
drewa
#1 Unread post by drewa »
I can't seem to get ROMS run on both processors. It successfully runs on one but I want to use both. I've tried compiling and running both the INLET_TEST and UPWELLING test case with different results.
To compile, I'm using the bash script and have set the parallel flag to 1 in the file. I compile using ./build.bash -j 2
The UPWELLING case will compile but INLET_TEST won't. The error message I get for the INLET_TEST case is:
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include set_ngfldr.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include set_weights.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include wrt_diags.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include wrt_floats.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include wrt_hessian.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include wrt_rst.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include mod_nesting.f90
cd /ROMS/Projects/inlet_test/Build; g95 -c -fno-second-underscore -O2 -O3 -ffast-math -I/usr/local/mct/include -ffree-form -ffixed-form swmod2.f90
Error: Can't open included file 'mpif.h'
make: *** [/ROMS/Projects/inlet_test/Build/swmod2.o] Error 1
I modified these lined in CYGWIN-g95.mk to try and direct things to MPIF.H
ifdef USE_ARPACK
ifdef USE_MPI
# PARPACK_LIBDIR ?= /usr/local/lib
PARPACK_LIBDIR ?= /ROMS/Lib/ARPACK/PARPACK/EXAMPLES/MPI
LIBS += -L$(PARPACK_LIBDIR) -lparpack
endif
# ARPACK_LIBDIR ?= /usr/local/lib
LIBS += -L$(ARPACK_LIBDIR) -larpack
endif
when I try to run the compiled UPWELLING, I get:
$ mpirun -np 2 ./oceanM External/ocean_upwelling.in
Process Information:
Thread # 0 (pid= 0) is active.
Tuesday - May 13, 2008 - 2:48:15 PM
READ_PhyPar - Error while processing line:
Things hang up at that point. A bit more detailed output is:
$ mpirun -np 2 ./oceanM External/ocean_upwelling.in &
[2] 5392
drewa@Drew_Dell /roms/projects/ocean_upwelling
$ mpiexec_Drew_Dell (handle_stdin_input 1067): stdin problem; if pgm is run in background, redirect from /dev/null
mpiexec_Drew_Dell (handle_stdin_input 1068): e.g.: mpiexec -n 4 a.out < /dev/null &
Tuesday - May 13, 2008 - 2:53:17 PM
I'm at a loss as to where to look to get things running right.
Thanks for the help
drew
Do you know that a simple "hello, world" sort of MPI program runs?
drewa
#3 Unread post by drewa »
I thought I was good to go with the install but I'll look into it more. Thanks
m.hadfield
As far as I know, ROMS with Cygwin g95 has not yet been adapted to support MPI (though I expect it could be, so if you get it working, please contribute the source to the trunk).
Another option for ROMS parallelisation with Cygwin is Gfortran with OpenMP. I have tested this option: the executable builds OK and sometimes runs OK, but other times it hangs for no obvious reason.
