Cygwin compilation error
foropeza
#1 Unread post by foropeza »
I am following the tutorial: Installing ROMS in Windows XP/Vista (via Cygwin) but when i was trying to compile i get this error:
$ ./build.bash
./build.bash: line 40: $'\r': command not found
./build.bash: line 43: $'\r': command not found
./build.bash: line 46: syntax error near unexpected token `$'in\r''
'/build.bash: line 46: ` case "$1" in
does any one can help me with this, thanks in advance.
this took me 6 seconds to find an answer to your question.
Use the Google search option,
search.php
and enter
and see what you get.
foropeza
#3 Unread post by foropeza »
Ok, Thank you it was a "dos2unix" problem i run it to the build.bash file and it is compiling now!, thanks again
