Compile error in newer ROMs revision
jearly
#1 Unread post by jearly »
Compiling for my model with the latest ROMs revision, 177, results in the following error:
cd /Users/jearly/Documents/ROMSProjects/FPMonopole/Build; gfortran -c -frepack-arrays -ftree-vectorize -msse3 -fopenmp -O3 -ffast-math -ffree-form -ffree-line-length-none analytical.f90
analytical.f90:275.21:
      integer :: Istr, IstrR, IstrT, IstrU, Iend, IendR, IendT
                    1
Error: Symbol 'istr' at (1) already has basic type of INTEGER
followed by a number of other similar errors. I tried rolling back to revision 148, which I had been using previously, and it compiled with no problems. I filed this under 'bugs' simply because it changed between revisions, but could this error be something on my end?
Jeffrey
can u tell us what analytical routine this was in?
jearly
#3 Unread post by jearly »
Not only did I fail to provide a complete problem description, but I also failed to realize just how obvious my problem was. Ultimately I was using the ana_grid.h rev 148 to compile rev 177 with -- doing a diff between revisions makes it obvious why it failed.
So nevermind! Case closed.
Jeffrey
