ROMS on AMD linux pc with ifort 8.1
shilo
#1 Unread post by shilo »
Hi to all ,
Did any of you try to run roms on AMD pc using intel fortran compiler?
I compiled roms on my AMD using ifort 8.1 but failed to run the model, with severe error 168. With pgf90 the model runs great.
Thank in advance for any help
Elad Shilo
lasarux
#2 Unread post by lasarux »
I compiled ROMS with ifort 8.1 but I couldn't probe it. Could you contact with me at pgracia@iter.es in order to make the same test?
Thank you in advance,
Pedro A. Gracia Fajardo
http://www.iter.es
rsignell
No problem running on AMD with IFORT 8.1
#3 Unread post by rsignell »
Elad,
As you can see from the benchmark results at
http://cove.whoi.edu/~rsignell/roms/bench
I had no problem running ROMS on AMD with Intel Fortran 8.1.
I used
FFLAGS="-ip -O2 -xW"
if that is useful.
Are you using OpenMP or MPI? If MPI, could it be that you are using LAM compiled with PGI, but then using Ifort 8.1 for ROMS? I think there could be some issues there, since in the LAM doc it says you should use the same compiler for both.
-Rich SIgnell
