make_grid
fdaryabor
make_grid
#1 Unread post by fdaryabor »
Hi
When I execute make_grid in matlab I see follow error:
>> make_grid
Making the grid: ../Run/ROMS_FILES/roms_grd.nc
Title: Benguela Test Model
Resolution: 1/3 deg
Create the grid file...
LLm = 23
MMm = 31
Fill the grid file...
Compute the metrics...
??? Error: File: subsref.m Line: 128 Column: 9
"subs" previously appeared to be used as a function or command, conflicting with its use here as the name of a variable.
A possible cause of this error is that you forgot to initialize the
variable, or you have initialized it implicitly using load or eval.
Error in ==> netcdf.subsref at 52
result = subsref(result, s);
Error in ==> get_metrics at 35
latu=nc{'lat_u'}(:);
Error in ==> make_grid at 95
[pm,pn,dndx,dmde]=get_metrics(grdname);
Please you guide me
Best Regards
F.Daryabor
marceloandrioni
#2 Unread post by marceloandrioni »
Hi, subs is the name of a variable in the program, but is also the name of a matlab function.
"which subs" will tell you if you have the subs function and in which directory it is. If you do, try removing that directory from your matlab path.
fdaryabor
#3 Unread post by fdaryabor »
marceloandrioni wrote:Hi, subs is the name of a variable in the program, but is also the name of a matlab function.
Tank you my friend for your guide.
Best Regards
F.Daryabor
