Hello!
I'm new to ROMS and have started trying the upwelling example, but I'm receiving this strange error message:
:>make upwelling
makefile:226: INCLUDING FILE Build/make_macros.mk WHICH CONTAINS APPLICATION-DEPENDENT MAKE DEFINITIONS
make: *** No rule to make target `upwelling'. Stop.
Does anyone have a clue ? I'm really kind a lost around here... :
help to a beginner
thank you for your help!
I think I've fixed it, but now I'm facing this problem under the command " make"(upw case)
cd Build; ifort -c -ip -O3 -xW white_noise.f90
Invalid_sym_id for MP_SCATTER, -352301747
fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
compilation aborted for white_noise.f90 (code 3)
Them I've tried it on another machine and received back:
fortcom: Error: mod_parallel.f90, line 18: Cannot open include file 'mpif.h'
> include 'mpif.h'
> fortcom: Error: mod_parallel.f90, line 76: This symbol must be a defined parameter or an argument of an inquiry
> function that evaluates to a compile-time constant. [MPI_DOUBLE_PRECISION]
> integer, parameter :: MP_FLOAT = MPI_DOUBLE_PRECISION
> fortcom: Error: mod_parallel.f90, line 76: This name does not have a type, and must have an explicit type.
> compilation aborted for mod_parallel.f90 (code 1)
> make: *** [Build/mod_parallel.o] Error 1
Does anyone have a good tip about what's happening at any of this cases?
> include 'mpif.h'
Don't you love it? This is saying your compiler can't handle compiling white_noise.f90. Have you looked at white_noise.f90 in the Build directory? It's likely that you don't actually need this file so you could try renaming white_noise.F to white_noise.F.orig in the ROMS/Utility directory which will prevent make from trying to compile it.macassis wrote: fortcom: Severe: **Internal compiler error: segmentation violation signal raised** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
Do you have MPI installed on this second computer? Why not try serial mode first?fortcom: Error: mod_parallel.f90, line 18: Cannot open include file 'mpif.h'
> include 'mpif.h'
uops,thanx, but nope! tried renaming the file at the first machine and it gave me back:
make: *** [Build/white_noise.o] Error 3
do you have another tip?
- m.hadfield
You are building the model with MPI enabled. As Kate has asked, do you really want to do that? Even if you do want to use MPI eventually, you should try serial mode first.
If you are not deliberately trying to build the model with MPI enabled, then something is happening behind the scenes and you need to find out what. MPI mode is controlled by the preprocessor macro USE_MPI. Are you defining it to a non-empty value?
