Hi everyone!!
I installed ROMS in my windows PC under cygwin using g95 compiler, then when the installation was completed I compiled to prove the installation using make and the compilation was succesfully without errors, but when I tried to run the upwelling test case using:
& ./oceanS<ocean_upw>&log&
I received this message:
$ ./oceanS<ocean_upw>&log&
[2388]
And here the model stoped working and I received this message:
$ 12 [main] oceanS 2388 _cygtls::handle_exceptions: Error while dumping state (probably corrupted stack)
Then I typed: tail log and I received the next message:
tail log
MinVolume = 2.74206945480521E+07
MaxVolume = 1.50000000000000E+08
Max/MIn = 5.47032095547906E+00
NL ROMS/TOMS: started time-stepping:(TimeSteps: 00000001 - 00001440)
STEP time[DAYS] KINETIC_ENRG POTEN_ENRG TOTAL_ENRG
0 0.000000 0.000000E+00 8.935171E+02 8.935171E+02
NET_VOLUME trd
7.285422E+11 0
[1]+ Segmentation fault (core dumped) ./oceanS <ocean_upw>&log&
Somebody could help me to solve my problem??
What do I have to do??
Cheers
-- Luis A.--
Problems Running Upwelling Test Case
- luis.chetu.83
look at the whole log file and see if there is any information that may answer why it went wrong. Did you compile th eprogram to run the upwelling case?
When i run upwelling i get:
Minimum X-grid spacing, DXmin = 1.00000000E+00 km
Maximum X-grid spacing, DXmax = 1.00000000E+00 km
Minimum Y-grid spacing, DYmin = 1.00000000E+00 km
Maximum Y-grid spacing, DYmax = 1.00000000E+00 km
Minimum Z-grid spacing, DZmin = 1.57503054E+00 m
Maximum Z-grid spacing, DZmax = 2.30290891E+01 m
Minimum barotropic Courant Number = 2.22358627E-01
Maximum barotropic Courant Number = 5.42494240E-01
Maximum Coriolis Courant Number = 2.47800000E-02
Maximum grid stiffness ratios: rx0 = 6.931666E-02 (Beckmann and Haidvogel)
rx1 = 1.188435E+00 (Haney)
Initial basin volumes: TotVolume = 3.88437558836196E+11 m3
MinVolume = 1.61682903648599E+06 m3
MaxVolume = 2.30290890585923E+07 m3
Max/Min = 1.42433668241409E+01
NL ROMS/TOMS: started time-stepping:( TimeSteps: 00000001 - 00001440)
STEP time[DAYS] KINETIC_ENRG POTEN_ENRG TOTAL_ENRG NET_VOLUME trd
0 0.00000 0.000000E+00 6.579497E+02 6.579497E+02 3.884376E+11 0
DEF_HIS - creating history file: ocean_his.nc
DEF_AVG - creating average file: ocean_avg.nc
DEF_DIAGS - creating diagnostics file: ocean_dia.nc
1 0.00347 3.268255E-13 6.579497E+02 6.579497E+02 3.884376E+11 0
I wrote up the sort of output ROMS is giving you here:
https://www.myroms.org/wiki/index.php/Standard_Output
- luis.chetu.83
- luis.chetu.83
