I recently encountered an error when running a new ROMS simulation: "NLM: CHECKVARS_NF90 - unable to find model variable: rzeta." I looked up this variable and found it is related to the trajectory module. However, I didn't intend to run this module. Both my .in and .h files are based on previous templates. No related errors occurred in the previous simulation. I suspect that I mistakenly enabled the relevant module. Does anyone know how to solve this problem? Thank you so much!
.h file
#define SOLVE3D /* - use if solving 3D primitive equations */
/*commented section*/
/*#ifdef SOLVE3D*/
/*# define RI_SPLINES */ /* - use if splines reconstruction for vertical sheer */
/*#endif*/
/* Boundary conditions...careful with grid orientation */
#define RADIATION_2D /* - use if tangential phase speed in radiation conditions */
#define UV_ADV /* - use to activate advection terms */
#define UV_COR /* - use to activate Coriolis term */
#define UV_LDRAG /* - use to activate linear bottom friction */
#define UV_VIS2 /* - use to activate harmonic horizontal mixing */
#define MIX_S_UV /* - use if mixing along constant S-surfaces */
#define MIX_GEO_TS /* - use if mixing along geopotential (constant depth) surfaces*/
#define SPLINES_VDIFF /* - use if splines reconstruction of vertical diffusion */
#define SPLINES_VVISC /* - use if splines reconstruction of vertical viscosity */
#define DJ_GRADPS /* - use if splines density Jacobian (Shchepetkin, 2000) */
#define TS_DIF2 /* - use to turn ON or OFF harmonic horizontal mixing */
#define SALINITY /* - use if having salinity */
#define GLS_MIXING /*use if Generic Length-Scale mixing*/
/* - use if Generic Length-Scale mixing or - use if Mellor/Yamada Level-2.5 closure */
# define KANTHA_CLAYSON /* - use if Kantha and Clayson stability function */
# define N2S2_HORAVG /* - use if horizontal smoothing of buoyancy/shear */
# define RI_SPLINES /* - use if splines reconstruction for vertical sheer */
#else
# define ANA_VMIX /* - use if analytical vertical mixing coefficients */
#define ANA_SMFLUX /* - use if analytical surface momentum stress */
#define ANA_BTFLUX /* - use if analytical bottom temperature flux */
#define ANA_BSFLUX /* - use if analytical bottom salinity flux */
#define T_PASSIVE
#define ANA_BPFLUX
#define ANA_SPFLUX
#define RIVERPLUME1
#define TS_MPDATA_LIMIT
#define TRACER_DECAY
/* tide */
#define SSH_TIDES
#define UV_TIDES
#define RAMP_TIDES
#define ADD_FSOBC
#define ADD_M2OBC
/* biological module */
#define NPZD_POWELL
#define TS_C4VADVECTION
#define TS_SVADVECTION
#define TS_U3HADVECTION
/* general */
#define CURVGRID /* - use if curvilinear coordinates grid */
#define MASKING /* - use if land/sea masking */
#define WET_DRY /* - use to activate wetting and drying */
#define NONLIN_EOS /* - use if using nonlinear equation of state */
/* surface forcing */
#ifdef SOLVE3D /* - use if solving 3D primitive equations */
# define CORE_FORCING
# define BULK_FLUXES /* - use if bulk fluxes computation */
# define CCSM_FLUXES
# if defined BULK_FLUXES || defined CCSM_FLUXES
# define LONGWAVE_OUT /* - use if computing outgoing longwave radiation */
# undef DIURNAL_SRFLUX /* - use to impose shortwave radiation local diurnal cycle */
# define SOLAR_SOURCE /* - use if solar radiation source term */
# define EMINUSP /* - use if computing E-P */
# undef ANA_SRFLUX /* use if analytical surface shortwave radiation flux */
# undef ALBEDO_CLOUD
# define ALBEDO_CURVE /* for water */
# undef ALBEDO_FILE /* for both */
# undef LONGWAVE /* - use if computing net longwave radiation */
/* output stuff */
#define AVERAGES /* - use if writing out time-averaged data */
#define PERFECT_RESTART /* - use to include perfect restart variables */
#ifdef PERFECT_RESTART /* - use to include perfect restart variables */
/*Commented section*/
/*# undef AVERAGES*/ /* - use if writing out time-averaged data */
# undef DIAGNOSTICS_TS /* - use if writing out tracer diagnostics */
# undef DIAGNOSTICS_UV /* - use if writing out momentum diagnostics */
# define OUT_DOUBLE /* - use if writing double precision output fields */
# define RST_SINGLE /* - use if writing single precision restart fields */
/* sediment CPPDEFS */
#undef SEDIMENT
.in file
! Application title.
TITLE = River Plume Test 1, flow across u-face grid cell
! C-preprocessing Flag.
MyAppCPP = RIVERPLUME1
VARNAME = /home/ubuntu/roms/project/yangjiang_5km_Po/varinfo.yaml
! Number of nested grids.
Ngrids = 1
NestLayers = 1
GridsInLayer = 1
! these parameters correctly.
Lm == 438 ! Number of I-direction INTERIOR RHO-points
Mm == 428 ! Number of J-direction INTERIOR RHO-points
N == 15 ! Number of vertical levels
NPT = 1 ! Number of inactive passive tracers
NtileI == 12 ! I-direction partition
NtileJ == 16 ! J-direction partition
! Set horizontal and vertical advection schemes for active and inert
! tracers. A different advection scheme is allowed for each tracer.
! For example, a positive-definite (monotonic) algorithm can be activated
! for salinity and inert tracers, while a different one is set for
! temperature. [1:NAT+NPT,Ngrids] values are expected.
! Keyword Advection Algorithm
! A4 4th-order Akima (horizontal/vertical)
! C2 2nd-order centered differences (horizontal/vertical)
! C4 4th-order centered differences (horizontal/vertical)
! HSIMT 3th-order HSIMT-TVD (horizontal/vertical)
! MPDATA recursive flux corrected MPDATA (horizontal/vertical)
! SPLINES parabolic splines (only vertical)
! SU3 split third-order upstream (horizontal/vertical)
! U3 3rd-order upstream-biased (only horizontal)
! The user has the option of specifying the full Keyword or the first
! two letters, regardless if using uppercase or lowercase. If nested
! grids, specify values for each grid (see glossary below).
Hadvection == A4 \ ! temperature
MPDATA \ ! salinity
HSIMT ! Po
Vadvection == A4 \ ! temperature
MPDATA \ ! salinity
HSIMT ! Po
! Adjoint-based algorithms can have different horizontal and schemes
! for active and inert tracers.
ad_Hadvection == U3 \ ! temperature
U3 \ ! salinity
U3 ! Po
C4 \ ! salinity
C4 ! Po
! for each boundary segment per nested grid for each state variable.
! Each tracer variable requires [1:4,1:NAT+NPT,Ngrids] values. Otherwise,
! [1:4,1:Ngrids] values are expected for other variables. The boundary
! order is: 1=west, 2=south, 3=east, and 4=north. That is, anticlockwise
! starting at the western boundary.
! The keyword is case insensitive and usually has three characters. However,
! it is possible to have compound keywords, if applicable. For example, the
! keyword "RadNud" implies radiation boundary condition with nudging. This
! combination is usually used in active/passive radiation conditions.
! Cha Chapman_implicit (free-surface)
! Che Chapman_explicit (free-surface)
! Cla Clamped
! Clo Closed
! Fla Flather (2D momentum) _____N_____ j=Mm
! Gra Gradient | 4 |
! Nes Nested (refinement) | |
! Nud Nudging 1 W E 3
! Per Periodic | |
! Rad Radiation |_____S_____|
! Red Reduced Physics (2D momentum) 2 j=1
! Shc Shchepetkin (2D momentum) i=1 i=Lm
! W S E N
! e o a o
! s u s r
! t t t t
! h h
! 1 2 3 4
LBC(isFsur) == Che Che Che Che ! free-surface
LBC(isUbar) == Shc Shc Shc Shc ! 2D U-momentum
LBC(isVbar) == Shc Shc Shc Shc ! 2D V-momentum
LBC(isUvel) == RadNud RadNud RadNud RadNud ! 3D U-momentum
LBC(isVvel) == RadNud RadNud RadNud RadNud ! 3D V-momentum
LBC(isMtke) == Rad Rad Rad Rad ! mixing TKE
LBC(isTvar) == RadNud RadNud RadNud RadNud \ ! temperature
RadNud RadNud RadNud RadNud \ ! salinity
Rad Rad Rad Rad ! Po
! conditions keywords.
ad_LBC(isFsur) == Che Che Che Che ! free-surface
ad_LBC(isUbar) == Shc Shc Shc Shc ! 2D U-momentum
ad_LBC(isVbar) == Shc Shc Shc Shc ! 2D V-momentum
ad_LBC(isUvel) == RadNud RadNud RadNud RadNud ! 3D U-momentum
ad_LBC(isVvel) == RadNud RadNud RadNud RadNud ! 3D V-momentum
ad_LBC(isMtke) == Rad Rad Rad Rad ! mixing TKE
ad_LBC(isTvar) == RadNud RadNud RadNud RadNud \ ! temperature
! conservation, except if tidal forcing is enabled. [1:Ngrids].
VolCons(west) == F ! western boundary
! Time-Stepping parameters.
NTIMES == 174240 !total time = NTIMES*DT (s)
DT == 60.0d0 !unit = (s)
NDTFAST == 30
! Number of timesteps for computing observation impacts during the
! analysis-forecast cycle.
NTIMES_ANA == 0 ! analysis interval
NTIMES_FCT == 0 ! forecast interval
ERstr = 1
ERend = 1
Nouter = 1
Ninner = 1
Nsaddle = 1
Nintervals = 1
! Input/Output parameters.
NRREC == -1
LcycleRST == T
NRST == 60
NSTA == 1
NFLT == 0
NINFO == 1
! Output history, quicksave, average, and diagnostic files parameters.
LDEFOUT == T
NHIS == 60 ! record one time every NHIS steps (every NHIS*DT (s))
NDEFHIS == 0
NQCK == 0
NDEFQCK == 0
NTSAVG == 1
NAVG == 60
NDEFAVG == 0
NTSDIA == 1
NDIA == 60
NDEFDIA == 0
LcycleTLM == F
NTLM == 60
NDEFTLM == 0
LcycleADJ == F
NADJ == 60
NDEFADJ == 0
NSFF == 60
NOBC == 60
! GST output and check pointing restart parameters.
LmultiGST = F ! one eigenvector per file
MaxIterGST = 60 ! maximum number of iterations
Ritz_tol = 1.0d-15
TNU2 == 8*5.0d0 ! m2/s
TNU4 == 8*0.0d0 ! m4/s
ad_TNU2 == 0.0d0 0.0d0 ! m2/s
ad_TNU4 == 0.0d0 0.0d0 ! m4/s
VISC2 == 3.5d0 ! m2/s
VISC4 == 0.0d0 ! m4/s
ad_VISC2 == 0.0d0 ! m2/s
ad_VISC4 == 0.0d0 ! m4/s
! Logical switches (TRUE/FALSE) to increase/decrease horizontal viscosity
! and/or diffusivity in specific areas of the application domain (like
! sponge areas) for the desired application grid.
LuvSponge == F ! horizontal momentum
LtracerSponge == F F F ! temperature, salinity, inert
AKT_BAK == 8*1.0d-6 ! m2/s
ad_AKT_fac == 1.0d0 1.0d0 1.0d0 ! nondimensional
AKV_BAK == 1.0d-5 ! m2/s
! Upper threshold values to limit vertical mixing coefficients computed
! from vertical mixing parameterizations. Although this is an engineering
! fix, the vertical mixing values inferred from ocean observations are
! rarely higher than this upper limit value.
AKT_LIMIT == 1.0d-3 1.0d-3 1.0d-3 ! m2/s
AKV_LIMIT == 1.0d-3 ! m2/s
AKK_BAK == 5.0d-6 ! m2/s
AKP_BAK == 5.0d-6 ! m2/s
TKENU2 == 0.0d0 ! m2/s
TKENU4 == 0.0d0 ! m4/s
! GLS_P == 3.0d0 ! K-epsilon
! GLS_M == 1.5d0
! GLS_N == -1.0d0
! GLS_Kmin == 7.6d-6
! GLS_Pmin == 1.0d-12
! GLS_CMU0 == 0.5477d0
! GLS_C1 == 1.44d0
! GLS_C2 == 1.92d0
! GLS_C3M == -0.4d0
! GLS_C3P == 1.0d0
! GLS_SIGK == 1.0d0
! GLS_SIGP == 1.30d0
GLS_P == -1.0d0 ! K-omega
GLS_M == 0.5d0
GLS_N == -1.0d0
GLS_Kmin == 7.6d-6
GLS_Pmin == 1.0d-12
GLS_C1 == 0.555d0
GLS_C2 == 0.833d0
GLS_C3M == -0.6d0
GLS_C3P == 1.0d0
GLS_SIGK == 2.0d0
GLS_SIGP == 2.0d0
CHARNOK_ALPHA == 1400.0d0 ! Charnok surface roughness
RDRG == 3.0d-04 ! m/s
RDRG2 == 3.0d-03 ! nondimensional
Zob == 0.02d0 ! m
Zos == 0.02d0 ! m
BLK_ZQ == 2.0d0 ! air humidity
BLK_ZT == 2.0d0 ! air temperature
BLK_ZW == 2.0d0 ! winds
! Minimum depth for wetting and drying.
DCRIT == 0.50d0 ! m
! Various parameters.
WTYPE == 1
LEVSFRC == 15
LEVBFRC == 1
! Set vertical, terrain-following coordinates transformation equation and
! stretching function (see below for details), [1:Ngrids].
Vtransform == 2 ! transformation equation
Vstretching == 4 ! stretching function
! Vertical S-coordinates parameters (see below for details), [1:Ngrids].
THETA_S == 8.0d0 ! surface stretching parameter
THETA_B == 4.0d0 ! bottom stretching parameter
TCLINE == 20.0d0 ! critical depth (m)
RHO0 = 1025.0d0 ! kg/m3
BVF_BAK = 1.0d-5 ! 1/s2
! If tide generating forces, set switch (T/F) to apply a 18.6-year lunar
! nodal correction to equilibrium tide constituents.
Lnodal = T
! NetCDF units attribute.
DSTART = 0.0d0 ! days
TIDE_START = 0.0d0 ! days
TIME_REF = 19700101.0d0 ! yyyymmdd.dd
! internally, [1:Ngrids].
TNUDG == 2*360.0d0 ! days
ZNUDG == 0.0d0 ! days
M2NUDG == 0.0d0 ! days
M3NUDG == 0.0d0 ! days
OBCFAC == 10.0d0 ! nondimensional
R0 == 1027.0d0 ! kg/m3
T0 == 25.0d0 ! Celsius
S0 == 35.0d0 ! nondimensional
TCOEF == 1.7d-4 ! 1/Celsius
SCOEF == 7.6d-4 ! nondimensional
GAMMA2 == 1.0d0
! Logical switches (TRUE/FALSE) to activate horizontal momentum transport
! point Sources/Sinks (like river runoff transport) and mass point
! Sources/Sinks (like volume vertical influx), [1:Ngrids].
LuvSrc == F ! horizontal momentum transport
LtracerSrc == F F F ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to read and process climatology fields.
! See glossary below for details.
LsshCLM == F ! sea-surface height
Lm2CLM == T ! 2D momentum
Lm3CLM == T ! 3D momentum
LtracerCLM == T T T ! temperature, salinity, inert
! Logical switches (TRUE/FALSE) to nudge the desired climatology field(s).
! If not analytical climatology fields, users need to turn ON the logical
! switches above to process the fields from the climatology NetCDF file
! that are needed for nudging. See glossary below for details.
LnudgeM2CLM == F ! 2D momentum
LnudgeTCLM == F F F ! temperature, salinity, inert
DstrS == 0.0d0 ! starting day
DendS == 0.0d0 ! ending day
KstrS == 1 ! starting level
KendS == 1 ! ending level
Lstate(isFsur) == F ! free-surface
Lstate(isTvar) == F F F ! NT tracers
! Logical switches (TRUE/FALSE) to specify the state variables for
! which Forcing Singular Vectors or Stochastic Optimals is required.
Fstate(isFsur) == F ! free-surface
Fstate(isTvar) == F F F ! NT tracers
Fstate(isUstr) == T ! surface U-stress
Fstate(isVstr) == T ! surface V-stress
Fstate(isTsur) == F F F ! NT surface tracers flux
! Stochastic Optimals time decorrelation scale (days) assumed for
! red noise processes.
SO_decay == 2.0d0 ! days
! Stochastic Optimals surface forcing standard deviation for
! dimensionalization.
SO_sdev(isFsur) == 1.0d0 ! free-surface
SO_sdev(isTvar) == 1.0d0 1.0d0 1.0d0 ! NT tracers
SO_sdev(isUstr) == 1.0d0 ! surface U-stress
SO_sdev(isVstr) == 1.0d0 ! surface V-stress
SO_sdev(isTsur) == 1.0d0 1.0d0 1.0d0 ! NT surface tracers flux
! HISTORY output file.
Hout(idUvel) == T ! u 3D U-velocity
Hout(idTvar) == T T T ! temp, salt temperature and salinity
Hout(idTair) == F ! Tair surface air temperature
Hout(idDano) == T ! rho density anomaly
Hout(idVvis) == T ! AKv vertical viscosity
Hout(idTdif) == T ! AKt vertical T-diffusion
Hout(idSdif) == T ! AKs vertical Salinity diffusion
Hout(idHsbl) == T ! Hsbl depth of surface boundary layer
Hout(idHbbl) == T ! Hbbl depth of bottom boundary layer
Hout(idMtke) == T ! tke turbulent kinetic energy
Hout(idMtls) == T ! gls turbulent length scale
! tracers other than biological and sediment tracers into the HISTORY
! output file. An inert passive tracer is one that it is only advected and
! diffused. Other processes are ignored. These tracers include, for example,
! dyes, pollutants, oil spills, etc. NPT values are expected. However, these
! switches can be activated using compact parameter specification.
Hout(inert) == T ! dye_01, ... inert passive tracers
! QUICKSAVE output file.
Qout(idUvel) == F ! u 3D U-velocity
Qout(idTvar) == F F F ! temp, salt temperature and salinity
Qout(idsurT) == T T T ! temp_sur, salt_sur surface temperature and salinity
Qout(idTair) == F ! Tair surface air temperature
! tracers other than biological and sediment tracers into the QUICKSAVE
Qout(inert) == T ! dye_01, ... inert passive tracers
Qout(Snert) == T ! dye_01_sur, ... surface inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of time-averaged
! fields into AVERAGE output file.
Aout(idUvel) == T ! u 3D U-velocity
Aout(idTvar) == T T T ! temp, salt temperature and salinity
Aout(idTair) == F ! Tair surface air temperature
Aout(idv2dD) == F ! vbar_detided detided 2D V-velocity
Aout(idTTav) == F F ! temp_2, ... quadratic <t*t> tracer terms
Aout(idUTav) == F F ! u_temp, ... quadratic <u*t> tracer terms
Aout(idVTav) == F F ! v_temp, ... quadratic <v*t> tracer terms
Aout(iHUTav) == F F ! Huon_temp, ... tracer volume flux, <Huon*t>
Aout(iHVTav) == F F ! Hvom_temp, ... tracer volume flux, <Hvom*t>
! tracers other than biological and sediment tracers into the AVERAGE file.
Aout(inert) == T ! dye_01, ... inert passive tracers
! Logical switches (TRUE/FALSE) to activate writing of time-averaged,
! 2D momentum (ubar,vbar) diagnostic terms into DIAGNOSTIC output file.
Dout(M2rate) == T ! ubar_accel, ... acceleration
! 3D momentum (u,v) diagnostic terms into DIAGNOSTIC output file.
Dout(M3rate) == T ! u_accel, ... acceleration
! active (temperature and salinity) and passive (inert) tracer diagnostic
! terms into DIAGNOSTIC output file: [1:NAT+NPT,Ngrids].
Dout(iTrate) == T T T ! temp_rate, ... time rate of change
Dout(iThadv) == T T T ! temp_hadv, ... horizontal total advection
Dout(iTxadv) == T T T ! temp_xadv, ... horizontal XI-advection
Dout(iTyadv) == T T T ! temp_yadv, ... horizontal ETA-advection
Dout(iTvadv) == T T T ! temp_vadv, ... vertical advection
Dout(iThdif) == T T T ! temp_hdiff, ... horizontal total diffusion
Dout(iTxdif) == T T T ! temp_xdiff, ... horizontal XI-diffusion
Dout(iTydif) == T T T ! temp_ydiff, ... horizontal ETA-diffusion
Dout(iTsdif) == T T T ! temp_sdiff, ... horizontal S-diffusion
Dout(iTvdif) == T T T ! temp_vdiff, ... vertical diffusion
NUSER = 0
USER = 0.d0
! Input and Output files processing library to use:
! [2] Serial or Parallel I/O with Parallel-IO (PIO) library (MPI only)
INP_LIB = 1
OUT_LIB = 1
! PIO library methods for reading/writing NetCDF files:
! [0] parallel read and write of PnetCDF (CDF-5, not recommended)
! [1] parallel read and write of NetCDF3 (64-bit offset)
! [2] serial read and write of NetCDF3 (64-bit offset)
! [4] parallel read and write of NETCDF4/HDF5
PIO_METHOD = 2
! PIO library MPI processes set-up:
PIO_IOTASKS = 1 ! number of I/O tasks to define
PIO_STRIDE = 1 ! stride in the MPI-ran between I/O tasks
PIO_BASE = 0 ! offset for the first I/O task
! PIO library rearranger methods for moving data between computational and I/O
! processes:
! [1] Box rearrangement
! [2] Subset rearrangement
PIO_REARR = 1
! PIO library rearranger flag for MPI communications between computational
! and I/O processes:
! [0] Point-to-Point (low-level communications)
! [1] Collective (high-level grouped communications)
PIO_REARRCOM = 0
! PIO library rearranger flow control direction flag for MPI communications
! between computational and I/O processes:
! [2] Enable computational to I/O processes only
! [3] Enable I/O to computational processes only
! [4] Disable flow control
PIO_REARRDIR = 0
! PIO rearranger options for computational to I/O processes (C2I):
PIO_C2I_HS = T ! Enable C2I handshake (T/F)
PIO_C2I_Send = T ! Enable C2I Isends (T/F)
PIO_C2I_Preq = 64 ! Maximum pending C2I requests
! PIO rearranger options for I/O to computational processes (I2C):
PIO_I2C_HS = T ! Enable I2C handshake (T/F)
! If OUT_LIB=1, NetCDF-4/HDF5 compression parameters for output files.
NC_SHUFFLE = 1 ! if non-zero, turn on shuffle filter
GRDNAME == /home/ubuntu/roms/project/yangjiang_5km_Po/yangjiang_5km_Po.nc
ININAME == /home/ubuntu/roms/project/yangjiang_5km_Po/data/ic/HYCOM_GLBy0.08_2024_001_ic_YANGJIANG_PO.nc
!ININAME == /home/ubuntu/roms/project/yangjiang_5km/roms_rst.nc !restart file location if available
ITLNAME == roms_itl.nc
IRPNAME == roms_irp.nc
IADNAME == roms_iad.nc
FWDNAME == roms_fwd.nc
ADSNAME == roms_ads.nc
! Input adjoint forcing NetCDF filenames for computing observations
! impacts during the analysis-forecast cycle. If the forecast error
! metric is defined in state-space, then FOInameA and FOInameB should
! be regular adjoint forcing files just like ADSname. If the forecast
! error metric is defined in observation space (OBS_SPACE is activated)
! then the forecast is initialized OIFnameA and OIFnameB (specified in
! s4dvar.in input script) will have the structure of a 4D-Var observation
! file.
FOInameA == roms_foi_a.nc
FOInameB == roms_foi_b.nc
! Input NetCDF filenames for the forecasts initialized from the analysis
! of the current 4D-Var cycle (FCTnameA) and initialized from the analysis
! of the previous 4D-Var cycle (FCTnameB).
FCTnameA == roms_fct_a.nc
FCTnameB == roms_fct_b.nc
! Nesting grids connectivity data: contact points information. This
! NetCDF file is special and complex. It is currently generated using
! the script "matlab/grid/contact.m" from the Matlab repository.
NGCNAME = roms_ngc.nc
! Input lateral boundary conditions file names. The USER has the option
! to separate the required lateral boundary variables into individual
! NetCDF files (NBCFILES > 1), as in the input surface forcing. Also,
! the USER may split input data time records into several NetCDF files
! (monthly, seasonal, or annual). See prologue instructions above. Use
! a single line per entry with a continuation (\) or a vertical bar (|)
! symbol after each entry, except the last one.
NBCFILES == 1 ! number of boundary files
BRYNAME == /home/ubuntu/roms/project/yangjiang_5km_Po/data/bdry/HYCOM_GLBy0.08_2024_Jan2Apr_bdry_YANGJIANG_PO.nc
! Input climatology file names. The USER has the option to separate the
! climatology variables into individual NetCDF files (NCLMFILES > 1),
! as in the input surface forcing. Also, the USER may split input data
! time records into several NetCDF files (monthly, seasonal, or annual).
! See prologue instructions above. Use a single line per entry with a
! continuation (\) or a vertical bar (|) symbol after each entry, except
! the last one.
NCLMFILES == 1 ! number of climatology files
CLMNAME == /home/ubuntu/roms/project/yangjiang_5km_Po/data/clm/HYCOM_GLBy0.08_2024_Jan2Apr_clim_YANGJIANG_PO.nc
! Input climatology nudging coefficients file name.
NUDNAME == roms_nud.nc
! Input Sources/Sinks forcing (like river runoff) file name.
SSFNAME == myrivers.nc
! Input tidal forcing file name.
TIDENAME == /home/ubuntu/roms/project/yangjiang_5km_Po/frc_TPXO9v5_150d.nc
! Input forcing NetCDF file name(s).
! The USER has the option to enter several sets of file names for each
! nested grid. For example, the USER may have different data for the
! wind products, heat fluxes, etc. Alternatively, if the all the forcing
! files are the same for nesting and the data is in its native resolution,
! we could enter only one set of files names and ROMS will replicate those
! files internally to the remaining grids using the plural KEYWORD protocol.
! The model will scan the files and will read the needed data from the first
! file in the list containing the forcing field. Therefore, the order of the
! filenames is critical. If using multiple forcing files per grid, first
! enter all the file names for grid one followed by two, and so on. It is
! also possible to split input data time records into several NetCDF files
! (see Prolog instructions above). Use a single line per entry with a
! the last one.
NFFILES == 1 ! number of unique forcing files
FRCNAME == /home/ubuntu/roms/project/yangjiang_5km_Po/data/forcings/frc_Yangjiang_Po_ERA5_bulkflux_2024_1to4.nc
DAINAME == roms_dai.nc
GSTNAME == roms_gst.nc
RSTNAME == roms_yangjiang_Po_rst.nc
HISNAME == roms_yangjiang_Po_his.nc
QCKNAME == roms_qck.nc
TLMNAME == roms_tlm.nc
TLFNAME == roms_tlf.nc
ADJNAME == roms_adj.nc
AVGNAME == roms_yangjiang_Po_avg.nc
HARNAME == roms_har.nc
DIANAME == roms_dia.nc
STANAME == roms_sta.nc
FLTNAME == roms_flt.nc
! Input ASCII parameter filenames.
APARNAM = s4dvar.in
SPOSNAM = stations.in
FPOSNAM = floats.in
BPARNAM = /home/ubuntu/roms/project/yangjiang_5km_Po/npzd_Powell.in
SPARNAM = sediment.in
USRNAME = MyFile.dat
