Today's (14 May 2025) "develop" branch produces the following compilation errors.
(This is with ifx and the default Linux-ifx.mk file.)
With SOLVE3D, SEDIMENT, and SSW_BBL:
cd /ches/home00/pierre/test/Build_romsM; /usr/local/james/oneapi-2024.0/openmpi-4.1.6-3cwg7q/bin/mpif90 -c -fp-model precise -heap-arrays -O3 -traceback bbl.f90
bbl.f90(499): error #6404: This name does not have a type, and must have an explicit type. [IDTBL]
bottom(i,j,idtbl)=thck_wbl(i,j)
bbl.f90(500): error #6404: This name does not have a type, and must have an explicit type. [IDPCX]
bottom(i,j,idpcx)=phic(i,j)
bbl.f90(501): error #6404: This name does not have a type, and must have an explicit type. [IDPWC]
bottom(i,j,idpwc)=phicw(i,j)
compilation aborted for bbl.f90 (code 1)
make: *** [ROMS/Nonlinear/BBL/Module.mk:14: /ches/home00/pierre/test/Build_romsM/bbl.o] Error 1
GNU Build script command: build_roms.csh -j 4
ROMS source directory: /ches/home00/pierre/ROMS/rutgers_roms_develop20250514
ROMS header file: /ches/home00/pierre/test/minimal.h
ROMS build directory: /ches/home00/pierre/test/Build_romsM
ROMS executable: /ches/home00/pierre/test/romsM
ROMS Application: MINIMAL
Fortran compiler: ifx
Fortran flags: -fp-model precise -heap-arrays -O3 -traceback
Added CPP Options:
cd /ches/home00/pierre/test/Build_romsM; /usr/local/james/oneapi-2024.0/openmpi-4.1.6-3cwg7q/bin/mpif90 -c -fp-model precise -heap-arrays -O3 -traceback bbl_output.f90
bbl_output.f90(794): error #6792: The rank of the allocate-shape-spec-list differs from the rank of the allocate-object. [WRK2D]
allocate ( wrk2d(LBi:UBi, LBj:UBj) )
bbl_output.f90(795): error #6351: The number of subscripts is incorrect. [WRK2D]
wrk2d(LBi:UBi,LBj:UBj)=0.0_r8
bbl_output.f90(797): error #6366: The shapes of the array expressions do not conform. [WRK2D]
wrk2d=SQRT(BBL(ng)%bustrcwmax*BBL(ng)%bustrcwmax+ &
bbl_output.f90(800): error #6284: There is no matching specific function for this generic function reference. [NF_FWRITE2D]
status=nf_fwrite2d(ng, model, S(ng)%ncid, idUVwc, &
compilation aborted for bbl_output.f90 (code 1)
make: *** [ROMS/Nonlinear/BBL/Module.mk:14: /ches/home00/pierre/test/Build_romsM/bbl_output.o] Error 1
Added CPP Options:
Thanks for your time. Pierre
