Resolution, Grid 01: 343x348x35, Parallel Nodes: 64, Tiling: 8x8
210240 ntimes Number of timesteps for 3-D equations.
150.000 dt Timestep size (s) for 3-D equations.
F LcycleRST Switch to recycle time-records in restart file.
576 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
1 nSTA Number of timesteps between the writing of data
the stations file.
48 nHIS Number of timesteps between the writing fields
into history file.
576 ndefHIS Number of timesteps between the creation of new
history files.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
time-averaged data.
17520 nAVG Number of timesteps between the writing of
17520 ndefAVG Number of timesteps between the creation of new
time-averaged files.
5.0000E+00 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
5.0000E+00 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E+00 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
2.0000E+00 blk_ZQ Height (m) of surface air humidity measurement.
1.0000E-01 Dcrit Minimum depth for wetting and drying (m).
1 lmd_Jwt Jerlov water type.
8.0000E+00 theta_s S-coordinate surface control parameter.
2.0000E+00 theta_b S-coordinate bottom control parameter.
20220101.00 time_ref Reference time for units attribute (yyyymmdd.dd)
3.0000E+01 Tnudg(01) Nudging/relaxation time scale (days)
3.0000E+01 Tnudg(02) Nudging/relaxation time scale (days)
for tracer 02: salt
3.0000E+01 Znudg Nudging/relaxation time scale (days)
3.0000E+01 M2nudg Nudging/relaxation time scale (days)
3.0000E+01 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
3.0000E+01 obcfac Factor between passive and active
32.000 S0 Background salinity (PSU) constant.
T Aout(idFsuD) Write out detided free-surface.
T Aout(idu2dD) Write out detided 2D U-velocity.
T Aout(idv2dD) Write out detided 2D V-velocity.
T Aout(idu3dD) Write out detided 3D U-velocity.
T Aout(idv3dD) Write out detided 3D V-velocity.
1 inp_lib Using standard NetCDF library for input files.
1 out_lib Using standard NetCDF library for output files.
Output Restart File: roms_rst.nc
Prefix for History Files: scs2022_his
Prefix for Averages Files: scs2022_avg
Output Detiding Harmonics File: scs2022_har.nc
Output Stations File: scs2022_sta.nc
Input Grid File: SCS_grid.nc
Input Nonlinear Initial File: SCS2022_ini_2.nc
Tidal Forcing File: frc_TPXO9v5_scs.nc
Input Forcing File 01: gom_lwrad_era_1.nc
gom_lwrad_era_2.nc
gom_lwrad_era_3.nc
Input Forcing File 02: gom_Pair_era_1.nc
gom_Pair_era_2.nc
gom_Pair_era_3.nc
Input Forcing File 03: gom_Qair_era_1.nc
gom_Qair_era_2.nc
gom_Qair_era_3.nc
Input Forcing File 04: gom_rain_era_1.nc
gom_rain_era_2.nc
gom_rain_era_3.nc
Input Forcing File 05: gom_swrad_era_1.nc
gom_swrad_era_2.nc
gom_swrad_era_3.nc
Input Forcing File 06: gom_Tair_era_1.nc
gom_Tair_era_2.nc
gom_Tair_era_3.nc
Input Forcing File 07: gom_wind_era_1.nc
gom_wind_era_2.nc
gom_wind_era_3.nc
Input Lateral Boundary File 01: SCS_bry_01.nc
SCS_bry_02.nc
SCS_bry_03.nc
SCS_bry_04.nc
SCS_bry_05.nc
SCS_bry_06.nc
SCS_bry_07.nc
SCS_bry_08.nc
SCS_bry_09.nc
SCS_bry_10.nc
SCS_bry_11.nc
SCS_bry_12.nc
SCS_bry_13.nc
Station positions File: stations.in
ROMS I/O variables Metadata File: varinfo.yaml
TIDE_DATE - Checking tidal reference date for zero phase:
'zero_phase_date' variable not found in: frc_TPXO9v5_scs.nc
given tide_start = 0.0000 (days)
tide_DateNumber = 738522.0000 (2022-01-01 00:00:00)
Tile partition information for Grid 01: 343x348x35 tiling: 8x8
tile Istr Iend Jstr Jend Npts
0 1 43 1 42 63210
1 44 86 1 42 63210
2 87 129 1 42 63210
3 130 172 1 42 63210
4 173 215 1 42 63210
5 216 258 1 42 63210
6 259 301 1 42 63210
7 302 343 1 42 61740
8 1 43 43 86 66220
9 44 86 43 86 66220
10 87 129 43 86 66220
11 130 172 43 86 66220
12 173 215 43 86 66220
13 216 258 43 86 66220
14 259 301 43 86 66220
15 302 343 43 86 64680
16 1 43 87 130 66220
17 44 86 87 130 66220
18 87 129 87 130 66220
19 130 172 87 130 66220
20 173 215 87 130 66220
21 216 258 87 130 66220
22 259 301 87 130 66220
23 302 343 87 130 64680
24 1 43 131 174 66220
25 44 86 131 174 66220
26 87 129 131 174 66220
27 130 172 131 174 66220
28 173 215 131 174 66220
29 216 258 131 174 66220
30 259 301 131 174 66220
31 302 343 131 174 64680
32 1 43 175 218 66220
33 44 86 175 218 66220
34 87 129 175 218 66220
35 130 172 175 218 66220
36 173 215 175 218 66220
37 216 258 175 218 66220
38 259 301 175 218 66220
39 302 343 175 218 64680
40 1 43 219 262 66220
41 44 86 219 262 66220
42 87 129 219 262 66220
43 130 172 219 262 66220
44 173 215 219 262 66220
45 216 258 219 262 66220
46 259 301 219 262 66220
47 302 343 219 262 64680
48 1 43 263 306 66220
49 44 86 263 306 66220
50 87 129 263 306 66220
51 130 172 263 306 66220
52 173 215 263 306 66220
53 216 258 263 306 66220
54 259 301 263 306 66220
55 302 343 263 306 64680
56 1 43 307 348 63210
57 44 86 307 348 63210
58 87 129 307 348 63210
59 130 172 307 348 63210
60 173 215 307 348 63210
61 216 258 307 348 63210
62 259 301 307 348 63210
63 302 343 307 348 61740
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 43.50 0.50 42.50 RHO-points
1 43.50 86.50 0.50 42.50 RHO-points
2 86.50 129.50 0.50 42.50 RHO-points
3 129.50 172.50 0.50 42.50 RHO-points
4 172.50 215.50 0.50 42.50 RHO-points
5 215.50 258.50 0.50 42.50 RHO-points
6 258.50 301.50 0.50 42.50 RHO-points
7 301.50 343.50 0.50 42.50 RHO-points
8 0.50 43.50 42.50 86.50 RHO-points
9 43.50 86.50 42.50 86.50 RHO-points
10 86.50 129.50 42.50 86.50 RHO-points
11 129.50 172.50 42.50 86.50 RHO-points
12 172.50 215.50 42.50 86.50 RHO-points
13 215.50 258.50 42.50 86.50 RHO-points
14 258.50 301.50 42.50 86.50 RHO-points
15 301.50 343.50 42.50 86.50 RHO-points
16 0.50 43.50 86.50 130.50 RHO-points
17 43.50 86.50 86.50 130.50 RHO-points
18 86.50 129.50 86.50 130.50 RHO-points
19 129.50 172.50 86.50 130.50 RHO-points
20 172.50 215.50 86.50 130.50 RHO-points
21 215.50 258.50 86.50 130.50 RHO-points
22 258.50 301.50 86.50 130.50 RHO-points
23 301.50 343.50 86.50 130.50 RHO-points
24 0.50 43.50 130.50 174.50 RHO-points
25 43.50 86.50 130.50 174.50 RHO-points
26 86.50 129.50 130.50 174.50 RHO-points
27 129.50 172.50 130.50 174.50 RHO-points
28 172.50 215.50 130.50 174.50 RHO-points
29 215.50 258.50 130.50 174.50 RHO-points
30 258.50 301.50 130.50 174.50 RHO-points
31 301.50 343.50 130.50 174.50 RHO-points
32 0.50 43.50 174.50 218.50 RHO-points
33 43.50 86.50 174.50 218.50 RHO-points
34 86.50 129.50 174.50 218.50 RHO-points
35 129.50 172.50 174.50 218.50 RHO-points
36 172.50 215.50 174.50 218.50 RHO-points
37 215.50 258.50 174.50 218.50 RHO-points
38 258.50 301.50 174.50 218.50 RHO-points
39 301.50 343.50 174.50 218.50 RHO-points
40 0.50 43.50 218.50 262.50 RHO-points
41 43.50 86.50 218.50 262.50 RHO-points
42 86.50 129.50 218.50 262.50 RHO-points
43 129.50 172.50 218.50 262.50 RHO-points
44 172.50 215.50 218.50 262.50 RHO-points
45 215.50 258.50 218.50 262.50 RHO-points
46 258.50 301.50 218.50 262.50 RHO-points
47 301.50 343.50 218.50 262.50 RHO-points
48 0.50 43.50 262.50 306.50 RHO-points
49 43.50 86.50 262.50 306.50 RHO-points
50 86.50 129.50 262.50 306.50 RHO-points
51 129.50 172.50 262.50 306.50 RHO-points
52 172.50 215.50 262.50 306.50 RHO-points
53 215.50 258.50 262.50 306.50 RHO-points
54 258.50 301.50 262.50 306.50 RHO-points
55 301.50 343.50 262.50 306.50 RHO-points
56 0.50 43.50 306.50 348.50 RHO-points
57 43.50 86.50 306.50 348.50 RHO-points
58 86.50 129.50 306.50 348.50 RHO-points
59 129.50 172.50 306.50 348.50 RHO-points
60 172.50 215.50 306.50 348.50 RHO-points
61 215.50 258.50 306.50 348.50 RHO-points
62 258.50 301.50 306.50 348.50 RHO-points
63 301.50 343.50 306.50 348.50 RHO-points
0 1.00 43.50 0.50 42.50 U-points
1 43.50 86.50 0.50 42.50 U-points
2 86.50 129.50 0.50 42.50 U-points
3 129.50 172.50 0.50 42.50 U-points
4 172.50 215.50 0.50 42.50 U-points
5 215.50 258.50 0.50 42.50 U-points
6 258.50 301.50 0.50 42.50 U-points
7 301.50 343.00 0.50 42.50 U-points
8 1.00 43.50 42.50 86.50 U-points
9 43.50 86.50 42.50 86.50 U-points
10 86.50 129.50 42.50 86.50 U-points
11 129.50 172.50 42.50 86.50 U-points
12 172.50 215.50 42.50 86.50 U-points
13 215.50 258.50 42.50 86.50 U-points
14 258.50 301.50 42.50 86.50 U-points
15 301.50 343.00 42.50 86.50 U-points
16 1.00 43.50 86.50 130.50 U-points
17 43.50 86.50 86.50 130.50 U-points
18 86.50 129.50 86.50 130.50 U-points
19 129.50 172.50 86.50 130.50 U-points
20 172.50 215.50 86.50 130.50 U-points
21 215.50 258.50 86.50 130.50 U-points
22 258.50 301.50 86.50 130.50 U-points
23 301.50 343.00 86.50 130.50 U-points
24 1.00 43.50 130.50 174.50 U-points
25 43.50 86.50 130.50 174.50 U-points
26 86.50 129.50 130.50 174.50 U-points
27 129.50 172.50 130.50 174.50 U-points
28 172.50 215.50 130.50 174.50 U-points
29 215.50 258.50 130.50 174.50 U-points
30 258.50 301.50 130.50 174.50 U-points
31 301.50 343.00 130.50 174.50 U-points
32 1.00 43.50 174.50 218.50 U-points
33 43.50 86.50 174.50 218.50 U-points
34 86.50 129.50 174.50 218.50 U-points
35 129.50 172.50 174.50 218.50 U-points
36 172.50 215.50 174.50 218.50 U-points
37 215.50 258.50 174.50 218.50 U-points
38 258.50 301.50 174.50 218.50 U-points
39 301.50 343.00 174.50 218.50 U-points
40 1.00 43.50 218.50 262.50 U-points
41 43.50 86.50 218.50 262.50 U-points
42 86.50 129.50 218.50 262.50 U-points
43 129.50 172.50 218.50 262.50 U-points
44 172.50 215.50 218.50 262.50 U-points
45 215.50 258.50 218.50 262.50 U-points
46 258.50 301.50 218.50 262.50 U-points
47 301.50 343.00 218.50 262.50 U-points
48 1.00 43.50 262.50 306.50 U-points
49 43.50 86.50 262.50 306.50 U-points
50 86.50 129.50 262.50 306.50 U-points
51 129.50 172.50 262.50 306.50 U-points
52 172.50 215.50 262.50 306.50 U-points
53 215.50 258.50 262.50 306.50 U-points
54 258.50 301.50 262.50 306.50 U-points
55 301.50 343.00 262.50 306.50 U-points
56 1.00 43.50 306.50 348.50 U-points
57 43.50 86.50 306.50 348.50 U-points
58 86.50 129.50 306.50 348.50 U-points
59 129.50 172.50 306.50 348.50 U-points
60 172.50 215.50 306.50 348.50 U-points
61 215.50 258.50 306.50 348.50 U-points
62 258.50 301.50 306.50 348.50 U-points
63 301.50 343.00 306.50 348.50 U-points
0 0.50 43.50 1.00 42.50 V-points
1 43.50 86.50 1.00 42.50 V-points
2 86.50 129.50 1.00 42.50 V-points
3 129.50 172.50 1.00 42.50 V-points
4 172.50 215.50 1.00 42.50 V-points
5 215.50 258.50 1.00 42.50 V-points
6 258.50 301.50 1.00 42.50 V-points
7 301.50 343.50 1.00 42.50 V-points
8 0.50 43.50 42.50 86.50 V-points
9 43.50 86.50 42.50 86.50 V-points
10 86.50 129.50 42.50 86.50 V-points
11 129.50 172.50 42.50 86.50 V-points
12 172.50 215.50 42.50 86.50 V-points
13 215.50 258.50 42.50 86.50 V-points
14 258.50 301.50 42.50 86.50 V-points
15 301.50 343.50 42.50 86.50 V-points
16 0.50 43.50 86.50 130.50 V-points
17 43.50 86.50 86.50 130.50 V-points
18 86.50 129.50 86.50 130.50 V-points
19 129.50 172.50 86.50 130.50 V-points
20 172.50 215.50 86.50 130.50 V-points
21 215.50 258.50 86.50 130.50 V-points
22 258.50 301.50 86.50 130.50 V-points
23 301.50 343.50 86.50 130.50 V-points
24 0.50 43.50 130.50 174.50 V-points
25 43.50 86.50 130.50 174.50 V-points
26 86.50 129.50 130.50 174.50 V-points
27 129.50 172.50 130.50 174.50 V-points
28 172.50 215.50 130.50 174.50 V-points
29 215.50 258.50 130.50 174.50 V-points
30 258.50 301.50 130.50 174.50 V-points
31 301.50 343.50 130.50 174.50 V-points
32 0.50 43.50 174.50 218.50 V-points
33 43.50 86.50 174.50 218.50 V-points
34 86.50 129.50 174.50 218.50 V-points
35 129.50 172.50 174.50 218.50 V-points
36 172.50 215.50 174.50 218.50 V-points
37 215.50 258.50 174.50 218.50 V-points
38 258.50 301.50 174.50 218.50 V-points
39 301.50 343.50 174.50 218.50 V-points
40 0.50 43.50 218.50 262.50 V-points
41 43.50 86.50 218.50 262.50 V-points
42 86.50 129.50 218.50 262.50 V-points
43 129.50 172.50 218.50 262.50 V-points
44 172.50 215.50 218.50 262.50 V-points
45 215.50 258.50 218.50 262.50 V-points
46 258.50 301.50 218.50 262.50 V-points
47 301.50 343.50 218.50 262.50 V-points
48 0.50 43.50 262.50 306.50 V-points
49 43.50 86.50 262.50 306.50 V-points
50 86.50 129.50 262.50 306.50 V-points
51 129.50 172.50 262.50 306.50 V-points
52 172.50 215.50 262.50 306.50 V-points
53 215.50 258.50 262.50 306.50 V-points
54 258.50 301.50 262.50 306.50 V-points
55 301.50 343.50 262.50 306.50 V-points
56 0.50 43.50 306.50 348.00 V-points
57 43.50 86.50 306.50 348.00 V-points
58 86.50 129.50 306.50 348.00 V-points
59 129.50 172.50 306.50 348.00 V-points
60 172.50 215.50 306.50 348.00 V-points
61 215.50 258.50 306.50 348.00 V-points
62 258.50 301.50 306.50 348.00 V-points
63 301.50 343.50 306.50 348.00 V-points
HaloSizeI(1) = 171
HaloSizeJ(1) = 174
TileSide(1) = 52
TileSize(1) = 2652
Stations Parameters, Grid: 01
13 Nstation Number of stations to write out into stations file.
T Sout(idFsur) Write out free-surface.
T Sout(idUbar) Write out 2D U-momentum component.
T Sout(idVbar) Write out 2D V-momentum component.
T Sout(idu2dE) Write out 2D U-eastward at RHO-points.
T Sout(idv2dN) Write out 2D V-northward at RHO-points.
T Sout(idUvel) Write out 3D U-momentum component.
T Sout(idVvel) Write out 3D V-momentum component.
T Sout(idWvel) Write out W-momentum component.
T Sout(idOvel) Write out omega vertical velocity.
T Sout(idTvar) Write out tracer 01: temp
T Sout(idTvar) Write out tracer 02: salt
T Sout(idVvis) Write out vertical viscosity coefficient.
Flag and positions for station 0001: 1 111.5550 17.9430
Flag and positions for station 0002: 1 111.7480 17.6680
Flag and positions for station 0003: 1 111.9430 17.3890
Flag and positions for station 0004: 1 112.1350 17.1140
Flag and positions for station 0005: 1 115.3500 22.7500
Flag and positions for station 0006: 1 108.6170 19.1000
Flag and positions for station 0007: 1 109.0830 21.4830
Flag and positions for station 0008: 1 110.2830 20.0170
Flag and positions for station 0009: 1 112.3330 16.8330
Flag and positions for station 0010: 1 112.8830 9.5500
Flag and positions for station 0011: 1 117.8500 15.1170
Flag and positions for station 0012: 1 114.3170 11.4500
Flag and positions for station 0013: 1 116.7170 20.7000
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 HSIMT HSIMT
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
ubar 1 Flather Flather Flather Flather
vbar 1 Flather Flather Flather Flather
temp 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
salt 1 Rad + Nud Rad + Nud Rad + Nud Rad + Nud
scs2022 scs2022
ADD_FSOBC Adding tidal elevation to processed OBC data
ADD_M2OBC Adding tidal currents to processed OBC data
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ASSUMED_SHAPE Using assumed-shape arrays
AVERAGES Writing out time-averaged nonlinear model fields
AVERAGES_DETIDE Writing out time-averaged nonlinear model detided fields
BOUNDARY_ALLREDUCE Using mpi_allreduce in mp_boundary routine
BULK_FLUXES Surface bulk fluxes parameterization
COLLECT_ALLREDUCE Using mpi_allreduce in mp_collect routine
CURVGRID Orthogonal curvilinear grid
DIFF_GRID Horizontal diffusion coefficient scaled by grid size
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel
EMINUSP Compute Salt Flux using E-P
!GATHER_SENDRECV Using mpi_gatherv in mp_gather2d/mp_gather3d routines
LIMIT_BSTRESS Limit bottom stress to maintain bottom velocity direction
LMD_CONVEC LMD convective mixing due to shear instability
LMD_MIXING Large/McWilliams/Doney interior mixing
LMD_NONLOCAL LMD convective nonlocal transport
LMD_RIMIX LMD diffusivity due to shear instability
LMD_SHAPIRO Shapiro filtering boundary layer depth
LMD_SKPP KPP surface boundary layer mixing
LONGWAVE_OUT Compute outgoing longwave radiation internally
MASKING Land/Sea masking
MIX_GEO_TS Mixing of tracers along geopotential surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
!MULTI_THREAD Using mpi_init with single thread level processing
NONLINEAR Nonlinear Model
NONLIN_EOS Nonlinear Equation of State for seawater
PERFECT_RESTART Processing perfect restart variables
POWER_LAW Power-law shape time-averaging barotropic filter
PROFILE Time profiling activated
RADIATION_2D Use tangential phase speed in radiation conditions
REDUCE_ALLREDUCE Using mpi_allreduce in mp_reduce routine
RI_SPLINES Parabolic Spline Reconstruction for Richardson Number
!RST_SINGLE Double precision fields in restart NetCDF file
SALINITY Using salinity
!SCATTER_BCAST Using mpi_scatterv in mp_scatter2d/mp_scatter3d routines
STEP2D_LF_AM3 Predictor/Corrector LF-AM3 stepping scheme
SOLAR_SOURCE Solar Radiation Source Term
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
SSH_TIDES Adding tidal elevation to SSH climatology
STATIONS Writing out station data
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_U3HADVECTION Third-order upstream horizontal advection of 3D momentum
UV_C4VADVECTION Fourth-order centered vertical advection of momentum
UV_LOGDRAG Logarithmic bottom stress
UV_TIDES Add tidal currents to 2D momentum climatologies
UV_VIS2 Harmonic mixing of momentum
VAR_RHO_2D Variable density barotropic mode
VISC_GRID Horizontal viscosity coefficient scaled by grid size
WET_DRY Wetting and drying activated
