There is a bug in post_initial.F that causes the compilation of 2D runs to fail. The easiest way to duplicate this run is to set the "canyon" test case to its 2D limit by altering its build_roms.sh to remove the "-DSOLVE3D" option in the line
export MY_CPP_FLAGS="${MY_CPP_FLAGS} -DSOLVE3D"
-O3 -ffast-math -fopenmp -static-libgcc post_initial.f90
post_initial.f90:22:32:
22 | USE set_depth_mod, ONLY : set_depth
| 1
Error: Symbol ‘set_depth’ referenced at (1) not found in module ‘set_depth_mod’
*** post_initial.F_original 2024-12-20 15:35:48.029287130 +0000
--- post_initial.F_jamieFix 2024-12-20 15:35:03.256215434 +0000
*** 24,30 ****
--- 24,32 ----
USE ini_fields_mod, ONLY : ini_fields, ini_zeta
+ #ifdef SOLVE3D
+ #endif
implicit none
*** 51,58 ****
DO tile=first_tile(ng),last_tile(ng),+1
! CALL ini_zeta (ng, tile, model)
! CALL set_depth (ng, tile, model)
!$OMP BARRIER
--- 53,62 ----
! #ifdef SOLVE3D
! #endif
!$OMP BARRIER
Jamie Pringle
