Errors compiling roms on Cray cluster
LeaF_7
#1 Unread post by LeaF_7 »
I am trying to compile Roms on a cray cluster, but it gives the error message as follows. While I am not a very skilled cluster user.
Can anyone tells me what the problem is?
Thanks a lot!
Fan
cd /work/fanlin/roms_kate_ser/Apps/YellowSea/Build; /opt/cray/craype/2.4.2/bin/ftn -c  -O3 -Mfree mod_iounits.f90
ftn-78 crayftn: ERROR in command line
  The -M option has an invalid argument, "free".
make: *** [/work/fanlin/roms_kate_ser/Apps/YellowSea/Build/mod_iounits.o] Error 1
Re: Errors compiling roms on Cray cluster
On the Cray, there may be more than one available compiler, but they will all be called "ftn". Do you know which one you are using? Can you show "module list"? On our system, check out the "PrgEnv" module - I have PrgEnv-intel/4.2.34 currently loaded.
fish2 1140% module avail PrgEnv
------------------------------- /opt/modulefiles -------------------------------
PrgEnv-cray/4.0.46           PrgEnv-intel/4.0.46
PrgEnv-cray/4.2.34(default)  PrgEnv-intel/4.2.34(default)
PrgEnv-gnu/4.0.46            PrgEnv-pgi/4.0.46
PrgEnv-gnu/4.2.34(default)   PrgEnv-pgi/4.2.34(default)
You can have any one of these loaded - but only one at a time.
Did you select "ftn" for the FORT variable in your build script/makefile?
So, now go into the Compilers directory. There is probably a Linux-ftn.mk file. If this is the trunk ROMS, it will say "CRAY FTN cross-compiler with Linux" at the top. If this is my branch, it will say "PGI Fortran compiler on Linux (on Cray)". Actually, the latter has the "-Mfree" in it. My local file on the Cray system has "-free" instead, which is what ifort wants. You need to know which compiler you are using in order to know which options to give it. Compare with the Linux-ifort.mk file in that Compilers directory. If you are using the actual Cray compiler, you might have to read the man page to find out how to tell it to use F90 free format.
LeaF_7
#3 Unread post by LeaF_7 »
Thanks a lot for you reply, kate.
--------------------------------------------------------------- /opt/cray/modulefiles ----------------------------------------------------------------
PrgEnv-cray/5.2.40(default)  PrgEnv-gnu/5.2.40(default)   PrgEnv-intel/5.2.40(default) PrgEnv-pgi/5.2.40(default)
It's like the cray compiler is the default one. I switch it to ifort and modified the Linux-ftn.mk file as you suggested, it seemed working.
Will try to learn more about cray compiler stuff.
Thanks again for the help!
Fan
pheidary
#4 Unread post by pheidary »
Hello everyone,
I am working on a cray system, and trying to compile ROMS following these steps:
  • loaded cray modules:
    module load PrgEnv-cray
    module load cray-hdf5/1.12.2.11
    module load cray-netcdf/4.9.0.11
  • Changed these in build_script
    Fort to ftn-cray
    export which_MPI=mpich (only available)
  • Also modified Linux-ftn-cray.mk:
    FFLAGS = -em -h omp
    FFLAGS = -O3 -h aggress
    FIXEDFLAGS = -ef
    FREEFLAGS = -eF
  • ./build_roms_split.sh -j 20
When I run it for the WC13 case (as a test), it gets stuck in the last inner loop while trying to calculate eigenvectors and eigenvalues in rpcg-lanczos.F when it calls the DSTEQR subroutine. From what I’ve found, the issue seems to be with LAPACK: it’s not functioning correctly, as the DLASCL subroutine isn’t accessing the appropriate native Cray constants needed for eigenvector/eigenvalue calculations.Has anyone who has run ROMS on Cray encountered a similar problem?
I appreciate any help on this issue.
Best,
Parisa
