In an attempt to create a NESTED GRID application, using the same nested grid example(Lake Jersey). I considered the same coarser grid as in the given application named (a grid), using the coarse2fine function I created a grid in the same region as b gird but with more finer resolution. I was successful in generating that grid file. Now in order to have a initial file for this grid file, I'm using d_roms2roms.m. The parameters passed to this function are as follows,
sNWAdata = 'lake_jersey_avg_a.nc';
NWAgrid = 'lake_jersey_grd_a.nc';
GRDname = 'lake_jersey_grd_test.nc';
INIname = 'gom_ini_b_new.nc';
but when running that script I'm getting the following errors and it says Zname is missing how do I solve this Issue.
** Interpolating initial conditions from NWA to GOM grid **
** Processing: 01-Jan-1900 00:15:00 **
Interpolating 2D variable: zeta (156x233) from donor (102x82) ...
Donor Min = -6.55380e-03 Donor Max = 6.12860e-05
Receiver Min = -4.56433e-03 Receiver Max = -7.35259e-04 NaN count = 0
Interpolating 2D variable: ubar (156x233) from donor (101x82) ...
Donor Min = 1.82445e-04 Donor Max = 4.31658e-03
Receiver Min = 1.27630e-03 Receiver Max = 3.85136e-03 NaN count = 0
Interpolating 2D variable: vbar (156x233) from donor (102x81) ...
Donor Min = -8.93723e-04 Donor Max = 5.68493e-04
Receiver Min = -3.61550e-04 Receiver Max = 3.30786e-04 NaN count = 0
Error using roms2roms
ROMS2ROMS - unable to find field ', Zname, ' in receiver grid structure: R
Error in d_roms2roms (line 153)
I.(field) = roms2roms(NWAdata, P, T, field, IniRec, Rvector, ...
Below I have attached all the files mentioned here, any help is really appreciated.
Interpolating variables to get a finer resolution model (NESTED GRID)
- lake_jersey_avg_a.nc
- (23.5 MiB) Downloaded 1092 times
- lake_jersey_grd_test.nc
- (4.42 MiB) Downloaded 1151 times
- lake_jersey_ini_a.nc
- (216 Bytes) Downloaded 1109 times
Re: Interpolating variables to get a finer resolution model (NESTED GRID)
It must be something wrong when you using "get_roms_grid" or "roms2roms". You can search words such as "vertical process" in these codes, and modified it.
