Hi everyone,
I've encountered an issue with the FRCNAME parameter in my roms.in and I'm seeking some guidance. It seems that when the number of FRCNAME entries exceeds 204, for example 210 (though NFFILES == 7, 7*30years=210), I encounter an error. Unfortunately, there is no specific "Error" in output. Instead, I see error messages like "Caught signal 11 (Segmentation fault: Sent by the kernel at address (nil))."
I'm curious if there is a known limitation on the number of FRCNAME entries in the .in files. Additionally, I would appreciate any insights or suggestions on how to resolve this issue and successfully run my simulations with more than 204 FRCNAME entries.
Looking forward to any advice. Thank you in advance!
Query about FRCNAME Limitation in .in Files
Re: Query about FRCNAME Limitation in .in Files
Nope, there is no limitation. The filename is limited to 256 characters, and the number of files in the sequence files(:) is allocated internally to the number of files that it finds. This is the first time we have heard of a user providing files for 30 years. If I want to do such a long simulation, I will do restarts. Anyway, It seems that there is a problem with the specific syntax for these entries in your roms.in file.
With a bit of curiosity, you would discover that the answers to your question can be found easily in ROMS/Modules/mod_iounits.F. The code is well documented internally for users to explore its complexity:
TYPE T_IO
integer :: IOtype ! file IO type
integer :: Nfiles ! number of multi-files
integer :: Fcount ! multi-file counter
integer :: load ! filename load counter
integer :: Rindex ! NetCDF record index
integer :: ncid ! NetCDF file ID
integer, pointer :: Nrec(:) ! NetCDF record size
integer, pointer :: Vid(:) ! NetCDF variables IDs
integer, pointer :: Tid(:) ! NetCDF tracers IDs
real(dp), pointer :: time_min(:) ! starting time
real(dp), pointer :: time_max(:) ! ending time
character (len=50 ) :: label ! structure label
character (len=256) :: head ! head filename
character (len=256) :: base ! base filename
character (len=256) :: name ! current name
character (len=256), pointer :: files(:) ! multi-file names
#if defined PIO_LIB && defined DISTRIBUTE
TYPE (File_desc_t) :: pioFile ! file descriptor
TYPE (My_VarDesc), pointer :: pioVar(:) ! variable descriptor
TYPE (My_VarDesc), pointer :: pioTrc(:) ! tracer descriptor
END TYPE T_IO
Thank you,
I am currently using rst to implement long-time simulation, it works. ROMS/Modules/mod_iounits.F helps me steer clear of potential issues related to character lengths in the future, I would continue to familiarize myself with the ROMS source code.
