I have started with ROMS recently but have run into an issue during installation via git in the step “Synchronizing Git and SVN revision information” (https://www.myroms.org/wiki/Git#Synchro ... nformation). When following the explanation on that ROMS wiki page, the Git commit hash and the corresponding SVN revision properties do not appear in the ROMS source files after the command
$ git checkout HEAD -- “$(git rev-parse --show-toplevel)
even though the command seems to run properly (it takes a few minutes and then finishes without terminal output).
The resulting header of ROMS/Modules/mod_ncparam.F contains no commit hashes:
!git $Id: mod_ncparam.F 1198 2023-09-01 19:00:59Z arango $
!svn $Id: mod_ncparam.F 1198 2023-09-01 19:00:59Z arango $
Instead of the expected e.g.:
!git $Id: b42658ab652647fca27d50af4afa15c3401fe544 $
!svn $Id: mod_ncparam.F 968 2019-06-17 16:02:48Z arango $
Possibly the issue has to do with that the previous commands
$ git config filter.id.smudge ".git_filters/id.smudge %f"
$ git config filter.id.clean ".git_filters/id.clean %f"
did not change the ~/.gitconfig file (I am not sure if they should change the .gitconfig?). So I also tried to configure the filters manually by adding
[filter "id"]
clean = .git_filters/id.clean %f
smudge = .git_filters/id.smudge %f
To ~/.gitconfig and again applying the smudge filter, but that made no difference.
Does anyone know what could be the solution to this issue?
I am working on a HPC cluster with OS “Red Hat Enterprise Linux Server release 7.9 (Maipo)”. I access it via ssh from OS X 13.5.2.
Thank you in advance for any help,
Kind regards,
Sophie
Installation problem during “Synchronizing Git and SVN revision information”
Re: Installation problem during “Synchronizing Git and SVN revision information”
Nowadays, we distribute ROMS in
github.com/myroms. Please follow the instructions on https://github.com/myroms/roms/wiki
