As the subject suggests we recently noticed that our forecast showed random inconsistencies in the temperature variable. At first, we thought it was due to atmospheric forcing but looking further into it we noticed the "inconsistency" is present through the water column. It is also reflected in the salinity. By inconsistency, I am referring to a grid point where values (of salinity or temperature) drop. There are a few mysteries here.
- These "inconsistencies" appear after 30 minutes, and they completely disappear after 12 hours within a 7-day forecast
- They are not big enough to cause a model blow-up
- It is not exclusive to temperature as it also shows in the salinity
- It seems to propagate throughout the water column
- These spots appear randomly throughout the domain, although around the same regions (as seen below)
- There are no clear bathymetric features that might be to blame
Even though this doesn't blow our run and doesn't seem to have a great impact on our output, we would like to get it right to be able to couple our run to an atmospheric model and to not propagate the error. Our guess is that it is an internal computation kind of issue, if anybody has encountered this issue before or have any input I would really appreciate it!
