Error termination. Backtrace:
ERROR STOP
#0 0x56477d4d4ce6 in ???
#1 0x56477d4d48ce in ???
#2 0x7f6f48f4084f in ???
#3 0x7f6f48f40909 in ???
#4 0x56477d4d4924 in ???
#5 0xffffffffffffffff in ???
#0 0x561dde7b5ce6 in ???
#1 0x561dde7b58ce in ???
#2 0x7f28ffe2e84f in ???
#3 0x7f28ffe2e909 in ???
#4 0x561dde7b5924 in ???
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[38976,1],0]
Exit code: 1
ERROR STOP
ERROR STOP
#0 0x556bedc96ce6 in ???
#1 0x556bedc968ce in ???
#2 0x7f0f4e74084f in ???
#3 0x7f0f4e740909 in ???
#4 0x556bedc96924 in ???
#0 0x55f547af9ce6 in ???
#1 0x55f547af98ce in ???
#2 0x7f62bfe5384f in ???
#3 0x7f62bfe53909 in ???
#4 0x55f547af9924 in ???
Process name: [[36786,1],1]
Exit code: 1
! Input variable information file name. This file needs to be processed
VARNAME = /Users/arango/ocean/repository/git/trunk/ROMS/External/varinfo.yaml
It would help if you spent some time getting more familiar with ROMS. There is plenty of information in WikiROMS.
Yes, It's weird, because if my VARNAME was incorrect I couldn't see the first error. And I checked my VARNAME, after your suggestion, put the complete path and still get the same mistakes. I will read the WikiROMS and see if I made something wrong. Thanks for trying to help me.
