compilation attempt using wc13.h fails
otel
Location: Instituto Oceanográfico - Universidade de São Paul
#1 Unread post by otel »
Hello everyone,
We are currently trying to implement a model with data assimilation system and we are now following the steps in https://www.myroms.org/wiki/4DVar_Norma ... n_Tutorial. Unfortunately, a few errors showed up when we tried to compile ROMS (we are using the NORMALIZATION option the cpp file: ROMS/Include/wc13.h). We didn't expect the compilation to fail, since this is a cpp file provided with the ROMS source code,.
The compilation throws the following error:
563 |         IF (allocated(FOURDVAR(ng) % NobsSurvey)) THEN
      |                                    1
Error: Symbol 'fourdvar' at (1) has no IMPLICIT type
Upon investigation, we have identified the issues originating from the T_FOURDVAR type defined in ROMS/Modules/mod_fourdvar.F (lines 146-155, see below) and the macro OBSERVATIONS defined in ROMS/Include/globaldefs.h (lines 623-640,see below). It appears that the T_FOURDVAR type is dependent on the C++ macro OBSERVATIONS. ROMS/Include/wc13.h (see below) does not contain any key that activates OBSERVATIONS when the NORMALIZATION option is set.
I'm wondering if you would have any advice on dealing with this issue. The version of ROMS we are using is displayed at the end of this message.
I appreciate your time,
Dalton Sasaki
[ROMS/Modules/mod_fourdvar.F (lines 146-155)]
# ifdef OBSERVATIONS
!  Define T_FOURDVAR structure.
        TYPE T_FOURDVAR
          integer , allocatable :: NobsSurvey(:)
          integer , allocatable :: ObsCount(:)
          integer , allocatable :: ObsReject(:)
#  ifdef FOUR_DVAR
          real(r8), allocatable :: BackCost(:)
          real(r8), allocatable :: Cost0(:)
[ROMS/Include/globaldefs.h]
#if defined ARRAY_MODES            || \
    defined CLIPPING               || \
    defined I4DVAR                 || \
    defined I4DVAR_ANA_SENSITIVITY || \
    defined RBL4DVAR               || \
    defined R4DVAR                 || \
    defined SENSITIVITY_4DVAR      || \
    defined SPLIT_I4DVAR           || \
    defined SPLIT_RBL4DVAR         || \
    defined SPLIT_R4DVAR           || \
    defined SPLIT_SP4DVAR          || \
    defined SP4DVAR                || \
    defined TLM_CHECK              || \
    defined TL_RBL4DVAR            || \
    defined TL_R4DVAR              || \
    defined VERIFICATION
# define OBSERVATIONS
[ROMS/Include/wc13.h]
** svn $Id: wc13.h 77 2020-05-13 03:06:55Z arango $
** Copyright (c) 2002-2023 The ROMS/TOMS Group                               **
**   Licensed under a MIT/X style license                                    **
**   See License_ROMS.txt                                                    **
** Options for the California Current System, 1/3 degree resolution.
** Application flag:   WC13
** Input script:       roms_wc13.in
**                     s4dvar.in
** Available Drivers options: choose only one and activate it in the
**                            build.sh script (MY_CPP_FLAGS definition)
**  AD_SENSITIVITY            Adjoint Sensitivity Driver
**  AFT_EIGENMODES            Adjoint Finite Time Eigenmodes
**  ARRAY_MODES               Stabilized representer matrix array modes
**  CLIPPING                  Stabilized representer matrix clipped analysis
**  CORRELATION               Background-error Correlation Check
**  GRADIENT_CHECK            TLM/ADM Gradient Check
**  FORCING_SV                Forcing Singular Vectors
**  FT_EIGENMODES             Finite Time Eigenmodes
**  I4DVAR                    Incremental, strong constraint 4D-Var
**  NLM_DRIVER                Nonlinear Basic State trajectory
**  NORMALIZATION             Background error Covariance Normalization
**  OPT_PERTURBATION          Optimal perturbations
**  PICARD_TEST               Picard Iterations Test
**  RBL4DVAR                  Strong/Weak constraint RBL4D-Var
**  R4DVAR                    Stronf/Weak constraint R4D-Var
**  R_SYMMETRY                Representer Matrix Symmetry Test
**  SANITY_CHECK              Sanity Check
**  SO_SEMI                   Stochastic Optimals: Semi-norm
**  TLM_CHECK                 Tangent Linear Model Check
**  VERIFICATION              NL Observation Verification Driver
**  Nonlinear basic state settings.
#ifdef VERIFICATION
# define FULL_GRID
#define MIX_GEO_TS
#define SPLINES_VDIFF
#define SPLINES_VVISC
#define PROFILE
#define SPHERICAL
#ifdef NLM_DRIVER
# define AVERAGES           /* define if writing out time-averaged data */
**  Vertical Mixing parameterization
#define GLS_MIXING
#ifdef GLS_MIXING
# define RI_SPLINES
** Surface atmospheric fluxes. Note, that we must define DIURNAL_SRFLUX
** when using daily averaged fields.
#define BULK_FLUXES      /* turn ON or OFF bulk fluxes computation */
#define DIURNAL_SRFLUX   /* impose shortwave radiation local diurnal cycle */
#define SOLAR_SOURCE     /* define solar radiation source term */
#define LONGWAVE_OUT     /* Compute net longwave radiation internally */
#define EMINUSP          /* turn ON internal calculation of E-P */
**  Variational Data Assimilation.
**  Options to compute error covariance normalization coefficients.
#ifdef NORMALIZATION
# define ADJUST_BOUNDARY
# define ADJUST_WSTRESS
# define ADJUST_STFLUX
# define CORRELATION
# define VCONVOLUTION
# define IMPLICIT_VCONV
# define FULL_GRID
# define FORWARD_WRITE
# define FORWARD_READ
# define FORWARD_MIXING
# define OUT_DOUBLE
**  Options for adjoint-based algorithms sanity checks.
#ifdef SANITY_CHECK
# define FULL_GRID
# define OUT_DOUBLE
# define ANA_PERTURB
# define ANA_INITIAL
**  Common options to all 4DVAR algorithms.
    defined I4DVAR                   || \
    defined RBL4DVAR_ANA_SENSITIVITY || \
    defined R4DVAR                   || \
    defined R4DVAR_ANA_SENSITIVITY
# define PRIOR_BULK_FLUXES
# define FORWARD_FLUXES
# define BALANCE_OPERATOR
# ifdef BALANCE_OPERATOR
#  define ZETA_ELLIPTIC
# define OUT_DOUBLE
**  Special options for each 4DVAR algorithm.
    defined R4DVAR                 || \
# define RPM_RELAXATION
ROMS/TOMS Framework:  April 9, 2023
svn: $HeadURL: https://www.myroms.org/svn/src/trunk/ROMS/Version $
svn: $LastChangedBy: arango $
svn: $LastChangedRevision: 1165 $
svn: $LastChangedDate: 2023-04-09 22:59:07 -0300 (dom, 09 abr 2023) $
otel
Re: compilation attempt using wc13.h fails
#2 Unread post by otel »
Hello everyone,
After exchanging a few emails with Mr. Robertson and Dr. Levin we realized that our issue was actually an outdated version of ROMS (In fact the actual version we were trying to compile was NOT the revision 1165 as indicated in our previous message :oops: ). After updating the source code to the latest version (ticket 1166) the model compiled successfully.
We appreciate your time
Dalton.
