Hello, colleagues
I am running a simulation and find that the simulation below up immediately after defining NONLIN_EOS. I tried to circumvent the problem by shortening the dt, but the problem was not solved. The simulation continues when NONLIN_EOS is not defined, i.e. when using linear density calculations. Do I need to change anything in the .h or .in file if I want to continue using non-linear terms?
Error caused by define NONLIN_EOS
- Location: Institute of Oceanology of the Chinese Academy
ecs.h
- (1.89 KiB) Downloaded 448 times
roms_upwelling.in
- (153.82 KiB) Downloaded 428 times
error_output.txt
- (592.5 KiB) Downloaded 433 times
