Question calculating transport of passive tracer
agaul
#1 Unread post by agaul »
Hi everyone,
I am trying to calculate how much of a passive tracer crosses from offshore to onshore of the shelf-break, and I have calculated this using two different methods. These methods give different answers by a factor of 3, which shouldn't be the case (I think), so I am wondering if I am doing something blatantly wrong or if there is a reason that these two methods actually shouldn't be expected to agree.
Method A)
1) Take a slice of Hvom_dye_01 (from roms_avg.nc) in the alongshore, at the shelf-break. This will have dimensions (Nx,1,Nz,timesteps), where timesteps are from the beginning to end of the simulation. And it has units [m^3/s*kg/m^3=kg/s]
2) Sum the slice in space to get the total flux of passive tracer at each timestep [kg/s].
3) Integrate in time to get the total transport of passive tracer to onshore of the shelf-break [kg].
Method B)
1) Use the dye_01 concentration from roms_his.nc at the final model timestep [units kg/m^3]
2) Integrate this field in space over the region onshore of the shelf-break to get the total mass of tracer that is onshore of the shelf-break [kg].
Thank you in advance,
Alan
My model is along-shore in x, cross-shore in y, and has periodic east & west boundaries. The passive tracer is set to 1 in regions offshore of the shelf-break as an initial condition.
rduran
Re: Question calculating transport of passive tracer
#2 Unread post by rduran »
For flux and transport, you need a velocity. I don't see that in A. By including the velocity you account for stuff leaving, not just stuff entering.
#3 Unread post by wilkin »
What you say is, in principle, correct. Generally speaking, in method B you need to subtract the mass of tracer at the start, but that is zero for this specific set up, right?
How are you calculating dz in the volume integral? It is easy to get that wrong if you are coding from scratch.
Replying to rduran: The v-velocity is the "v" in Hvom_dye_01
agaul
#4 Unread post by agaul »
Hi John, thanks for your reply.
Correct, in this setup the starting mass of tracer is zero in the region I am summing over, which is everywhere onshore of the shelfbreak
I am using the roms_zint.m function in your roms matlab tools package.
