Time problem of ROMS result output
huangyg_123
#1 Unread post by huangyg_123 »
Hi everyone
When I run COAWST, I have a problem with the timing of the results output by ROMS. The running time of ROMS I set in the oceanin file is 2017-08-09 to 2017-09-18, but the time of ROMs output is 2017-08-07 to 2017-09-16. Hope someone can tell me where the problem is. See the attachment for the running log
Re: Time problem of ROMS result output
#2 Unread post by arango »
Ensure the time in the initial conditions NetCDF file is 2017-08-09. ROMS sets the initial time when reading the initial conditions NetCDF file. You can check that time easily if your NetCDF file has the correct units attribute for time:
ncdump -t -v ocean_time my_roms_ini.nc
