Unable to complete ./build.bash compilation
ShimaKasaei
#1 Unread post by ShimaKasaei »
Hello all,
I am a new user to ROMS and trying to follow tutorial steps to run my modified model in both serial and parallel.
My problem is, I am not able to get ROMS executables after doing ./build.bash as it says:
rm -f -r core *.ipo /home/ywang/roms/Projects/JB01/Build /home/ywang/make_macros.mk
cp -f /opt/junk/netcdff/include/netcdf.mod /home/ywang/roms/Projects/JB01/Build
cp -f /opt/junk/netcdff/include/typesizes.mod /home/ywang/roms/Projects/JB01/Build
cp -p /home/ywang/make_macros.mk /home/ywang/roms/Projects/JB01/Build
make: *** No rule to make target `8'. Stop.
Anyone has any thoughts for the possible issue?
Thank you in advance.
Best,
Shima
robertson
Re: Unable to complete ./build.bash compilation
#2 Unread post by robertson »
How and when did you download your ROMS source code? The bash build script has not been named build.bash for almost 4 years and is now called build_roms.sh. Are you perhaps trying to use an old build.bash with the new source code? If so, I would suggest starting anew with the build_roms.sh file from the ROMS/Bin directory of the new source code as many, many things have changed in ROMS since build.bash was last used.
Also, what tutorial are you following?
ShimaKasaei
#3 Unread post by ShimaKasaei »
Well yes, I am using the old version but everything is consistent, I mean build.bash and the ROMS version.
As for the tutorial, I am following Wiki ROMS steps to run my case, and there is a manual also that we can get it online which tried to use.
Any other assumption for my issue?
Best,
Shima
robertson
#4 Unread post by robertson »
If everything is consistent, the error would suggest that there is a typo somewhere that is making ROMS think it's supposed to be building something called '8'. Perhaps there's a path with a space in it or just an errant '8'?
