Surface boundary condition
logvinov
#1 Unread post by logvinov »
I have a question about surface boundary condition.
I run application with uniform wind in x-direction sustr=5e-8 and with a constant value of Akv=1e-3.
When I checked the output the stress condition (sustr=Akv*du/dz) didn't work! Value in the output (Akv*du/dz) is ~15% less.
What is especially tricky du/dz seems to go to desirable value(big enough to satisfy stress condition) but then drops sharply in the top 2 grid points!
Here is the link to du/dz(z) plot and his.nc file
http://web.mit.edu/~logvinov/Public/ROMS/
Thanks a lot,
Evgeny
kurapov
#2 Unread post by kurapov »
The Ekman layer thickness is delta=sqrt(2*Akv/f) (see Pedlosky'87, 4.3.16)
Akv=1.e-3 m2/s
f=1.e-4 1/s
=> delta= 4m
So the sharp change you see in u,v in the upper 4 m is Ekman veering.
Besides, sustr=Akv du/dz at the surface. You are probably trying to estimate
it at the points below the surface. That's why you get 15% diff.
logvinov
#3 Unread post by logvinov »
Hi Alexander,
Thanks a lot for your reply!
Yep, Ekman layer is there, but as you said it is 4.5m. And indeed there is a significant correction on the field in the Ekman layer, which actually tends to go to the right value of du/dz (that would satisfy a stress condition).
But We see a very sharp change in the top 1 meter that actually goes to a smaller value of du/dz at the very surface! (see the fig above). I am not sure why it happens.
I am wondering if I am not aware of some tricky ROMS boundary condition, that it tries to satisfy. (Not just a stress condition)
kurapov
#4 Unread post by kurapov »
Use a better resolution. Try to resolve the boundary layer. Or, for the sake of experiment,
increase Akv by an order of magnitude.
logvinov
#5 Unread post by logvinov »
The resolution is pretty hight already. It has 5-6 points in Ekman layer, so I don't think there should be a problem with resolution. I'll try the bigger values of Vertical mixing
logvinov
#6 Unread post by logvinov »
The problem was in using
#define SPLINES
#define UV_SADVECTION
I terned them off and now everything is working
