Forcing file erro
jc_Sun
Location: Institute of Oceanology of the Chinese Academy
Forcing file erro
#1 Unread post by jc_Sun »
I want to use ROMS for one month simulation, and I made the relevant NC file using crocotools, but the following error appears after execution, I checked blk.nc and found that there is no variable wind_time and cycle_length related properties.
GET_CYCLE_NF90 - unable to get value for attribute: cycle_length
in variable: wind_time
This attribute value is expected to be of
the same external type as the variable.
Found Error: 02 Line: 346 Source: ROMS/Utility/inquiry.F, inquiry_nf90
Found Error: 02 Line: 219 Source: ROMS/Utility/get_2dfld.F, get_2dfld_nf90
Found Error: 02 Line: 112 Source: ROMS/Utility/get_2dfld.F
Found Error: 02 Line: 169 Source: ROMS/Nonlinear/get_data.F
Found Error: 02 Line: 670 Source: ROMS/Nonlinear/initial.F
Found Error: 02 Line: 197 Source: ROMS/Drivers/nl_roms.h, ROMS_initialize
jbettencourt
Re: Forcing file erro
#2 Unread post by jbettencourt »
crocotools are designed for the CROCO ocean model, which is not the same model as ROMS. My advice would be to use the Matlab scripts provided by ROMS to create the forcing file.
jc_Sun
#3 Unread post by jc_Sun »
Thank you for your advice
