I am trying to navigate through wiki roms to figure out what options I have for horizontal mixing of momentum and tracers.
Currently I find there are four - which are UV_VIS2, UV_VIS4 - these two are well commented - and perhaps also TS_DIF2 and TS_DIF4 that have zero information provided?
whereas TS_DIF2 and TS_DIF4 have absolutely no information -UV_VIS2
Option to activate/deactivate horizontal, harmonic viscosity of momentum. The hamonic mixing of momentum can be applied along terrain-following or geopotential levels. In ROMS, the viscosity is derived from the horizontal divergence of the deviatory stress tensor (Wajsowicz, 1993).
parameter = visc2(ng)
variable = visc2_p(:,:), visc2_r(:,:)
required = MIX_S_UV, MIX_GEO_UV
related = VISC_GRID
routine = uv3dmix2_s.h, uv3dmix2_geo.h, uv3dmix.F
UV_VIS4
Option to activate/deactivate horizontal, biharmonic viscosity of momentum. The bihamonic mixing of momentum can be applied along terrain-following or geopotential levels. In ROMS, the viscosity is derived from the horizontal divergence of the deviatory stress tensor (Wajsowicz, 1993).
parameter = visc4(ng)
variable = visc4_p(:,:), visc4_r(:,:)
related = VISC_GRID
routine = uv3dmix4_s.h, uv3dmix4_geo.h, uv3dmix.F
Can someone explain what these are? Is there a reference to what they are? My suspicion is that they are 2nd order and 4th order schemes?TS_DIF2
Option to
parameter =
parent =
required =
related =
conflict =
routine =
TS_DIF4
Option to
parameter =
parent =
required =
related =
conflict =
routine =
thanks
