I'm trying to run ROMS alone in the COAWST model.
The header file (.h) is set to #define ROMS, and the others are set to #undef.
coast.bash was able to compile successfully, and I prepared various necessary files and tried to execute the calculation.
Then an error occurred.
Below are my header files (.h), input files (.in) and output results (.out).
<.h file>
** svn $Id: sandy.h 25 2007-04-09 23:43:58Z jcwarner $
** Copyright (c) 2002-2007 The ROMS/TOMS Group **
** See License_ROMS.txt **
** Options for Sandy Test.
** Application flag: SANDY
#define ROMS_MODEL
#undef NESTING
#undef WRF_MODEL
#undef SWAN_MODEL
#undef WW3_MODEL
#undef MCT_LIB
#undef MCT_INTERP_OC2AT
#undef MCT_INTERP_WV2AT
#undef MCT_INTERP_OC2WV
#if defined WRF_MODEL && (defined SWAN_MODEL || defined WW3_MODEL)
# define DRAGLIM_DAVIS
# define COARE_TAYLOR_YELLAND
#ifdef ROMS_MODEL
/* Physics + numerics */
# if defined WW3_MODEL || defined SWAN_MODEL
# define WEC_VF
# define WDISS_WAVEMOD
# define UV_KIRBY
# define UV_ADV
# define UV_COR
# define UV_VIS2
# define MIX_S_UV
# undef TS_FIXED
# undef SSW_BBL
# ifdef SSW_BBL
# define SSW_CALC_ZNOT
# define ANA_SEDIMENT
# else
# define UV_LOGDRAG
# if !defined SWAN_MODEL && defined SSW_BBL
# define ANA_WWAVE
# define DJ_GRADPS
# define TS_DIF2
# define MIX_GEO_TS
# define CURVGRID
# define SALINITY
# define SOLVE3D
# define SPLINES_VDIFF
# define SPLINES_VVISC
# define AVERAGES
# define NONLIN_EOS
/* Grid and Initial */
# define MASKING
/* Forcing */
# ifdef WRF_MODEL
# undef BULK_FLUXES
# define ATM2OCN_FLUXES
# undef ANA_SSFLUX
# undef LONGWAVE_OUT
# else
# define BULK_FLUXES
# define ANA_NUDGCOEF
# define ATM_PRESS
# define ANA_BTFLUX
# define ANA_BSFLUX
# define ANA_BPFLUX
# define ANA_SPFLUX
# define ANA_SRFLUX
# define EMINUSP
# define SOLAR_SOURCE
/* Turbulence closure */
# define GLS_MIXING
# undef MY25_MIXING
# define LIMIT_VDIFF
# define LIMIT_VVISC
# define RI_SPLINES
# define CRAIG_BANNER
# define CHARNOK
# define SSH_TIDES
# define UV_TIDES
# define RAMP_TIDES
# define ANA_FSOBC
# define ANA_M2OBC
/* Output */
# undef DIAGNOSTICS_UV
# undef DIAGNOSTICS_TS
Model Input Parameters: ROMS/TOMS version 3.9
Friday - July 29, 2022 - 11:09:47 PM
Hurricane Katrina
Operating system : Linux
CPU/hardware : x86_64
Compiler system : gfortran
Compiler command : /home/concretelab/Build_COAWST/LIBRARIES/mpich/bin/mpif90
Compiler flags : -frepack-arrays -O3 -ffast-math -O3 -ftree-vectorize -ftree-loop-linear -funroll-loops -w -
OCN Communicator : 1140850688, PET size = 1
Input Script :
SVN Root URL :
SVN Revision :
Local Root : /home/concretelab/Build_COAWST/ROMS_COAWST
Header Dir : /home/concretelab/Build_COAWST/ROMS_COAWST/Projects/Katrina
Header file : katrina.h
Analytical Dir : /home/concretelab/Build_COAWST/ROMS_COAWST/Projects/Katrina
Resolution, Grid 01: 98x98x15, Parallel Nodes: 1, Tiling: 1x1
10800 ntimes Number of timesteps for 3-D equations.
40.000 dt Timestep size (s) for 3-D equations.
60 nRST Number of timesteps between the writing of data
into restart fields.
to standard output.
60 nHIS Number of timesteps between the writing fields
into history file.
0 nQCK Number of timesteps between the writing fields
into quicksave file.
time-averaged data.
432 nAVG Number of timesteps between the writing of
2.0000E-01 nl_tnu2(01) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 01: temp
2.0000E-01 nl_tnu2(02) NLM Horizontal, harmonic mixing coefficient
(m2/s) for tracer 02: salt
1.0000E-01 nl_visc2 NLM Horizontal, harmonic mixing coefficient
(m2/s) for momentum.
for tracer 02: salt
1.0000E-03 Akt_limit(01) Vertical diffusion upper threshold (m2/s)
1.0000E-03 Akt_limit(02) Vertical diffusion upper threshold (m2/s)
for tracer 02: salt
1.0000E-03 Akv_limit Vertical viscosity upper threshold (m2/s)
for turbulent energy.
0.000 wec_alpha WEC factor for roller/breaking energy distribution.
2.0000E+00 blk_ZQ Height (m) of surface air humidity measurement.
1 lmd_Jwt Jerlov water type.
8.0000E+00 theta_s S-coordinate surface control parameter.
4.0000E+00 theta_b S-coordinate bottom control parameter.
20.000 Tcline S-coordinate surface/bottom layer width (m) used
38591.000 dstart Time-stamp assigned to model initialization (days).
38591.000 tide_start Reference time origin for tidal forcing (days).
18581117.00 time_ref Reference time for units attribute (yyyymmdd.dd)
for tracer 02: salt
1.0000E+00 M3nudg Nudging/relaxation time scale (days)
for 3D momentum.
T LtracerCLM(01) Turning ON processing of climatology tracer 01: temp
T LtracerCLM(02) Turning ON processing of climatology tracer 02: salt
T LnudgeTCLM(01) Turning ON nudging of climatology tracer 01: temp
T LnudgeTCLM(02) Turning ON nudging of climatology tracer 02: salt
T Hout(idPair) Write out surface air pressure.
T Hout(idTair) Write out surface air temperature.
T Hout(idUair) Write out surface U-wind component.
T Hout(idVair) Write out surface V-wind component.
T Hout(idUairE) Write out surface Eastward U-wind component.
T Hout(idVairN) Write out surface Northward V-wind component.
T Hout(idSrad) Write out shortwave radiation flux.
T Hout(idLrad) Write out longwave radiation flux.
T Hout(idLhea) Write out latent heat flux.
T Hout(idShea) Write out sensible heat flux.
T Hout(idEmPf) Write out E-P flux.
T Hout(idevap) Write out evaporation rate.
T Hout(idrain) Write out rain rate.
T Hout(idMtke) Write out turbulent kinetic energy.
T Hout(idMtls) Write out turbulent generic length-scale.
T Aout(idSdif) Write out averaged vertical diffusion: AKt(isalt).
Output Restart File: Katrina_ocean_rst.nc
Output History File: Katrina_ocean_his.nc
Output Averages File: Katrina_ocean_avg.nc
Input Grid File: Projects/Katrina/roms_grid_Katrina.nc
Input Nonlinear Initial File: Projects/Katrina/Katrina_ini.nc
Tidal Forcing File: Projects/Katrina/tide_forc_Katrina.nc
Input Forcing File 01: Projects/Katrina/romsforc_NARR_Katrina2005.nc
Input Climatology File 01: Projects/Katrina/Katrina_clim.nc
Input Lateral Boundary File 01: Projects/Katrina/Katrina_bry.nc
ROMS I/O variables Metadata File: ROMS/External/varinfo.dat
Tile partition information for Grid 01: 98x98x15 tiling: 1x1
tile Istr Iend Jstr Jend Npts
0 1 98 1 98 144060
(interior points only)
tile Xmin Xmax Ymin Ymax grid
0 0.50 98.50 0.50 98.50 RHO-points
0 1.00 98.00 0.50 98.50 U-points
0 0.50 98.50 1.00 98.00 V-points
HaloSizeI(1) = 218
HaloSizeJ(1) = 218
TileSide(1) = 103
TileSize(1) = 10609
Tracer Advection Scheme: NLM
Variable Grid Horizontal Vertical
temp 1 Upstream3 Centered4
salt 1 Upstream3 Centered4
Akima4 Fourth-order Akima advection
Centered2 Second-order centered differences advection
Centered4 Fourth-order centered differences advection
HSIMT Third High-order Spatial Inteporlation at Middle Time Advection with TVD limiter
MPDATA Multidimensional Positive Definite Advection Algorithm, recursive method
Splines Conservative Parabolic Splines Reconstruction Advection (only vertical; not recommended)
Split_U3 Split third-order Upstream Advection
Upstream3 Third-order Upstream-biased Advection (only horizontal)
zeta 1 Closed Chapman Imp Chapman Imp Chapman Imp
ubar 1 Closed Flather Flather Flather
vbar 1 Closed Flather Flather Flather
u 1 Closed Nested Nested Nested
v 1 Closed Nested Nested Nested
temp 1 Gradient Nested Nested Gradient
salt 1 Gradient Nested Nested Gradient
tke 1 Closed Gradient Gradient Gradient
KATRINA Hurricane Katrina
ANA_BSFLUX Analytical kinematic bottom salinity flux
ANA_BTFLUX Analytical kinematic bottom temperature flux
ANA_FSOBC Analytical free-surface boundary conditions
ANA_M2OBC Analytical 2D momentum boundary conditions
ANA_NUDGCOEF Analytical spatially varying nudging time-scales
ANA_SRFLUX Analytical kinematic shortwave radiation flux
ASSUMED_SHAPE Using assumed-shape arrays
ATM_PRESS Impose atmospheric pressure onto sea surface
AVERAGES Writing out time-averaged nonlinear model fields
!BOUNDARY_ALLGATHER Using mpi_allreduce in mp_boundary routine
BULK_FLUXES Surface bulk fluxes parameterization
!COLLECT_ALL... Using mpi_isend/mpi_recv in mp_collect routine
CHARNOK Charnok surface roughness from wind stress
CRAIG_BANNER Craig and Banner wave breaking surface flux
CURVGRID Orthogonal curvilinear grid
DJ_GRADPS Parabolic Splines density Jacobian (Shchepetkin, 2002)
DOUBLE_PRECISION Double precision arithmetic numerical kernel.
EMINUSP Compute Salt Flux using E-P
GLS_MIXING Generic Length-Scale turbulence closure
KANTHA_CLAYSON Kantha and Clayson stability function formulation
LIMIT_VDIFF Impose an upper limit on vertical diffusion coefficient
LIMIT_VVISC Impose an upper limit on vertical viscosity coefficient
MASKING Land/Sea masking
MIX_GEO_TS Mixing of tracers along geopotential surfaces
MIX_S_UV Mixing of momentum along constant S-surfaces
MPI MPI distributed-memory configuration
NONLINEAR Nonlinear Model
NONLIN_EOS Nonlinear Equation of State for seawater
N2S2_HORAVG Horizontal smoothing of buoyancy and shear
POWER_LAW Power-law shape time-averaging barotropic filter
PROFILE Time profiling activated
K_GSCHEME Third-order upstream advection of TKE fields
RAMP_TIDES Ramping tidal forcing for one day
REDUCE_ALLREDUCE Using mpi_allreduce in mp_reduce routine
RI_SPLINES Parabolic Spline Reconstruction for Richardson Number
!RST_SINGLE Double precision fields in restart NetCDF file
SALINITY Using salinity
SOLAR_SOURCE Solar Radiation Source Term
SOLVE3D Solving 3D Primitive Equations
SPLINES_VDIFF Parabolic Spline Reconstruction for Vertical Diffusion
SPLINES_VVISC Parabolic Spline Reconstruction for Vertical Viscosity
SSH_TIDES Add tidal elevation to SSH climatology
TS_DIF2 Harmonic mixing of tracers
UV_ADV Advection of momentum
UV_COR Coriolis term
UV_U3HADVECTION Third-order upstream horizontal advection of 3D momentum
UV_C4VADVECTION Fourth-order centered vertical advection of momentum
UV_LOGDRAG Logarithmic bottom stress
UV_TIDES Add tidal currents to 2D momentum climatologies
UV_VIS2 Harmonic mixing of momentum
VAR_RHO_2D Variable density barotropic mode
Process Information:
Node # 0 (pid= 105506) is active.
GET_GRID - angle between XI-axis and EAST: angler
(Grid = 01, File: Projects/Katrina/roms_grid_Katrina.nc)
(Min = -2.10128491E-12 Max = 2.88440987E-12)
GET_GRID - bathymetry at RHO-points: h
(Min = -2.15744419E+02 Max = 3.33282292E+03)
GET_GRID - Coriolis parameter at RHO-points: f
(Min = 6.41047590E-05 Max = 7.91128633E-05)
GET_GRID - reciprocal XI-grid spacing: pm
(Min = 1.40936455E-04 Max = 1.50689689E-04)
GET_GRID - reciprocal ETA-grid spacing: pn
(Min = 1.31388388E-04 Max = 1.31388389E-04)
GET_GRID - XI-derivative of inverse metric factor pn: dndx
(Min = -5.92140623E-07 Max = 5.92140623E-07)
GET_GRID - ETA-derivative of inverse metric factor pm: dmde
(Min = -5.10947184E+00 Max = 0.00000000E+00)
GET_GRID - longitude of RHO-points: lon_rho
(Min = -9.30376282E+01 Max = -8.60048832E+01)
GET_GRID - longitude of U-points: lon_u
(Min = -9.30021093E+01 Max = -8.60404021E+01)
GET_GRID - longitude of V-points: lon_v
GET_GRID - longitude of PSI-points: lon_psi
GET_GRID - latitude of RHO-points lat_rho
(Min = 2.60755171E+01 Max = 3.28514916E+01)
GET_GRID - latitude of U-points: lat_u
GET_GRID - latitude of V-points: lat_v
(Min = 2.61097392E+01 Max = 3.28172695E+01)
GET_GRID - latitude of PSI-points lat_psi
GET_GRID - mask on RHO-points: mask_rho
(Min = 0.00000000E+00 Max = 1.00000000E+00)
GET_GRID - mask on U-points: mask_u
GET_GRID - mask on V-points: mask_v
GET_GRID - mask on PSI-points: mask_psi
15 0.0000000 0.0000000 0.000 0.000 0.000 0.000
14 -0.0666667 -0.0003983 -1.375 -0.671 -1.929 -2.645
13 -0.1333333 -0.0017081 -2.533 -1.350 -5.261 -8.310
12 -0.2000000 -0.0043062 -3.385 -2.043 -10.576 -18.242
11 -0.2666667 -0.0089353 -3.754 -2.756 -19.015 -34.904
10 -0.3333333 -0.0169029 -3.329 -3.502 -32.592 -62.625
9 -0.4000000 -0.0304126 -1.586 -4.304 -54.697 -108.707
8 -0.4666667 -0.0530642 2.331 -5.197 -90.870 -185.076
7 -0.5333333 -0.0905094 9.766 -6.238 -149.807 -310.455
6 -0.6000000 -0.1510347 22.688 -7.510 -244.259 -512.298
5 -0.6666667 -0.2452550 43.623 -9.119 -390.561 -825.770
4 -0.7333333 -0.3828872 74.881 -11.162 -603.665 -1283.062
3 -0.8000000 -0.5634305 116.342 -13.634 -882.800 -1882.517
2 -0.8666667 -0.7610631 161.867 -16.277 -1188.232 -2538.588
1 -0.9333333 -0.9210683 198.445 -18.544 -1435.763 -3070.001
0 -1.0000000 -1.0000000 215.744 -20.000 -1558.539 -3332.823
Time Splitting Weights for Grid 01: ndtfast = 30 nfast = 42
12 0.0043042707117221 0.0335513677379153-0.0022367614257357 0.4026337758325831
13 0.0060106451121704 0.0334078920475245 0.0037738836864347 0.4360416678801076
15 0.0099910761708920 0.0329439123123590 0.0216737068001212 0.5021931174029188
16 0.0122483446563884 0.0326108764399960 0.0339220514565096 0.5348039938429148
17 0.0146692120341107 0.0322025982847830 0.0485912634906203 0.5670065921276978
18 0.0172400033810439 0.0317136245503127 0.0658312668716642 0.5987202166780105
19 0.0199444086685725 0.0311389577709445 0.0857756755402367 0.6298591744489550
20 0.0227631639997064 0.0304741441486588 0.1085388395399431 0.6603333185976138
21 0.0256737146312910 0.0297153720153352 0.1342125541712341 0.6900486906129490
22 0.0286498597812016 0.0288595815276255 0.1628624139524357 0.7189082721405746
23 0.0316613792205220 0.0279045862015855 0.1945237931729577 0.7468128583421600
24 0.0346736416507075 0.0268492068942347 0.2291974348236651 0.7736620652363948
25 0.0376471948657328 0.0256934188392112 0.2668446296893979 0.7993554840756060
26 0.0405373376992232 0.0244385123436867 0.3073819673886211 0.8237939964192927
27 0.0432936737565711 0.0230872677537126 0.3506756411451922 0.8468812641730054
28 0.0458596469320356 0.0216441452951603 0.3965352880772278 0.8685254094681656
29 0.0481720587108284 0.0201154903974257 0.4447073467880562 0.8886408998655914
30 0.0501605672561820 0.0185097551070648 0.4948679140442381 0.9071506549726561
31 0.0517471682814030 0.0168377361985254 0.5466150823256412 0.9239883911711815
32 0.0528456577069106 0.0151128305891453 0.5994607400325517 0.9391012217603267
33 0.0533610761022577 0.0133513086655816 0.6528218161348094 0.9524525304259084
34 0.0531891349131379 0.0115726061288397 0.7060109510479473 0.9640251365547481
35 0.0522156244733761 0.0097996349650684 0.7582265755213234 0.9738247715198165
36 0.0503158038019031 0.0080591141492892 0.8085423793232265 0.9818838856691057
37 0.0473537721847153 0.0063819206892258 0.8558961515079418 0.9882658063583315
38 0.0431818225418188 0.0048034616164019 0.8990779740497606 0.9930692679747335
39 0.0376397765791564 0.0033640675316746 0.9367177506289170 0.9964333355064081
40 0.0305543017255206 0.0021094083123694 0.9672720523544377 0.9985427438187775
41 0.0217382098544505 0.0010909315881854 0.9890102622088881 0.9996336754069629
42 0.0109897377911119 0.0003663245930371 1.0000000000000000 1.0000000000000000
Minimum X-grid spacing, DXmin = 6.63615411E+00 km Water points = 6.79507250E+00 km
Maximum X-grid spacing, DXmax = 7.09539627E+00 km Water points = 7.09539627E+00 km
Minimum Y-grid spacing, DYmin = 7.61102264E+00 km Water points = 7.61102264E+00 km
Maximum Y-grid spacing, DYmax = 7.61102265E+00 km Water points = 7.61102265E+00 km
Minimum Z-grid spacing, DZmin = -8.41525285E+01 m Water points = -1.38040192E-01 m
Maximum Z-grid spacing, DZmax = 4.73552371E+01 m Water points = 6.56070675E+02 m
Minimum barotropic Courant Number = 7.42536615E-07
Maximum barotropic Courant Number = 4.64534958E-02
Maximum Coriolis Courant Number = 2.97491249E-03
NLM: GET_STATE - Reading state initial conditions, 2005-08-27 00:00:00.00
(Grid 01, t = 53609.0000, File: Katrina_ini.nc, Rec=0001, Index=1)
- free-surface
(Min = -3.54594313E-01 Max = 4.45445436E-01)
(Min = -1.41692584E-01 Max = 2.49862346E-01)
(Min = -1.73684799E-01 Max = 1.14896163E-01)
- u-momentum component
(Min = -9.26025459E-01 Max = 1.03917037E+00)
- v-momentum component
(Min = -9.95687677E-01 Max = 5.99752986E-01)
- potential temperature
(Min = 4.15533894E+00 Max = 3.54882013E+01)
- salinity
(Min = -1.15116346E+01 Max = 3.68338484E+01)
GET_NGFLD - tidal period
(Grid = 01, Min = 1.49047215E+04 Max = 9.67260840E+04)
(Grid = 01, Min = 0.00000000E+00 Max = 2.09046983E-01)
(Grid = 01, Min = -1.29687416E+01 Max = 4.82525186E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.28316919E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 6.28306597E+00)
(Grid = 01, Min = 0.00000000E+00 Max = 3.46792927E-01)
(Grid = 01, Min = -8.07614703E-02 Max = 4.40275504E-02)
GET_2DFLD - surface u-wind component, 2005-08-27 00:00:00.00
(Grid=01, Rec=1, Index=1, File: romsforc_NARR_Katrina2005.nc)
(Tmin= 53609.0000 Tmax= 53614.0000) t = 53609.0000
(Min = -1.07696928E+01 Max = -8.92840971E-01) regrid = T
GET_2DFLD - surface v-wind component, 2005-08-27 00:00:00.00
(Min = -8.16268255E+00 Max = 3.43387192E+00) regrid = T
GET_2DFLD - surface air pressure, 2005-08-27 00:00:00.00
(Min = 1.00612364E+03 Max = 1.01279449E+03) regrid = T
GET_2DFLD - net longwave radiation flux, 2005-08-27 00:00:00.00
(Min = -1.29572949E-05 Max = -6.30481076E-07) regrid = T
GET_2DFLD - surface air temperature, 2005-08-27 00:00:00.00
(Min = 2.74625011E+01 Max = 3.52368334E+01) regrid = T
GET_2DFLD - surface air relative humidity, 2005-08-27 00:00:00.00
(Min = 4.85722983E-01 Max = 8.13929408E-01) regrid = T
GET_2DFLD - rain fall rate, 2005-08-27 00:00:00.00
(Min = 3.83558273E-07 Max = 3.75354200E-05) regrid = T
GET_NGFLD - 3D u-momentum eastern boundary condition, 2005-08-27 00:00:00.00
(Grid= 01, Rec=1, Index=2, File: Katrina_bry.nc)
(Min = -3.29027653E-01 Max = 2.30727926E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, 2005-08-27 00:00:00.00
(Min = -8.52026403E-01 Max = 1.83875933E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, 2005-08-27 00:00:00.00
(Min = -9.26025450E-01 Max = 6.07419252E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, 2005-08-27 00:00:00.00
(Min = -9.95687664E-01 Max = 5.74938476E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, 2005-08-27 00:00:00.00
GET_NGFLD - 3D v-momentum northern boundary condition, 2005-08-27 00:00:00.00
GET_NGFLD - temperature eastern boundary condition, 2005-08-27 00:00:00.00
(Min = 0.00000000E+00 Max = 3.17894020E+01)
GET_NGFLD - salinity eastern boundary condition, 2005-08-27 00:00:00.00
(Min = 0.00000000E+00 Max = 3.63082657E+01)
GET_NGFLD - temperature southern boundary condition, 2005-08-27 00:00:00.00
(Min = 4.22060776E+00 Max = 3.13313637E+01)
GET_NGFLD - salinity southern boundary condition, 2005-08-27 00:00:00.00
(Min = 3.48331337E+01 Max = 3.68266792E+01)
GET_3DFLD - potential temperature climatology, 2005-08-27 00:00:00.00
(Grid=01, Rec=1, Index=1, File: Katrina_clim.nc)
GET_3DFLD - salinity climatology, 2005-08-27 00:00:00.00
Maximum grid stiffness ratios: rx0 = 2.000000E-01 (Beckmann and Haidvogel)
rx1 = 5.800000E+00 (Haney)
Initial domain volumes: TotVolume = 3.7806098739E+14 m3
MinCellVol = -7.1542085900E+06 m3
MaxCellVol = 3.4742261021E+10 m3
Max/Min = -4.8561990587E+03
NL ROMS/TOMS: started time-stepping: (Grid: 01 TimeSteps: 000032438881 - 000032449680)
GET_2DFLD - surface u-wind component, 2005-08-27 03:00:00.00
(Grid=01, Rec=2, Index=2, File: romsforc_NARR_Katrina2005.nc)
(Tmin= 53609.0000 Tmax= 53614.0000) t = 53609.1250
(Min = -1.20530137E+01 Max = 5.51073609E-01) regrid = T
GET_2DFLD - surface v-wind component, 2005-08-27 03:00:00.00
(Min = -7.55569400E+00 Max = 3.14627136E+00) regrid = T
GET_2DFLD - surface air pressure, 2005-08-27 03:00:00.00
(Min = 1.00585813E+03 Max = 1.01232250E+03) regrid = T
GET_2DFLD - net longwave radiation flux, 2005-08-27 03:00:00.00
(Min = -1.34115722E-05 Max = -1.42211893E-06) regrid = T
GET_2DFLD - surface air temperature, 2005-08-27 03:00:00.00
(Min = 2.38640230E+01 Max = 3.15746287E+01) regrid = T
GET_2DFLD - surface air relative humidity, 2005-08-27 03:00:00.00
(Min = 6.08187675E-01 Max = 8.83000289E-01) regrid = T
GET_2DFLD - rain fall rate, 2005-08-27 03:00:00.00
(Min = 2.56529711E-06 Max = 3.64055637E-04) regrid = T
GET_NGFLD - 3D u-momentum eastern boundary condition, 2005-08-28 00:00:00.00
(Grid= 01, Rec=2, Index=1, File: Katrina_bry.nc)
(Tmin= 53609.0000 Tmax= 53614.0000) t = 53610.0000
(Min = -1.06390405E+00 Max = 2.70750403E-01)
GET_NGFLD - 3D v-momentum eastern boundary condition, 2005-08-28 00:00:00.00
(Min = -4.67574030E-01 Max = 3.27160418E-01)
GET_NGFLD - 3D u-momentum southern boundary condition, 2005-08-28 00:00:00.00
(Min = -1.06390405E+00 Max = 5.65890431E-01)
GET_NGFLD - 3D v-momentum southern boundary condition, 2005-08-28 00:00:00.00
(Min = -9.68096316E-01 Max = 6.13836169E-01)
GET_NGFLD - 3D u-momentum northern boundary condition, 2005-08-28 00:00:00.00
GET_NGFLD - 3D v-momentum northern boundary condition, 2005-08-28 00:00:00.00
GET_NGFLD - temperature eastern boundary condition, 2005-08-28 00:00:00.00
(Min = 0.00000000E+00 Max = 3.17175808E+01)
GET_NGFLD - salinity eastern boundary condition, 2005-08-28 00:00:00.00
(Min = 0.00000000E+00 Max = 3.63111801E+01)
GET_NGFLD - temperature southern boundary condition, 2005-08-28 00:00:00.00
(Min = 4.21079731E+00 Max = 3.10041027E+01)
GET_NGFLD - salinity southern boundary condition, 2005-08-28 00:00:00.00
(Min = 3.48317986E+01 Max = 3.66650505E+01)
GET_3DFLD - potential temperature climatology, 2005-08-28 00:00:00.00
(Grid=01, Rec=2, Index=2, File: Katrina_clim.nc)
(Min = 4.19558276E+00 Max = 3.47792665E+01)
GET_3DFLD - salinity climatology, 2005-08-28 00:00:00.00
(Min = -1.77656485E+01 Max = 3.68394868E+01)
32438880 2005-08-27 00:00:00.00 NaN NaN NaN NaN
(54,22,12) 5.507628E-03 1.540193E-03 0.000000E+00 1.049467E+00
Found Error: 01 Line: 341 Source: ROMS/Nonlinear/main3d.F
Found Error: 01 Line: 331 Source: ROMS/Drivers/nl_ocean.h, ROMS_run
Node # 0 CPU: 0.184
Total: 0.184
Allocation and array initialization .............. 0.031 (16.7856 %)
Ocean state initialization ....................... 0.003 ( 1.7338 %)
Reading of input data ............................ 0.098 (53.5327 %)
Processing of input data ......................... 0.001 ( 0.4322 %)
Computation of global information integrals ...... 0.001 ( 0.6048 %)
2D/3D coupling, vertical metrics ................. 0.003 ( 1.4888 %)
Omega vertical velocity .......................... 0.001 ( 0.2842 %)
Equation of state for seawater ................... 0.006 ( 3.5079 %)
Total: 0.144 78.3701 %
Unique kernel(s) regions profiled ................ 0.144 78.3701 %
Residual, non-profiled code ...................... 0.040 21.6299 %
All percentages are with respect to total time = 0.184
MPI communications profile, Grid: 01
Message Passage: 2D halo exchanges ............... 0.000 ( 0.0240 %)
Message Passage: 3D halo exchanges ............... 0.000 ( 0.0120 %)
Message Passage: 4D halo exchanges ............... 0.000 ( 0.0016 %)
Message Passage: data broadcast .................. 0.002 ( 0.9532 %)
Message Passage: data reduction .................. 0.000 ( 0.0343 %)
Message Passage: data scattering.................. 0.007 ( 3.5776 %)
Message Passage: point data gathering ............ 0.000 ( 0.0011 %)
Message Passage: synchronization barrier ......... 0.000 ( 0.0022 %)
Total: 0.008 4.6059 %
Dynamic and Automatic memory (MB) usage for Grid 01: 98x98x15 tiling: 1x1
tile Dynamic Automatic USAGE MPI-Buffers
0 79.38 9.74 89.13 1.20
TOTAL 79.38 9.74 89.13 1.20
Found Error: 01 Line: 55 Source: ROMS/Utility/close_io.F, close_inp.F
Analytical header files used:
ROMS/Functionals/ana_btflux.h
ROMS/Functionals/ana_fsobc.h
ROMS/Functionals/ana_m2obc.h
ROMS/Functionals/ana_srflux.h
Found Error: 01 Line: 437 Source: ROMS/Utility/close_io.F, close_out
Please help me.
Thank you
